查看: 3585|回复: 0
[NI软件产品] NI RFIC Test Software 19.0.1 Win32/64Eng NI-RFIC测试软件19.0.1
    发表于 2021-1-24 00:28:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFIC测试软件
    RFIC测试软件简化了宽带RF IC的特性分析。
    RFIC测试软件是一款应用软件,可帮助您分析功率放大器(PA)和前端模块(FEM)等RFIC的特性。如果要对PA进行线性化,有多种针对特定应用的数字预失真(DPD)算法可供选择,例如查找表(LUT)、记忆多项式(MP)和广义记忆多项式(GMP)。此外,您还可以集成并运行NI联盟伙伴的线性化算法或技术。当使用像PXI矢量信号收发仪这样的NI仪器时,您还可以使用该软件来分析包络跟踪(ET)等功率效率优化技术。您可以使用GUI来保存手动配置和执行,以便重复使用这些配置和执行或与其他测试平台共享。National Instruments Alliance Partner(NI联盟伙伴)是独立于NI的商业实体,与NI之间不存在代理、合伙或合资关系。
    Win32/64Eng
    19.0.1
    文件大小: 605329408 字节 (577.29 MB)
    修改日期: 2019-08-29 13:00
    MD5: 17571fe2b6ae04eaa424e76185459f37(官方正确)
    SHA1: 7237ae8669f04d947c8848a06851fd08f678443c
    SHA256: 67c32b905d3ce96dc9c0c3a2306ed36de3408d6e8fb110d525f0943c3df8edc5
    CRC32: 24071b0d
    RFICts19.0.1.txt (667 Bytes, 下载次数: 0, 售价: 10 圆)
    RFIC Test Software 19.0 Readme
    July 2019
    This file contains important information about RFIC Test Software, including new features, supported hardware, a partial list of bugs fixed for RFIC Test Software 19.0, and known issues.
    Driver and Add-On Requirements
    Accessing the APIs
    How to Use NI Software with Microsoft Windows 10
    How to Use NI Software with Microsoft Windows 8.1
    RFIC Test Software Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    RFIC Test Software enables you to explore testing advanced RF integrated circuit (RFIC) devices featuring envelope tracking (ET), digital predistortion (DPD), and hardware-accelerated power servoing. Available measurements include adjacent channel power (ACP), spectral emission mask (SEM), error vector magnitude (EVM), AM-to-AM, and AM-to-PM. To set up measurements for your device, use the installed examples or the RFIC Test Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    RFIC Test Software 19.0:
    • Support for PXIe-5830 Vector Signal Transceiver intermediate frequency (IF)
    • Support for PXIe-5831 Vector Signal Transceiver, including IF
    • Support for downlink test model definitions with 5G New Radio (NR) downlink measurements
    • Support for the Automatic SG SA Shared LO property via RFmx and Automatic LO offset using NI-RFSG Playback Library
    • Support for NanoSemi Linearizer 1.6 (nst_dpd_train_without_align) in combination with RFmx DPD alignment
    • Support for NI-RFSA 19.0
    • RFIC Test Soft Front Panel updates
      • Removed dependency on the RFmx WLAN
      • Added measurement results for each DPD iteration to the summary table
    RFIC Test Software 3.0:
    • Support for 5G NR
    • New extensions framework for the PXIe-5840 Vector Signal Transceiver FPGA bitfile
    RFIC Test Software 2.5:
    • Improvements to the WLAN examples
    • New measurement series (power sweep) examples
    • New Long-Term Evolution (LTE) downlink measurement example
    • New power amplifier enable (PAEN) signal generation examples
    • Support for NI-RFSA 18.1
      • Support for measurement series (power sweep)
      • Support for LTE downlink measurements
    RFIC Test Software 2.3:
    • Support for the PXIe-5820 Vector Signal Transceiver as the arbitrary waveform generator in ET examples
    • Support for NI-RFSA 17.1
      • Support for the PXIe-5820 as the arbitrary waveform generator in ET mode
      • Improvements to DPD
      • Support for performing crest factor reduction (CFR) on reference and DPD waveforms
      • Support for performing Vcc sourcing and system DC current, voltage, and power-added efficiency (PAE) measurements
      • Support for performing WLAN 802.11ax measurements
    • Updated to new installer system
    RFIC Test Software 2.2:
    • New LabVIEW measurement example for WLAN 802.11ax
    • Support for TDMS file version 2.0
    RFIC Test Software 2.1:
    • Support for the PXIe-5840
      Note  This release provides no official support for WLAN measurements using the PXIe-5840.
    • Support for ETSync 2.0 (PXIe-5646 Vector Signal Transceiver only)
    RFIC Test Software 2.0:
    • Support for performing LTE uplink (UL) EVM, ACP, and SEM measurements
    • Support for performing wideband code division multiple access (WCDMA) EVM, ACP, and SEM measurements
    • New LabVIEW measurement examples for LTE, WCDMA, time division synchronous code division multiple access (TD-SCDMA), CDMA2000, Evolution-Data Optimized (EV-DO), Global System for Mobile Communications Enhanced Data Rates for GSM Evolution (GSM-EDGE), and WLAN
    • Support for performing PAE measurements using NI-Scope
    • Support for using detrough shaping functions for ET
    • Support for .NET programming languages
    The following table shows which hardware products are supported in RFIC Test Software. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware Product
    Hardware Model
    Application
    Vector Signal TransceiverPXIe-5646
    Hardware-accelerated power servoing
    PXIe-5830
    PXIe-5831
    PXIe-5840
    PXIe-5820
    Envelope waveform generation when testing ET devices under test (DUTs)
    Waveform GeneratorPXIe-5451
    Envelope waveform generation when testing ET DUTs
    Note  For DEVM measurements, use the PXIe-5820.
    OscilloscopePXIe-5162
    • PAE measurements
    • (Optional) Recommended for envelope waveform/delay analysis when testing ET DUTs
    PXIe-5185
    PXIe-5186
    Source Measure UnitPXIe-4139
    (Optional) Vcc sourcing and system PAE measurements
    PXIe-414x
    RFIC Test Software has the following minimum requirements:
    • Processor—Intel Pentium 4 or equivalent
    • 1 GB RAM*
    • A screen resolution of 1,024 x 768 with 256 colors
    NI recommends the following requirements:
    • 4 GB RAM*
    • A screen resolution of 1,600 x 1,200
    * Depending on the amount of data acquired and/or processed a larger amount of memory may be required.
    RFIC Test Software 19.0 supports Windows 10/8.11/72 (64-bit).
    Note  Refer to RFIC Test Software Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    RFIC Test Software supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFIC Test Software. To add support for application software installed after installing RFIC Test Software, modify your RFIC Test Software installation or launch the RFIC Test Software installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFIC Test Software
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    Microsoft Visual Studio2010 SP1 and later
    Note  RFIC Test Software will not operate correctly without the service packs previously mentioned.
    If you are using the RFIC Test Software .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFIC Test Software .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    RFIC Test Software requires the following driver and add-on versions:
    • NI-RFSG 19.1
    • NI-RFSA 19.1
    • NI-FGEN 19.0
    • NI-DCPower 19.0
    • NI-SCOPE 19.0
    • NI-RFmx SpecAn 19.0
    • NI-RFmx Demod 19.0
    • NI-RFmx LTE 19.01
    • NI-RFmx NR 19.01
    • NI-RFmx WLAN 19.01
    • NI-RFSG Playback Library 19.0
    • (Optional) NanoSemi Linearizer 1.62
    1 Installation and licensing are only required for standard-specific measurements.
    2 Requires a valid license.
    Note  The run-time versions of these products are sufficient to run the RFIC Test Soft Front Panel.
    Accessing the APIsLabVIEW
    ETSync VIs are available in LabVIEW from the Functions»Addons»ET palette.
    Power Servo VIs are available in LabVIEW from the Functions»User Libraries»NI Power Servoing IP palette.
    NanoSemi Linearizer VIs are available in LabVIEW from the Functions»User Libraries»NanoSemi Linearizer palette.
    .NET Framework
    You can use the ETSync .NET Class library by adding a reference to niETSync.cs, niETUtil.cs, and niFGEN.cs from C:\Users\Public\Documents\National Instruments\NI-ETSync\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    You can use the Power Servo .NET Class library by adding a reference to niVSTPowerServo.cs, niRFSA.cs, and niInteropCommon.cs from C:\Users\Public\Documents\National Instruments\FPGA Power Servo\DotNET Wrappers\CS\ and any dependent class libraries from within the Solution Explorer in Visual Studio.
    C
    You can use the ETSync C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niETsync_32.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niETSync_64.dll for 64-bit development.
    You can use the Power Servo C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niVSTPowerServo_32.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niVSTPowerServo_64.dll for 64-bit development.
    RFIC Test SFP
    To launch the RFIC Test SFP, navigate to Start»All Programs»National Instruments»RFIC Test Soft Front Panel.
    All installed RFIC Test Software examples for LabVIEW, C, and .NET are accessible from Start»All Programs»National Instruments»RFIC Test Software»RFIC Examples.
    Documentation for RFIC Test Software is located at Start»All Programs»National Instruments»RFIC Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    RFIC Test Software ManualPDFContains primary help content for RFIC Test Software products. The manual includes the following information:
    • How to get started with the installed examples
    • RFIC Test Soft Front Panel information and examples
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    RFIC Test Software ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    ETSync API ReferencePDFContains information about configuring hardware for use with the ETSync API and a complete reference for ETSync VIs, properties, and functions.
    Power Servo Theory of OperationPDFContains theory of operation information on power servoing and a complete reference for Power Servo VIs, properties, and functions.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI installs RFIC Test Software using NI Package Manager. If you do not already have NI software installed, RFIC Test Software installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Visit ni.com/critical-updates for information about critical updates and security notifications from National Instruments.
    You can access the software and documentation known issues list online. Visit RFIC Test Software 19.0 Known Issues for an up-to-date list of known issues.
    Bug FixesRFIC Test Software
    The following items are a subset of issues fixed between RFIC Test Software revisions. This section is not an exhaustive list of issues fixed in the current version of RFIC Test Software.
    • Corrected export behavior of the reference trigger in conjunction with Power Servo.
    • Fixed an issue where the Power Servo C interface sometimes failed with a time-out error when running in a loop.
    • Fixed an issue where errors prevented LabVIEW measurement examples from closing sessions and required restarting your device.
    • Fixed an issue where using the PXIe-5668 Vector Signal Analyzer in the WLAN shipping example caused a configuration error.
    • Fixed an issue in which the wrong number of waveform samples for the arbitrary waveform generator in the WLAN DEVM example resulted in an error.
    • Fixed an issue where the Power Servo function declaration did not match in the Power Servo wrapper, niVSTPowerServo.cs, and the header files, niVSTPowerServo_[32/64].h.
    RFIC Test Software 2.3.1
    • Fixed an issue where the dynamic link library (DLL) load failed in the ETSync API.
    • Fixed an internal error in the installer.
    • Fixed an issue in which trigger conditions on PXIe-5840 were unstable in the FPGA Power Servo.
    • Fixed an issue with the behavior of Abort VI in case of incoming errors in the FPGA Power Servo.
    • Fixed an issue where servo measurement time on the PXIe-5840 was calculated incorrectly in the FPGA Power Servo.
    • Fixed an issue with the behavior of Abort VI in case of incoming errors in the ETSync API.
    • Fixed an issue in which the DPD Target Gain Type property calculated the Peak Power Adjustment incorrectly after DPD.
    • Fixed an issue where the RFSG Playback Library was used incorrectly.
    • Fixed an issue where TDMS file versions were not compatible.
    • Fixed an issue where deprecated DPD API VIs were used.
    • Fixed an issue where the TD-SCDMA midamble shift was mishandled in the TD-SCDMA example and corresponding example waveform.
    • Fixed an issue where the AMPM Phase Error Range returned an incorrect result.
    • Fixed an issue where the AMPM Mean Error Range did not return a result.
    • Fixed an issue where an incorrect signal was generated if the user-defined sampling rate for AMPM/DPD differed from the sampling rate of the test waveform.
    RFIC Test SFP
    The following items are a subset of issues fixed between RFIC Test SFP revisions. This section is not an exhaustive list of issues fixed in the current version of RFIC Test SFP.
    RFIC Test SFP 3.0
    • Fixed an issue where configuring multiple LTE DL subblocks lead to an error during ACP measurements.
    • Fixed an issue in which ACP Offset channel traces were invisible due to poor contrast with the background.
    • Fixed an issue where the ACP result summary listed the same offset multiple times if multiple subblocks were configured.
    • Fixed an issue where the PFI output would only active the first time after configuration when using the static PFI mode to trigger an amplifier.
    RFIC Test SFP 2.5
    • Fixed an issue where the pre-DPD and post-DPD output powers were not consistent.
    • Fixed an issue where the SFP would crash when the current limit for the SMU was exceeded.
    • Fixed an issue where the SFP would crash when attempting to save waveforms in a directory that did not exist.
    RFIC Test Software will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2004–##year## National Instruments. All rights reserved.
    377985A-01
    GMT+8, 2026-4-23 09:15
