查看: 11|回复: 0
[NI驱动程序] NI RF Signal Generators 2024 Q3 Patch 3 Win11 32/64bitEn NI RF信号发生器NI-RFSG24.5.3
    12 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    NI-RFSG 2024 Q3 Patch 3
    发布日期:2024/10/22
    包含的版本:2024 Q3 Patch 3完整版,版本号24.5.3
    文件大小: 5544402944 字节 (5.16 GB)
    修改日期: 2026-04-08 16:14
    MD5: 5cfd420acae25b35dfce108bb983f217
    SHA1: f3e4bfaea0e125727974a214899976f15381eaa6
    SHA256: d9b0e7f83ab5812bb2d79a31c7bbb365af764d76dbfca260e047179d0795c2c4
    SHA512: 83c59b2ee0228a25f33f3029c43676e36d1c2bd699aa165dc2322d0b4cd8c64dd3f9ecf7caf07cad1cb72595708942db1835cd665d1eee84a48ea0e02bfdd3fd
    RFSG 2024 Q3 Patch3.txt (661 Bytes, 下载次数: 0, 售价: 10 圆)
    2024Q3Patch3版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-4-8 20:54
