查看: 13|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q3 Patch 3 Win11 32/64bitEn NI RF信号发生器NI-RFSG25.5.3
    12 小时前
  • 签到天数: 3850 天
    连续签到: 43 天
     楼主| 发表于 2 小时前 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    NI-RFSG 2025 Q3 Patch 3
    发布日期:2025/9/21
    包含的版本:2025 Q3 Patch 3完整版,版本号25.5.3
    Windows Server 2025
    文件大小: 5598056448 字节 (5.21 GB)
    修改日期: 2026-04-08 16:07
    MD5: 06646acfa529d17ccf9a6193c8754dc4
    SHA1: 3b8f8853a07518f7088b97c1ab294f66f9c635d2
    SHA256: b0372ac54a3a3ff2f9037772c4c2f3f5f14c15e5300607a287184ecc51957fde
    SHA512: 7a1e0a4d240550224da765238e679fb5df9babc18792dc74e8da24d1bbd174bb3d99aaafcb21cca4d06f91e6bebf94f45f31b5209caf307db689edd2c82ce7de
    RFSG 2025 Q3 Patch3.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 2025 Q3 Changes
    Learn about new features, behavior changes, and other updates in NI-RFSG 2025 Q3.
    This version of NI-RFSG provides support for the following features:
    • Support for SystemLink Asset Utilization.
    • Support for PXIe-5842 VST with 54 GHz Frequency Extension (RMM-5585).
    • Support for PXIe-5563 RF Port Switch.
    NI-RFSG2025Q3版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-4-8 20:54
