查看: 430|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q3 Win11 32/64bitEng NI RF信号发生器NI-RFSG25.5.0
     楼主| 发表于 2025-8-29 10:29:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    NI-RFSG 2025 Q3
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    文件大小: 5597257728 字节 (5.21 GB)
    修改日期: 2025-07-22 15:42
    MD5: 73f421ae7fd6f9debed57b87a5e1ab55
    SHA1: 5099dede58e411a8cd84d56de01035e769323867
    SHA256: 75e9a2b20c2729effd9698d9fde65393210e8ff4015e5a6a0ae6f9e6762a3749
    CRC32: 0155a558
    RFSG2025Q3.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG2025Q3版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:21
