查看: 841|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q2 Patch 1 Win11 32/64bitEng NI RF信号发生器NI-RFSG25.3.1
     楼主| 发表于 2025-5-20 09:12:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2025 Q2 Patch 1
    发布日期:2025/4/10
    包含的版本:2025 Q2Patch1完整版,版本号25.3.1
    Windows Server 2025
    文件大小: 4983744512 字节 (4.64 GB)
    修改日期: 2025-05-13 09:16
    MD5: c34e9d1dba36f6b5d2015429c40c6192
    SHA1: 539e5fe55e2846359c34a7e819773bcd1fb9b74a
    SHA256: 16ef336cdfaec9ea21c00a9bdc3168c395627cec425a3a8498882936878bb9e6
    CRC32: 258d603c
    RFSG2025Q2Patch1.txt (518 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG2025Q2Patch1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    • Support for LabVIEW 2023 Q1
    • 4 GB RAM*
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    Document
    Format
    Description
    • Hardware device overviews
    Document
    Format
    Description
    GMT+8, 2026-1-13 09:39
