查看: 5533|回复: 0
[LabVIEW] NI LabVIEW 2018 SP1 Full Linux64Eng LV2018SP1Linux系统完整版下载
    13 小时前
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2021-5-14 17:52:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    本文件为ISO文件,集成了LabVIEW2018SP1 Pro Linux 完整版,可在Linux系统中安装使用(使用范围参考下面的Readme)。完整版和专业版比较,少了应用生成功能、VI分析器等功能,具体请查看自述文件。
    LabVIEW 2018 SP1 Linux完整版
    发布日期:2018/12/3
    CentOS
    Scientific Linux
    RedHat
    openSUSE
    语言:英文
    文件名: 2018SP1LV-LinuxFull.iso
    文件大小: 1092052992 字节 (1.02 GB)
    修改日期: 2023-03-09 11:54
    MD5: 03052a91562680a0b112701f7e4bf7cf
    SHA1: 44b7c9ceea11f5739349d28c0b38d20d38944488
    SHA256: 2a0ad9f2f327f06564ac0d91ac4f35198a512259b9562ee6669938ef8ff71a7c
    CRC32: 0783165a
    请注册视觉论坛会员登录后购买附件下载查看
    LV2018SP1Linux Full.txt (397 Bytes, 下载次数: 1, 售价: 80 圆)
    LabVIEW 2018 Service Pack 1 Media Readme for macOS/Linux
    September 2018
    With the LabVIEW media for macOS/Linux, one installation gives you access to the LabVIEW Development System and nearly all the LabVIEW for macOS/Linux modules and toolkits. This file contains important information about the LabVIEW 2018 Service Pack 1 (SP1) media for macOS/Linux, including supported operating systems and installation instructions.
    Products Included on the LabVIEW Media for macOS/Linux
    You can run the LabVIEW for macOS/Linux installer on the following operating systems:
    • (macOS) macOS 10.12 or 10.13
    • (Linux)
      • openSUSE LEAP 15.0
      • openSUSE LEAP 42.2
      • openSUSE LEAP 42.3
      • Red Hat Enterprise Linux Desktop + Workstation 6.x
      • Red Hat Enterprise Linux Desktop + Workstation 7.x
      • CentOS 7
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2018 SP1.
    The LabVIEW media for macOS/Linux includes the following products. You can refer to the readme for each product in the Product ReadMes directory for information including system requirements, known issues, and bug fixes.
    • LabVIEW Full and Professional Development Systems
    • MathScript RT Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    2 The MathScript RT Module does not support the libraries class of MathScript RT Module functions.
    3 The VI Analyzer Toolkit and Application Builder install with the LabVIEW Professional Development System. For the LabVIEW Full Development System, you can purchase and install the VI Analyzer Toolkit and Application Builder with their own separate media. Follow the installation instructions in this readme to install these products.
    You can install your LabVIEW products—including the modules and toolkits—using the LabVIEW 2018 SP1 media for macOS/Linux.
    To request additional LabVIEW media, refer to the NI website.
    Installing the LabVIEW Development System
    Complete the following steps to install the LabVIEW Development System.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW2018SP1-Pro.dmg located under the LabVIEW/macOS directory.
    • Select Continue to run a program to determine if the LabVIEW Development System can be installed on your system.
    • Follow the instructions that appear on the screen to install LabVIEW.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount lv2018SP1pro-linux.iso located under the LabVIEW/Linux directory.
      • Create the directory which is the mount point:
        # mkdir -p /mnt/lv2018SP1
      • Use the following mount command to mount the ISO file:
        # mount -o loop <path to lv2018SP1full-linux.iso or lv2018SP1pro-linux.iso> /mnt/lv2018SP1
      • Change the directory to list files stored in the ISO image:
        # cd /mnt/lv2018SP1
    • On the mounted media, to run the installation script, enter the following command:
      sh ./UNINSTALL
    Installing the Control Design and Simulation Module
    Complete the following steps to install the Control Design and Simulation Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/Control Design and Simulation directory.
    • Open macOS directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Installation Type screen.
    • In the Installation Type screen, select Change Install Location to select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the installation location, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount CD&Sim2018.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the Control Design and Simulation Module installer in the Linux directory.
      sh ./UNINSTALL
    Installing the MathScript RT Module
    Complete the following steps to install the MathScript RT Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/MathScript RT directory.
    • Select Continue to run a program to determine if the MathScript RT Module can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount MathScript2018.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the MathScript RT Module installer in the Linux directory.
      sh ./UNINSTALL
    Installing the VI Analyzer Toolkit
    The VI Analyzer Toolkit installs with the LabVIEW Professional Development System. Refer to the Installing the LabVIEW Development System section to install the LabVIEW Professional Development System.
    If you use the LabVIEW Full Development System, refer to the LabVIEW VI Analyzer Toolkit Readme to install the VI Analyzer Toolkit.
    Installing the Application Builder
    The Application Builder installs with the LabVIEW Professional Development System. Refer to the Installing the LabVIEW Development System section to install the LabVIEW Professional Development System.
    If you use the LabVIEW Full Development System, complete the following steps to install the Application Builder.
    (macOS)
    • Insert the LabVIEW Application Builder media and open macOS directory.
    • Select Continue to run a program to determine if the Application Builder can be installed on your system.
    (Linux)
    • Insert the LabVIEW Application Builder media. Mount Linux directory. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
      sh ./UNINSTALL
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    © 2018 National Instruments. All rights reserved.
    GMT+8, 2026-4-18 23:14
