查看: 3802|回复: 0
[LabVIEW] NI LabVIEW 2018 Full Linux64Eng LV2018Linux系统完整版下载
  • 签到天数: 211 天
    发表于 2020-2-23 00:42:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW2018Full Linux完整版,可在Linux系统中安装使用(使用范围参考下面的Readme)。完整版和专业版比较,会少应用生成功能、VI分析器等功能,具体请查看自述文件。
    LabVIEW 2018 Linux完整版
    发布日期:2018/5/21
    CentOS
    openSUSE
    Scientific Linux
    RedHat
    语言:英文
    文件名: 2018LV-LinuxFull.iso
    文件大小: 1090344960 字节 (1.02 GB)
    修改日期: 2023-03-09 12:19
    MD5: c5b66461a520c40b9f06fcb78398747e
    SHA1: e1bfc9ba9cc45c6242da454dbacf70e19800adfd
    SHA256: 1290e16441e52672d228ad7b796760348751f67bd69b7fe1932d8e54f0a7747a
    CRC32: c13c8b23
    请注册视觉论坛会员登录后购买附件下载查看
    LV2018LinuxFull.txt (390 Bytes, 下载次数: 93, 售价: 80 圆)
    LabVIEW 2018 Readme for GNU/Linux
    March 2018
    This file contains important information about LabVIEW 2018 for Linux, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2018.
    Supported Drivers
    Additions to the LabVIEW Help
    LabVIEW 2018 for Linux has the following requirements:
    LinuxRun-Time EngineDevelopment Environment
    openSUSE LEAP 42.2
    openSUSE LEAP 42.3
    Red Hat Enterprise Linux Desktop + Workstation 6.x
    Red Hat Enterprise Linux Desktop + Workstation 7.x
    CentOS 7
    Note
    • LabVIEW 2018 for Linux is available only in 64-bit.
    • LabVIEW and LabVIEW Run-Time Engine require 64-bit processors which support SSE2 instructions.
    Are you installing LabVIEW for the first time? Insert and mount the LabVIEW installation media. As the root user in the mounted directory, enter sh ./INSTALL to install LabVIEW in the /usr/local directory.
    To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2018.
    LabVIEW 2018 for Linux supports the following modules and toolkits.
    • MathScript RT Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    2 The MathScript RT Module does not support the libraries class of MathScript RT Module functions.
    Supported Drivers
    Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2018, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2018.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2018. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    457851Bundling class data is slower than bundling cluster data.
    536763Pop-up menus can appear only limited number of times before LabVIEW crashes.
    630227LabVIEW incorrectly allows dropping a shared variable into a cluster.
    631802Exporting typedef array of numerics to Excel may crash LabVIEW.
    639000LabVIEW crashes when updating the radix of a numeric control on an Actor Core VI that is running.
    643107Changing the line styles of multiple plots does not work as expecting in XY graphs.
    645059Uninitialized shift registers may cause incorrect type propagation.
    648582Cannot create Express VIs in certain localized versions of LabVIEW.
    658587Rescripting a message for an actor on a Linux RT target results in error 7.
    664649Accessing a DVR and deleting its reference in parallel can, in certain circumstances, cause LabVIEW to crash.
    666823VIs that use channel wires are broken when built into a packed project library.
    670440When dynamically registering events, LabVIEW may behave unexpectedly if an event is fired and unregistered before it is processed.
    671753The LabVIEW Application Builder has the potential to hang when building malleable VIs with subarray or substring inputs.
    672120Malleable VIs may not properly break after you rename a class method that the mallable VI calls when performing class substitution.
    678973Tools»Synchronize with ni.com Icon Library fails in the LabVIEW Icon Editor.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2018.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • The Python functions use the new PythonSessionRefnum refnum. This refnum is added to the enum type control at labview\vi.lib\Utility\Data Type\Type Definitions\Refnum Type.ctl. If you use VI Scripting that checks this type control, you must update your code to handle the new refnum.
    © 2004–2018 National Instruments. All rights reserved.
    374718J-01
    GMT+8, 2026-4-18 21:35
