查看: 6343|回复: 2
[LabVIEW] NI LabVIEW 2019 Pro Linux64Eng LV2019Linux系统专业版下载
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2020-2-21 21:26:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW2019 Linux Pro专业版。专业版与完整版比较,多了出应用生成等功能,具体请查看自述文件。
    LabVIEW 2019 Linux专业版
    发布日期:2019-5-17
    CentOS 7
    Red Hat Enterprise Linux 7
    openSUSE Leap 42.3
    语言:英文
    文件名: 2019LV-LinuxPro.iso
    文件大小: 1135106048 字节 (1.06 GB)
    修改日期: 2023-03-09 11:48
    MD5: af446003a38250e76ff7234a39251732
    SHA1: e8228651ef84d135e089d78bf69a0a73f378fdc2
    SHA256: ce7fe4df1e032dabd968e3d5d29709f2aa8b66a9fabf3ef8ed98e9ff62fa65b8
    CRC32: 11c12162
    请注册视觉论坛会员登录后购买附件下载查看
    LV2019Linux Pro.txt (388 Bytes, 下载次数: 83, 售价: 100 圆)
    LabVIEW 2019 Media Readme for macOS/Linux
    April 2019
    With the LabVIEW media for macOS/Linux, one installation gives you access to the LabVIEW Development System and nearly all the LabVIEW for macOS/Linux modules and toolkits. This file contains important information about the LabVIEW 2019 media for macOS/Linux, including supported operating systems and installation instructions.
    Products Included on the LabVIEW Media for macOS/Linux
    You can run the LabVIEW for macOS/Linux installer on the following operating systems:
    • (macOS) macOS 10.13 or 10.14
    • (Linux)
      • openSUSE LEAP 15.0
      • openSUSE LEAP 42.3
      • Red Hat Enterprise Linux 7.x
      • Red Hat Enterprise Linux 8.x
      • CentOS 7
      • CentOS 8
    The LabVIEW media for macOS/Linux includes the following products. You can refer to the readme for each product in the Product ReadMes directory for information including system requirements, known issues, and bug fixes.
    • LabVIEW Full and Professional Development Systems
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    3 The VI Analyzer Toolkit and Application Builder install with the LabVIEW Professional Development System.
    You can install your LabVIEW products—including the modules and toolkits—using the LabVIEW 2019 media for macOS/Linux.
    To request additional LabVIEW media, refer to the NI website.
    Installing the LabVIEW Development System
    Complete the following steps to install the LabVIEW Development System.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW2019-Pro.dmg located under the LabVIEW/macOS directory.
    • Select Continue to run a program to determine if the LabVIEW Development System can be installed on your system.
    • Follow the instructions that appear on the screen to install LabVIEW.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount lv2019pro-linux.iso located under the LabVIEW/Linux directory.
      • Create the directory which is the mount point:
        # mkdir -p /mnt/lv2019
      • Use the following mount command to mount the ISO file:
        # mount -o loop <path to lv2019full-linux.iso or lv2019pro-linux.iso> /mnt/lv2019
      • Change the directory to list files stored in the ISO image:
        # cd /mnt/lv2019
    • On the mounted media, to run the installation script, enter the following command:
      sh ./UNINSTALL
    Installing the Control Design and Simulation Module
    Complete the following steps to install the Control Design and Simulation Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/Control Design and Simulation directory.
    • Open macOS directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Installation Type screen.
    • In the Installation Type screen, select Change Install Location to select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the installation location, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount CD&Sim2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the Control Design and Simulation Module installer in the Linux directory.
      sh ./UNINSTALL
    Installing the MathScript Module
    Complete the following steps to install the MathScript Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/MathScript RT directory.
    • Select Continue to run a program to determine if the MathScript Module can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount MathScript2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the MathScript Module installer in the Linux directory.
      sh ./UNINSTALL
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    © 2017–2019 National Instruments. All rights reserved.
    发表于 2020-4-17 23:41:22 | 显示全部楼层 来自:江苏省扬州市 电信
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
     楼主| 发表于 2020-4-17 23:43:55 | 显示全部楼层 来自:广东省东莞市 联通
    在以下帖子中扫码付款,付款时备注你的论坛账号,或者是付款后及时联系客服充值,充值完成后,自行购买附件或主题。
    机器视觉论坛充值赞助方式_黑白名单通知_行业市场|广告职位|黑白名单|通知_视觉论坛VISIONBBS_视觉之家VISIONHOME_机器视觉光源_光源控制器_工业相机_工业镜头_机器视觉方案系统_图像处理教程_石鑫华视觉网_东莞市华动智能科技有限公司
    http://visionbbs.com/thread-21377-1-1.html
    GMT+8, 2026-2-2 09:43
