查看: 5086|回复: 1
[LabVIEW] NI LabVIEW 2019 SP1 Full Linux64Eng LV2019SP1Linux系统完整版下载
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2020-2-22 14:29:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW2019SP1 Linux Full完整版。完整版与专业版比较,少了应用生成等功能,具体请查看自述文件。
    LabVIEW 2019 SP1完整版
    发布日期:19-10-29
    SUSE
    Scientific Linux
    CentOS
    RedHat
    Linux
    语言:英文
    文件名: 2019SP1LV-LinuxFull.iso
    文件大小: 1104433152 字节 (1.03 GB)
    修改日期: 2023-03-09 11:40
    MD5: 2c0cd7f010d6bc1cb7eeca70eb079bc7
    SHA1: 3a021024f8262922a1be0abe35946e5851edfa3f
    SHA256: 77fc4ed8bb6e0bf5e026ee28fd5eae7d9bf6f0d7e402f89d0ae19cb1507c271a
    CRC32: fec90251
    请注册视觉论坛会员登录后购买附件下载查看
    LV2019SP1Linux Full.txt (393 Bytes, 下载次数: 91, 售价: 80 圆)
    LabVIEW 2019 Service Pack 1 Media Readme for macOS/Linux
    September 2019
    With the LabVIEW media for macOS/Linux, one installation gives you access to the LabVIEW Development System and nearly all the LabVIEW for macOS/Linux modules and toolkits. This file contains important information about the LabVIEW 2019 Service Pack 1 (SP1) media for macOS/Linux, including supported operating systems and installation instructions.
    Products Included on the LabVIEW Media for macOS/Linux
    You can run the LabVIEW for macOS/Linux installer on the following operating systems:
    • (macOS) macOS 10.13 or 10.14
    • (Linux)
      • openSUSE LEAP 15.0
      • openSUSE LEAP 42.3
      • Red Hat Enterprise Linux 7.x
      • Red Hat Enterprise Linux 8.x
      • CentOS 7
      • CentOS 8
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2019 SP1.
    The LabVIEW media for macOS/Linux includes the following products. You can refer to the readme for each product in the Product ReadMes directory for information including system requirements, known issues, and bug fixes.
    • LabVIEW Full and Professional Development Systems
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    3 The VI Analyzer Toolkit and Application Builder install with the LabVIEW Professional Development System.
    You can install your LabVIEW products—including the modules and toolkits—using the LabVIEW 2019 SP1 media for macOS/Linux.
    To request additional LabVIEW media, refer to the NI website.
    Installing the LabVIEW Development System
    Complete the following steps to install the LabVIEW Development System.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW2019SP1-Pro.dmg located under the LabVIEW/macOS directory.
    • Select Continue to run a program to determine if the LabVIEW Development System can be installed on your system.
    • Follow the instructions that appear on the screen to install LabVIEW.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount lv2019proSP1-linux.iso located under the LabVIEW/Linux directory.
      • Create the directory which is the mount point:
        # mkdir -p /mnt/lv2019SP1
      • Use the following mount command to mount the ISO file:
        # mount -o loop <path to lv2019SP1full-linux.iso or lv2019SP1pro-linux.iso> /mnt/lv2019SP1
      • Change the directory to list files stored in the ISO image:
        # cd /mnt/lv2019SP1
    • On the mounted media, to run the installation script, enter the following command:
      sh ./UNINSTALL
    Installing the Control Design and Simulation Module
    Complete the following steps to install the Control Design and Simulation Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/Control Design and Simulation directory.
    • Open macOS directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Installation Type screen.
    • In the Installation Type screen, select Change Install Location to select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the installation location, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount CD&Sim2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the Control Design and Simulation Module installer in the Linux directory.
      sh ./UNINSTALL
    Installing the MathScript Module
    Complete the following steps to install the MathScript Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/MathScript RT directory.
    • Select Continue to run a program to determine if the MathScript Module can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount MathScript2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the MathScript Module installer in the Linux directory.
      sh ./UNINSTALL
    Back to Top
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    © 2017–2019 National Instruments. All rights reserved.
  • 签到天数: 6 天
    发表于 2020-8-11 14:34:33 | 显示全部楼层 来自:陕西省西安市 电信
    GMT+8, 2026-2-2 09:43
