查看: 4558|回复: 0
[LabVIEW] NI LabVIEW 2017 SP1 Pro Linux64Eng LV2017SP1Linux系统专业版下载
    昨天 09:50
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2020-2-20 21:17:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW 2017 SP1 Pro Linux专业版,可在Linux系统中安装使用(使用范围参考下面的Readme)。专业版和完整版比较,多了应用生成功能、VI分析器等功能,具体请查看自述文件。
    LabVIEW 2017 SP1 Linux专业版
    发布日期:2018/1/23
    CentOS
    openSUSE
    Scientific Linux
    RedHat
    语言:英文
    文件名: 2017SP1LV-LinuxPRO.iso
    文件大小: 1806587904 字节 (1.68 GB)
    修改日期: 2023-03-09 12:31
    MD5: 2e84957854deb3ce31f3fb7738094e3a
    SHA1: 56f4dc93345bd667ef640f18b0f0212c8799ace7
    SHA256: 3552dbac9c1a5c310d7323ba48a59442ea09c28c5bc644f9080e78938d205544
    CRC32: ee3413a2
    请注册视觉论坛会员登录后购买附件下载查看
    LV2017SP1Linux Pro.txt (392 Bytes, 下载次数: 63, 售价: 100 圆)
    LabVIEW 2017 Service Pack 1 Media Readme for macOS/Linux
    September 2017
    With the LabVIEW media for macOS/Linux, one installation gives you access to the LabVIEW Development System and nearly all the LabVIEW for macOS/Linux modules and toolkits. This file contains important information about the LabVIEW 2017 Service Pack 1 (SP1) media for macOS/Linux, including supported operating systems and installation instructions.
    Products Included on the LabVIEW Media for macOS/Linux
    You can run the LabVIEW for macOS/Linux installer on the following operating systems:
    • (macOS) macOS 10.11, 10.12, or 10.13
    • (Linux)
      • openSUSE LEAP 42.1
      • openSUSE LEAP 42.2
      • Red Hat Enterprise Linux Desktop + Workstation 6.x
      • Red Hat Enterprise Linux Desktop + Workstation 7.x
      • Scientific Linux 6.x
      • CentOS 7
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017 SP1.
    The following products are included on the LabVIEW media for macOS/Linux. You can refer to the readme for each product in the Product ReadMes directory for information including system requirements, known issues, and bug fixes.
    • LabVIEW Full and Professional Development Systems
    • VI Analyzer Toolkit2
    • Application Builder2
    2 The VI Analyzer Toolkit and Application Builder install with the LabVIEW Professional Development System. For LabVIEW Full Development System, follow the installation instructions in this readme to install the VI Analyzer Toolkit and Application Builder.
    You can install all of your LabVIEW products—including the modules and toolkits—using the LabVIEW 2017 SP1 media for macOS/Linux.
    To request additional LabVIEW media, refer to the NI website.
    Installing the LabVIEW Development System
    Complete the following steps to install the LabVIEW Development System.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW2017SP1-Pro.dmg located under the LabVIEW/macOS subdirectory.
    • Select Continue to run a program to determine if the LabVIEW Development System can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Destination Select screen.
    • In the Destination Select screen, select the location to install LabVIEW.
    • After you select the destination directory, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount lv2017sp1pro-linux.iso located under the LabVIEW/Linux subdirectory.
      • Create the directory which is the mount point:
        # mkdir -p /mnt/lv2017sp1
      • Use the following mount command to mount the ISO file:
        # mount -o loop <path to lv2017sp1full-linux.iso or lv2017sp1pro-linux.iso> /mnt/lv2017sp1
      • Change the directory to list files stored in the ISO image:
        # cd /mnt/lv2017sp1
    • On the mounted media, to run the installation script, enter the following command:
      sh ./UNINSTALL
    Installing the Control Design and Simulation Module
    Complete the following steps to install the Control Design and Simulation Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/Control Design and Simulation directory.
    • Open Mac OS X subdirectory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • In the Destination Select screen, you must select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount CD&Sim2017.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the Control Design and Simulation Module installer in the following directories:
      Linux_64-bit
      sh ./UNINSTALL
    Installing the VI Analyzer Toolkit
    The VI Analyzer Toolkit installs with the LabVIEW Professional Development System. Refer to the Installing the LabVIEW Development System section to install the LabVIEW Professional Development System.
    If you use the LabVIEW Full Development System, complete the following steps to install the VI Analyzer Toolkit.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/VI Analyzer directory.
    • Select Continue to run a program to determine if the VI Analyzer Toolkit can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount VIA2017.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the VI Analyzer Toolkit installer in the following directories:
      Linux_64-bit
      sh ./UNINSTALL
    Installing the Application Builder
    The Application Builder installs with the LabVIEW Professional Development System. Refer to the Installing the LabVIEW Development System section to install the LabVIEW Professional Development System.
    If you use the LabVIEW Full Development System, complete the following steps to install the Application Builder.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW Add-ons/Application Builder/macOS subdirectory.
    • Select Continue to run a program to determine if the Application Builder can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount LabVIEW Add-ons/Application Builder/Linux subdirectory. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
      sh ./UNINSTALL
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    © 2017 National Instruments. All rights reserved.
    GMT+8, 2026-4-19 01:00
