查看: 7401|回复: 1
[LV工具模块] LabVIEW 8.6 Internet Toolkit 6.0.2 Win32Eng LabVIEW8.6网络工具包6.0.2下载
    3 小时前
  • 签到天数: 3860 天
    连续签到: 53 天
    发表于 2013-4-6 15:39:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Internet工具包可用于将internet功能整合至VI,实现基于Telnet协议的数据收发、从FTP服务器上传或下载文件、向Web发布VI、以及通过Web浏览器对VI进行远程控制。
    校验和
    修改日期: 2019-01-05 12:32
    MD5: f5ca5ce7f1b905f42099ba6d9833b3b2
    SHA1: a6bdb10150197511af3fce9a46e53545af410230
    SHA256: 6e308008d580acffb0ce36c13d7ff57864cde78338d3134ca73ab7df7cf68674
    CRC32: 431a9ac1
    LVITK6.0.2.txt (478 Bytes, 下载次数: 2, 售价: 10 圆)
    或从LV8.6平台DVD安装:
    LV8.6平台DVD,报表生成和数据库连接-Internet工具包
    NI Software Platform Bundle-X86-zh-cn_8.6_suite NI SPB8.6 32位简体中文版下载,即NI软件平台套件8.6版
    http://visionbbs.com/thread-24683-1-1.html
    LabVIEW Internet Toolkit 6.0.2 Readme
    June 2008
    This file contains the following information about the LabVIEW Internet Toolkit 6.0.2.
    Installation
       Version 6.0.2 for LabVIEW 8.6
            Windows Vista/XP/2000
            Mac OS X
            Linux
       Version 6.0.1 for LabVIEW 7.x—8.5
            Mac OS X
            Linux
    InstallationVersion 6.0.2 for LabVIEW 8.6
    Internet Toolkit 6.0.2 is compatible with LabVIEW 8.6. If you want to use Internet Toolkit with an older version of LabVIEW, you must install Internet Toolkit 6.0.1.
    Before installing the LabVIEW Internet Toolkit 6.0.2, uninstall any previous versions of the Internet Toolkit from the computer.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    (Windows Vista/XP/2000) You can install all of your LabVIEW products—including LabVIEW and the Internet Toolkit—using the LabVIEW 8.6 Platform DVDs. Refer to the LabVIEW Release Notes, which are available in your LabVIEW box, for information about the LabVIEW Platform DVDs.
    Complete the following steps to install the LabVIEW Internet Toolkit 6.0.2 for Windows from the Internet Toolkit installation CD.
    • Insert the LabVIEW Internet Toolkit 6.0.2 installation CD and follow the instructions that appear on the screen.
    • Activate the Internet Toolkit using the NI License Manager.
    (Mac OS X) If a previous version of the LabVIEW Internet Toolkit exists on the machine, complete the following steps to uninstall the previous version before you install Internet Toolkit 6.0.2.
    • Navigate to the LabVIEW directory and drag the Internet_Toolkit_Uninstall.sh uninstallation script to the prompt in a Terminal Window. Press Return and follow the instructions provided by the script.
    • After uninstalling the Internet Toolkit, you must manually delete the uninstallation script.
    Complete the following steps to install the LabVIEW Internet Toolkit 6.0.2 for Mac OS X from the Internet Toolkit installation CD.
    • Insert and browse to the LabVIEW Internet Toolkit 6.0.2 installation CD and open Internet_Toolkit6.0.2.pkg located under the LabVIEW_8.6\Mac OS X directory.
    • Select Continue to run a program to determine if the Internet Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click the Choose button and select the version of LabVIEW (8.6) to which you want to install the Internet Toolkit.
    Note  You must click the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click the Continue button to complete the installation.
    • (Optional) Mass compile the Internet Toolkit VIs. When you open a VI last saved in a previous version of LabVIEW, LabVIEW automatically converts and compiles the VI. You must save the VI in the current version of LabVIEW or the conversion process, which uses extra memory resources, occurs every time you access the VI. Because the Internet Toolkit supports multiple versions of LabVIEW, you might need to mass compile after you install.
      • Launch LabVIEW and select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
      • Navigate to the labview\vi.lib\addons\internet directory and click the Mass Compile button to mass compile the Internet Toolkit VIs.
    (Linux) Complete the following steps to install the Internet Toolkit 6.0.2 for Linux from the Internet Toolkit installation CD.
    • Use mount /mnt/cdrom to mount the CD. On some systems, the CD is mounted automatically.
    • Enter the following command to navigate to the LabVIEW directory:
      cd /usr/local/natinst/labview
      where labview is the version of LabVIEW to which you are installing the Internet Toolkit, such as lv86.
    • Enter the following command to extract the toolkit to the LabVIEW folder:
      tar xf /mnt/cdrom/Linux/InternetToolkitLinux.tar
    • Enter the following command to navigate to the Example Finder directory:
      cd /usr/local/natinst/share/example finder/1.0/Products/labview/x.y/exbins/english
      where x.y is the version of LabVIEW to which you are installing the Internet Toolkit, such as 8.6.
    • Enter the following command to copy the toolkit example information to the Example Finder:
      cp /mnt/cdrom/Linux/lvexint.bin4 .
    Version 6.0.1 for LabVIEW 7.x–8.5
    You must install Internet Toolkit 6.0.1 to work with LabVIEW 7.x, 8.0, 8.2, or 8.5.
    (Windows Vista/XP/2000) Complete the following steps to install the Internet Toolkit 6.0.1 for Windows from the Internet Toolkit installation CD.
    • Insert the LabVIEW Internet Toolkit 6.0.2 installation CD and browse to the LabVIEW_7.x-8.5\Windows directory.
    • Double-click setup.exe and follow the instructions that appear on the screen.
    (Mac OS X) If a previous version of the LabVIEW Internet Toolkit exists on the machine, complete the following steps to uninstall the previous version before you install Internet Toolkit 6.0.1.
    Complete the following steps to install the Internet Toolkit 6.0.1 for Mac OS X from the Internet Toolkit installation CD.
    • Insert and browse to the LabVIEW Internet Toolkit 6.0.1 installation CD and open Internet_Toolkit6.0.1.pkg located under the LabVIEW_7.x-8.5\Mac OS X directory.
    • In the Select Destination dialog box, click the Choose button and select the version of LabVIEW (7.x or later) to which you want to install the Internet Toolkit.
    • After you select the destination directory, click Continue to complete the installation.
    (Linux) Complete the following steps to install the Internet Toolkit 6.0.1 for Linux from the Internet Toolkit installation CD.
      cd /usr/local/natinst/LabVIEW-8.0
    Note  The preceding command assumes that you installed LabVIEW 8.0. Modify the version if you installed a different version of LabVIEW.
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/InternetToolkit6_0_1Linux.tar
      cd "/usr/local/natinst/share/example finder/1.0"
    • Enter the following command to extract the Example Finder files:
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/InternetToolkit6_0_1ExFndrLinux.tar
    The Internet Toolkit VIs Help contains reference information about the Internet Toolkit.
    (Windows) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Search the LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits»Internet Toolkit VIs top-level topic.
    (Mac OS X, Linux) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Internet Toolkit to launch the Internet Toolkit VIs Help.
    Refer to the labview\examples\internet directory for example VIs that demonstrate common tasks using the Internet Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»Internet in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The LabVIEW Internet Toolkit 6.0.2 includes the following known issues:
    • The Internet Toolkit includes the G Web Server for backward compatibility. National Instruments recommends you use the LabVIEW Web Server to run VIs on the Web.
    • The G Web Server no longer can share a port with the LabVIEW Web Server. If you have applications that include both Internet Toolkit CGI VIs and LabVIEW remote panels, the VIs and the remote panels cannot be on the same port. You must reimplement the CGI VIs using the LabVIEW Import Web Service wizard.
    © 1999–2008 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    发表于 2013-4-7 19:23:35 | 显示全部楼层 来自:广西桂林市 电信
    GMT+8, 2026-4-18 13:34
