查看: 9707|回复: 0
[LabVIEW] NI LabVIEW 8.6 Win32Eng LV8.6 32位英文版下载
    4 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
    发表于 2019-1-17 10:56:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW可提供简单易用的交互式图形化编程软件,同时适用于工程设计和科学研究。 LabVIEW能从数千种仪器以及数据采集和测量设备上快速获取数据,各种交互式向导和500多个内置的LabVIEW测量分析和信号处理函数可用于抽取用户数据的有用信息,并将结果以图形化方式显示在自定义用户界面、图形图表以及报表中。
    NI官方已经不再提供下载,本下载为石鑫华视觉网/机器视觉论坛专供。收取一定的费用用于论坛日常维护。感谢您的支持与理解。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 购买附件下载查看
    LV8.6ENG.txt (89 Bytes, 下载次数: 47, 售价: 50 圆)
    LabVIEW 8.6 Readme for Windows
    June 2008
    This file contains important last-minute information about LabVIEW 8.6 for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed in the current version of LabVIEW, and changes from LabVIEW 8.5.x. Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and for a complete list of new features in LabVIEW 8.6. Refer to the LabVIEW Release Notes for installation instructions. After you install LabVIEW, you can access both of these documents by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Technical Support and Professional Services book.
    You also can refer to the National Instruments Web site for more information about additional issues you may encounter upgrading from LabVIEW 8.5.x.
    Refer to the National Instruments Web site for the latest information about LabVIEW 8.6.
    Refer to the labview\readme directory for readme files about LabVIEW add-ons, including modules and toolkits.
    Supported Platforms
    Installing Another Language Version
    Installing LabVIEW Silently
    Licensing
    Additions to the LabVIEW Help
    Documentation Corrections
    Supported Platforms
    LabVIEW supports Windows Vista/XP/2000. LabVIEW does not support Windows NT/Me/98/95, any of the Windows Server editions, or Windows XP x64. LabVIEW does support Windows Vista x64.
    Refer to the LabVIEW Release Notes for a complete list of system requirements.
    If you have another language version of LabVIEW 8.6 installed on your computer, uninstall that version before installing the new language version.
    You can install LabVIEW without viewing any installation dialog boxes. Refer to the National Instruments Web site for more information about installing LabVIEW silently.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate LabVIEW, use the serial number you received as part of your installation package.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the known issues in LabVIEW 8.6 online. Refer to the National Instruments Web site for a complete, up-to-date listing of known issues in LabVIEW 8.6.
    • Click the Update button in the Preview Pane of the LabVIEW MathScript Window to synchronize the value of the data type you select from the Display Type pull-down menu with the rest of MathScript. If you change the value of the data type in the Preview Pane, click the Update button to publish the new value to the rest of MathScript. If you do not change the value of the data type in the Preview Pane, click the Update button to refresh the data type with the latest value from the rest of MathScript.
    • The quad MathScript function is not supported in the LabVIEW Run-Time Engine. You cannot use this function in a stand-alone application or shared library.
    • If you install LabVIEW 8.6 or the latest NI Device Drivers media without upgrading to LabVIEW SignalExpress 3.0, some SignalExpress VIs brake after code generation.
    • The Wait (ms) function behaves differently on Windows and the LabVIEW Real-Time Module. On Windows, the Wait (ms) function waits up to the value specfied in the milliseconds to wait input. On the RT Module, the Wait (ms) function waits at least the value specified in the milliseconds to waitinput. The Wait (ms) function has a margin of error of plus or minus one millisecond.
    • The LabVIEW Fundamentals manual and the Getting Started with LabVIEW manual did not change for LabVIEW 8.6. Therefore, the content might not reflect changes made in LabVIEW 8.6. Refer to the LabVIEW Help for the most updated information.
    • To reset security settings for the NI Distributed System Manager, remove the Application Data directory.
    The following items are the IDs and titles of a subset of issues fixed between LabVIEW 8.5.1 and LabVIEW 8.6. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of LabVIEW.
    IDLegacy IDFixed Issue
    115277-XY Graph area expands in X direction by changing Y scale range
    113915-LabVIEW crashes when using Insert Into Array to insert two arrays into a 2D array
    113881-Creating a DAQmx task from a LabVIEW project crashes LabVIEW
    112820-File tab on project takes a long time to load when source code control is enabled
    112733-LabVIEW Import Shared Library Wizard Hangs when importing .dll created from an .m file
    112554-Setting HideText to FALSE Hides Selected Text
    112477-VI does not appear to be broken when type-def gets altered
    111886-Mixed signal Graph will not autoscale plot 1
    110616-VI Server method "Run VI" has strange behavior if callee VI is reentrant
    110597-Relative Time Stamp function doesn't work properly in LabVIEW 8.5.1
    109951-Problem in complex version of FIR Narrowband Filter VI
    109768-Project with auto-populate folder prompts for save even if no changes are made
    109751-Show constant folding option changes outputs in for loop executing 0 times
    109710-Case structure doesn't work with DBL data type
    109709-Suspend mode can stomp on caller data
    109589-Search Ordered Table returns Inf when searching past bounds
    108699-Error 0 Occured at Project Property Node in LabVIEW 8.5 & 8.5.1
    108413-Compiling customer VI in 8.5.1 drastically increases execution time
    107937-Calling a subVI that calls a subVI with Database Access enabled crashes LabVIEW
    107924-Auto-populating folder allows drag-drop from explorer
    107352-Zip builder fails with error 7 when including application or shared library build spec outputs
    106982-LVOOP Type Propagation problem
    106945-LabVIEW 8.5.1 installer removes some earlier version registry keys, breaking some compatibility
    106299-LabVIEW Class Browser creates incorrect DAQmx System and Device property nodes
    105907-VI Properties does not properly list reason why VI cannot be unlocked
    105629-Convert Panel To Screen Coordinates method not usable while running
    105336-Using ActiveX controls with the create document option crashes LabVIEW
    105082-Unable to close Time Domain Math Express VI after Opening Front Panel
    105073-LabVIEW crash upon opening VI with formula node using while loop and if else statement
    104765-Read Data Express VI of the Storage Palette breaks the Main VI in the Japanese version of LabVIEW 8.5.1
    104239-Global Variable crashes LabVIEW if the controls within it are deleted
    103428-Problems with project if a VI filename contains a '/' character
    103297-Changing a Text Ring control to fixed point representation crashes LabVIEW
    103244-Opening a reference to a simple VI in a project takes 2-4 times as long if the folder containing the VI has ever been expanded
    102226-Format Into String function containing an enum input with an out of range value crashes LabVIEW
    101959-LabVIEW Crash without an error when comparing string constant to a control refnum of a sub-vi
    101838-In MathScript, getfileproperty returns error for multiple channels with identical name
    101769-Write PNG File.vi modifies input image without record
    101706-Instructions in Tools>>Options for configuring palette are unclear
    101705-MathScript exist function partially broken
    101666-MathScript exist function returns true for nonexistent variable
    101612-Setting Strings[] property allocates arrays
    101579-MathScript can't accept a fixed-size array input
    101516-Right-click on plot legend crashes Labview
    101367-VI item property can not be pasted in LabVIEW project window if copy/cut/paste library owns the VI
    100830-Multiplot Cursors on Mixed Signal Graph Follows the Tangent of the Signal
    100780-Append VI list of subVIs to report.vi; don′t create subVI icons in \temp folder
    100643-LabVIEW crashes with a called-by-reference VI dialog
    100626-Property nodes acting as if they should always ignore errors instead of jumping out early
    100519-Customized Icon Editor causes LabVIEW to hang
    100474-Property nodes do not return values when errors occur inside node in LabVIEW 8.5. but do in 8.2 and prior
    100334-LV 8.5.1 crashes when creating multiplot cursor mixed signal graph
    100090-MathScript 'end' keyword doesn't work inside RHS indexing matrix
    100002-MathScript save command only saves first variable
    99838-LabVIEW Forced to Close When Using In Place Element Structure and Deleting Replace Array Subset
    99672-LabVIEW freezes when ALT key is pressed and menu is disabled
    99515-TDMS Primitive broken in 8.6
    99392-Import DLL Wizard: Tool hangs generating files when Report Generation Toolkit installed
    99250-MathScript can't load .mat file with platform MACI
    98880-Error -1950679035 when there are concurrent Logos XT and Logos connections
    98441-Static VI reference to Dynamic VI returning invalid reference on first call
    98282-VIs in lvlibs cannot be compared using Compare VI Hierarchy Tool
    98256-Right click mouse down events are not fired on disabled controls that are in a group
    97975-Read Measurement File VI doesn't support time columns in TDMS files
    97486-Format Into String gives error "End of file encountered" for some numeric values
    97405-Ctrl+click on a locked VI does not force recompile of the VI unless the diagram is unlocked
    97367-DLL Build Time is Too High for Large Number of Exports
    96805-Libraries contain illegal characters that causes build to fail
    95901-MathScript can't delete row if matrix has more rows than columns
    95756-LabVIEW 8.5 crashes when wire a constant to input refnum of Deny Access VI function.
    95442-Calling External C Code Array Pointer with Size of 2^n Elements Returns Incorrect Results in LabVIEW 8.5
    95097-Building a DLL that has a boolean control on the conn pane results in no type information generated in the DLL
    95068-Unexpected and inconsistent results in Gaussian White Noise.vi
    94692-Histogram VI with misleading help or bad handling of 1 sample
    94690-Labview crashes when you click on an array of clusters that is updating
    94378-Quadrature VI hangs LabVIEW if tolerance <= 0
    94228-LV 8.5 crash when class and project are in the same folder
    94190-Table hangs after carriage return in cell
    93912-VI comparison doesn't report different configuration of "In Range and Coerce" node
    922984AOEJ5F2Get Panel Image and Print.VI to HTML Method Cuts Off FP/BD Images
    737484IAH4TPWCreating an override method fails if parent class VI has short wires
    736264I3AKG00MDF prompts for distribution when network installed distribution is not located.
    735994I7BCEN8Editing the icon template for my class doesn't prompt to apply that icon to all the VIs in my library if they're in folders
    733144HU92DP2Call by ref node does not update when static ref changes
    731074HK9MDHAUsing true-false selector in generated code template cause unnecessary extra copy
    727834HAEO4N8Crash opening context help window on Name Control wire when appropriate support isn't installed
    725404H88KQTDZher, zher2 cause memory leakage in bigtest on Windows
    722814GKDGTORMathScript tsearch returns incorrect result
    721754GUF2AVIReshape Array works incorrectly in loop when reshaping array larger than in a previous iteration
    719224GDGE5F2Format Into File and Scan From File Functions Cannot Be Dropped with New VI Object Function
    719204GDB6AP2SCC provider peforming unexplained server status checks under certain editing operations
    718094GD9N7SNGeneral Eigen VI returns improper result
    717394G7F3Q00Static VI Reference to an instance VI
    716994GA9HE28Multirate palette VIs should not be included in LabVIEW 8.5.1
    703864F89HEP2Control label of a control reference in a typedef instance doesn't update when typedef is changed
    703324FCD3VWBVI Hierarchy Window doesn't draw LabVIEW Class VIs correctly
    702774FD8BN7NUndo crashes Shared Clone VI
    702354FCC8K1WBroken running VI - failed to reserve dynamic VIs
    698474F67PKDXMathScript window takes too long to shut down
    698114EPCHLJ1Fix icons for three vi.lib LVClass utilities
    697604EP9D0P2LabVIEW crashes when reading IsOnConnPane scripting property on a subpanel
    697194EPFDM03PolyVIs cannot be disconnected from lvlib if lvlib is missing from the file menu of the poly vi. the option is missing
    696934EPEBUCSClass won't leave Project Dependencies
    696874EP8G6V6Save For Previous on To FXP conversion bullet yields VI that crashes Jupiter/Saturn
    696694ES8GKM3Example Finder hardware ID for 9233 is incorrect
    696074ES3A1IKOptions for Printing not as expected
    694764EM87D5PSaveForPrevious has problem with overridable terminal
    694044EN98QP2Autopopulating folder retains path when project saving for previous.
    693664ELAP9WXActiveX control could not be loaded in the attached VI
    693484EM9M120DSC Shared Variable I/O Control Cannot be Programatically Set to Empty String Constant
    693244EM9JAORdgemm returns zero matrix for input matrix of order 2048
    692424EGF7U5PIncorrect terminal name when "Adapt to source"
    692344EN8BLDPCall Library Function Node Parameter Deletion Misbehavior
    692114ELFHRTDMatrix Log should return a warning when the input matrix is singular
    690674E9E6100The VI server method ExportVIInterface is returning bad data in some cases
    689394EBCJU5IUser-Defined Functions in DLLs - First DLL build error
    689374EAFQN5INonStatic MathScript Code - VI Broken - build Error
    689184EB988NTSource palette for structures - the source pallete was not displayed for Decoration palletes
    686894E9A8DP2Error when trying to configure Seapine Surrond SCM in LabVIEW
    681254E0ECHE1Opening multiple files from an LLB does not remember corrected locations of a missing control
    680214DJBBVXECheck out prompt notification is displayed when "New VI" is created from the file menu of a project in source control
    679624DJGFK7NBinary MLS is not reentrant but contains state
    678184DJDT700Save as rename on project file causes load of all contents and search for missing items
    677934DJDQT54Libs incorrectly show up under 'items in mem'
    675864DD81IP2Extra dependent files are returned when selecting "Add to Source Control" on a project folder
    673134DGFH7A6Resampling VI crashes
    670464D9A04NTDynamic Library loading - Unable to find LoopingCalls.vi
    669854D9FRJ5PFXP values not shown when highlight execution is on
    664274CTFC3NMLogos browse items for boolean variables report them as DBL's instead
    664174CSD5D6QSquare VI does not return correct value when input is FXP
    661504CNCKJ9AVIs with lots of chained case structures can take a long time to compile
    659904CJH76F2Grown and Constant FB Config Options Are Not Compatible
    658904CKEQ1F2Erroneous problem with project with Auto-populate Folders
    658464CM7PEBDBasic Spectral Measurement.vi crashes LabVIEW when opened
    657684CM36IQEThe performance test suite does not take paths which are more than one level hierarchy
    655544CDG41MXFlatten to XML primitive doesn't work for fixed-point numerics
    653784CD88JSFMathScript request for xlim, ylim, and zlim functions
    652874C2B7U54After rename of conflict, conflict glyph still remains
    652134BU9JHBQSome Math VIs are not seen as part of libraries when doing a palette search
    651084C0EI3FF.NET - The code to display cross link warnings when assemblies have been moved changes the actual path instead of a copy
    649934BUAM4F2Breakpoints on Storage VIs Disappear when Moving from LabVIEW 8.2 to 8.5
    649384BN9PDLNMathScript plot issue; title
    648634BOD6AN8Fixed point type can't be wired to case structure selector
    647644BO7SLN8Crash casting a double with units to a fixed point number
    647594BSEJB00Closing the Dialog (using the X button) that pops up when dropping the Storage VIs Get/Set Properties freezes LabVIEW
    645584BHD7Q00Cross-context loading can give you two linkobjs with the same name
    645474BJCA7N8Default values of Set Datalog Position aren't working
    645254BH7MJN8Attempting to exit LabVIEW while the llb manager is open prompts you to abort running VIs
    644864BIB6700Can't use "Remove breakpoints from hierarchy" while running
    644844BGHLELJClosing a Project Item Reference to a VI invalidates a downstream Open VI Reference
    644234BCFMCOISource Distribution feature does not work for certain modules
    643624B9A1FBDPossible problem with Open VI Reference and autobuild/VIServer calls in LabVIEW
    643274BB6KOP2Merge dialog comes up runable in LabVIEW Full
    642714B9DO203VI under an autopopulating folder cannot be added to a library
    642654B58RS00LLB Manager can't identify top VI correctly
    642474BBEDVP2Linux merge dialog is sized badly
    642384B98E1MOCompare doesn't report properly change to the Generate Wrappers setting for Call Library Function Node
    642254B5FEMF2File/Directory Info Returns Different Values with Wired Output
    641744ARD3OV2Inserting Bundle by Name node into class wire behaves differently than cluster
    641274ARCNQCSCode Interface Node calls show up in Dependencies
    641234AQ9JNDUUnit_string should not be added to the waveform attributes when read from a tdms file
    640864AQE6OPWProblems with MathScript Probe and global variables
    640774APBPOPWYou shouldn't be able to probe MathScript nodes if debugging is turned off
    640464APEMC00Unload MathScript Compiler code is duplicated
    640124AHCM2MXNumeric Property page sets VI server properties desired min and max individually
    638414AID3TG0Delete from Disk shows "Deletion will result in missing subVI errors." even when the VI has no callers
    637234ACBHCDXMathScript complex sort() and Sort Complex Numbers VI do not sort tied magnitudes by phase angle
    635884A6AOTOUMathScript delete function not supported
    6348849TAPLOUMathScript auread function not supported
    634864A6CK400"Make top level in LLB" option does not work for project folders App Builder Source Distributions
    634634A5GK8N8Can't turn on adapt to entered data on a fixed point (or integer) constant inside a cluster
    63196493ECHK9Creating a control from the TDMS Write VI leads to a broken wire
    6303148PB7BOUMathScript stepfun function not supported
    6301048BFT8V6Crash on shutdown when Load Warnings window is open
    6299648OAL61WBrowse Relationships - "This VI's Callers" is disabled for Dynamic Dispatch VIs
    6293548GE03OUMathScript: imagesc not supported
    62656477C8NOUMathScript: 'quad' function not supported
    6206743FCOQP2Showing/Hiding pane label does not cause a doc mod
    617613ZPGE9PWCreating a variable called 'ctranspose' breaks the ' operator in MathScript
    617323ZOBGDN8Shared variable dropped from palette shows 3 errors, none of which seem ideal
    616093Y5HANMQCan't use "Remove breakpoints from hierarchy" while running
    616043Y5BTDTZComplex Bessel Functions not working correctly in MathScript
    614193VKBPS1WLabVIEW unable to create modal windows after remote debugging
    610083L4A65P2Name of Tree property "Show at Indent Level 0" does not match functionality
    609263HGADP3ZNew dialog doesn't close immediately when new shared variable created
    60785369GOA1WNavigation Window does not save maximized state when closed
    602174I6CG2VIOpen VI Ref does not show search dialog when looking for missing subVIs
    602094I4EN800Dynamic VI call in UserMessage Callback in the TestStand LabVIEW UI hangs LabVIEW
    601874I7AJ100Using the lvanlys complex IIR filter as against two real IIR filters on a CDB array is slower on some machines
    601494I49DV00Call by ref node crashes in some undo then close use cases
    600374HS4CTGBBuild Fails With Error 7 When Destination Label Matches Virtual Folder Structure.
    598824HLF9B14Using a feedback node with a sub-array input causes LabVIEW to crash
    598614HNCIEORMethod Object.FindObject return error if the output is unwired
    597124HEA1BORMathScript save can not write data into external data file
    597064HAGGKBTIncorrect value range of fxp data type
    596234H5DDLP2Boolean Array To Number should sign extend when overridden with wider output.
    596094H3D9P2NBlock node caption does not update correctly in Icon View
    595474H6HORHZQuotient and Remainder function impropertly coerces to I64 and can return incorrect value
    595464H6DTUGQLV-Built DLL's process Win32 messages during startup
    595174GKB07NQDBL -> FXP is much slower than DBL -> I32 via Calibration VIs
    594264GQA4KNOSweep chart crashes LabVIEW 8.5
    594124GGDR700Project Continually asks to save vis even after mass compile.
    593774GHB01VBGet LabVIEW Class Default Value VI - Unclosed Reference to Owning Application
    593704GI8I952LabVIEW crash when replacing graph with chart and creating cursor.
    593674GGD1EN4Array Constant scrollbar properties don't work
    593254GDE5K3AInplaceness error - cluster copy incremented
    593044GGE21RJCannot force to display trailing zeros for fixed point integer number
    592564GAFM6SFMathScript needs 'warning' function
    592474GBEB2V9Maximum error detection on CLF node causes addressing error when calling a DLL
    592444G6E5HDXMathScript error() should not return an error if input string is empty.
    592424GB6DJ0GLabVIEW 8.5 crash with scrollbar on plot legend.
    592414GB4DMQHDisconnect from type definition causes LabVIEW to crash
    592184GAED7SFMathScript 'griddata' returns incorrect results with 'cubic' setting
    592154GBAAV00VI Server Check Responsiveness method not working properly
    592034G68QQ6BLocked LabVIEW 8.2 VI's with MathScript Node have broken arrow when opened in LabVIEW 8.5
    591904G5F293AWiring not a path to a call library function node produces an error, empty or invalid path does not
    591854G4D8SD1XML Scripting does not provide references to wires
    591744G2AK900Absolute Time and Relative Time are swapped in the "Format & Precision" Property Page dialog
    591584G2E9E5DWaveform Attributes in Mixed Signal Graphs
    591534G49MR1WSquare wave off by one point on linux
    590764FQ967QHWrite to single-process shared variable alters error message
    590744FS8Q3HACompare ability need to pass in the object refs for comparison
    590604FS84507Dependencies show in Project - Files tab view, even when they are deselected
    590514FQ3RJ00Project moving files on disk loading crashes LabVIEW
    590454FJC8JSNResample returns same result with different anti-aliasing filter setting
    590144FGDAS00Adding a class to a library and saving the library doesn't prompt for saving the class
    590064FF1BL00LabVIEW class control update
    590004FEE09U4Project shows incorrect dependencies
    589904FJA4UAPFind VIs on Disk will find but cannot open classes
    589894FJA3IAPGetting Started Window may not show proper conflict resolution dialogs
    589644FI1M6IZWhen a frame decoration is in front of controls, CPU usage increases
    589504FE4DE7UInconsistent 1077 errors when plotting data on a Waveform Graph in a SubVI
    589384FBCICNKCall Library Function with String arg and Minimum Size causes incorrect String
    589344FDI8JXERun (provider) client menu item is not enabled in Tools>>Source Control
    589324FD9PU5IPrinting Page UI Testing - Unable to find "Standard Printing" and "Bitmap Printing" in the Printing page options
    589204FBBHU00NI-TDMS cdfs should contain different versions as the dlls change from release-to-release
    589034FCGDHE9Graphing DSTEP in MathScript
    588944FC8E0DError when building DLL with a Waveform
    588744FCCC000Crash when a VI is both called by a member of a LabVIEW class and calls another member of the same class
    588584FB9PJ54Maximized private data ctls flash up and cause trouble
    588544EUGF326No IP record in summary message appears
    588504EUFQ954Need to compile after load in separate context.
    588484F5HD99AOpen/Create/Replace Datalog.vi does not show confirmation message when "replace or create with confirmation" is selected
    588464F4AIRNKMatrix Condition Number saturates to inf at low numbers
    588404F4K00RBMatrix Determinant VI returns non 0 for matrices where it should be 0
    588194F1EIJTMMathScript feval doesn't find functions in search path directories
    588144F58QJF7VI containing 845x reference opened from LabVIEW 8.5 project crashes LabVIEW
    588064EUGI2HERendezvs and Semaphore appear in dependencies list
    588034F4DMDJ1LabVIEW crashes when creating a control of LVClass Refnum type
    588014EO8NNHACrash On RT because of some LabVIEW callback problems
    587974EPGF8E0Coercion dot dissappears when view style changes from ExpressVI to 32X32 Icon
    587954EO823HOTDMS VIs do not free file reference if file open fails due to an error
    587644EUC1P0DCall Library Node Instance Data Pointer
    587484EOCM768VRML file not loaded with wrong positions
    587344ELES2FNLabVIEW classes orphaned in certain cases during application build
    587224EGCS1E1Mixing RefnumTags and Refnums in a class doesn't work
    587164EMGA8OREvalc does not work in MathScript Node
    587014EH9GLS0Logos initialization code throws exceptions but is not exception safe; leads to crashes
    586944EL96U5C3D Graph XControl uses NaN as the count for a for loop and, naturally ,runs out of memory
    586894EL8P3J1Reentrant clones do not unload when their front panels are closed
    586874EM8MQZUCrash in Logos XT PSP Server if a variables buffer is too small to hold a single value
    586604EG0UKD4The dll Import Wizard Will Not Complete With Certain Dlls
    586504EE8N99ZShared Variables nodes always cause problem on load/patch
    586444E9DE968Run When Opened build spec option does not save properly in LabVIEW 8.5
    586334EF0A91GManual Deletion of Class from LabVIEW 8.5 Project Does Not Completely Remove Class from Project
    586214EFEKT9ZShared variable loses linkage when upgrading from 8.5 with no project
    586174E9BLU5MWaveform Graph Plot Area does not resize when changing axis visibility
    586124E8C8H9AChanging icon of a library whose member VIs are all contained in virtual folders inside the lib does not prompt to apply lib overlay
    586054E8OP6YGet/set unmodified function keys as runtime menu shortcut test - VI broken since it cannot find required subVIs
    586004E3F15J1Poly VIs on the block diagram of dynamic dispatch VIs do not count as connecting dynamic input to dynamic output
    585884E4DNA0DAdvanced report generation has some VIs off the palette
    585834E2C8KUZThe LabVIEW Storage Express VIs have input and outputs named the same
    585824E87RIVIVI Server - Open App Ref can hang even if passing in a timeout
    585714E3E560DPalette API Item Path type problems
    585654E2EGCXECannot find - "Plot Images- Read .vi" at the specified location.
    585604E3GITXEThere are duplicate copies of "RT Analysis Workspace.lvproj " in NI Example Finder
    585484E78KBXESplit Signals function does properly generate output terminals when manually expanded
    585384DRDR89ABuilt app that has an instance VI calling a call dll node is broken when run; appbuilder completely misses nested instance VIs non VI dependencies
    585244E19S6TQSave for Previous crashes LabVIEW on a VI containing strict typedef XY graph or XY Graph Reference
    585154DR8EBMXVIs in lvclass are not loaded on second drop of a control of the class data type.
    584904DJF4KGKCrash when triggering autowiring of a feedback node to another node
    584824DNLAPAHLV Crashes when Displaying Error Dialog
    584664DIH22RJCopying a Shift Register on a Timed Loop Using a Ctrl Mouse Drag crashes LabVIEW
    584654DOE59VICrash when loading ODF Editor.lvproj in LabVIEW 8.5
    584214DDFRIF3Hyperlinks of hardware requirements in example finder do not work for several devices
    584024DI8LUP2Error 8 when building an app when using a custom ini file that has a LabVIEW section.
    583994DCCLJ00Problem when dragging non-LV file from project tree onto front panel path control
    583924DHD4PV6Renaming VI to name of deleted VI under Dependencies partially updates project
    583734DGBENWXSave as on a class - unable to rename Rename3.lvclass back into Rename2.lvclass
    583634DC89TAQLabVIEW crash if you change a numerical representation in a cluster in the customize view
    583224DA6AGILabVIEW crashes when creates a indicator from a LabVIEW Object Reference
    583124D3KLC68Waveform Chart X-Scale Marker displays incorrectly with Absolute Time
    582924D48KR00Details of unsuccess application building .exe too imprecise
    582894D48JF00Source Files under Application Builder don't get updated correctly when added and then removed from the "Always Included" pane
    582844CU3EIU1Host Interface Read/Write Control is not listing all Controls
    582694CUDFPYZDragging LabVIEW Objects from one project to another crashes LabVIEW
    582284CL9AQX3LabVIEW should look for both the new and old IVI interface
    582174CJ9C4P2Version Filetype for LabVIEW built DLL's is set incorrectly.
    582014CJ8MM5MLabVIEW 8.5 Shared Library does not display Include Paths
    581934CK915TZMac OS X System Sliders get bigger ever time a VI is saved
    581894CKHLL00LabVIEW crashes when dragging a VI icon over certain items
    581854CLA8LN8Save For Previous should be disabled without the diagram password
    581814CK75NP2Default language on app builder Run-Time Language page is English on Chinese OS.
    581804CK6IGP2Default Language setting does not update when "Support all languages" is selected in app builder.
    581604CEB53P2Local variables lose their names when linked terminal set to "Adapt to source"
    581564CG6T9AFCrash dragging anything from file view into a project
    581204C9DKJA3Minimum size of structure is too large with long cluster names
    580864C172NVIVI Ref property from "subVI" class needs context help
    580794C171MVISkip Sub Routine Call property from "subVI" class needs context help
    580494C58OHP2Source Files and Source File Settings trees don't scroll back to the top when all items are closed.
    580434C58HH4ILabVIEW crashes if I try to drop a New VI object of type Cancel Button with the owner as the "Motion resource" control.
    580414C1A37J1Bug when dragging .lvclass from project tree to path control
    580294BNA4PP2Files in folders that apply "Include if referenced" inclusion show up greyed out in Source Files page.
    580044BNGBBZULogos XT: No k_DISCONNECTED notification if a connection attempt is rejected by the server
    580004BPH6SM0Resize VI Merge
    579994BO94JN8Properties page for elements of waveform let you change it to unsupported types, causing crash
    579934BP7CTP2Selecting Run on a build spec that was saved one one OS but opened in another displays a warning dialog.
    579844BQ9C4ORMathScript error in setting color for multiple lines
    579834BQ9AUWJRead Event Data Example doesn't work
    579374BJ9D7J1Double clicking on LLB Manager to open a VI doesn't bring VI to the front if VI already open
    579344BHA29P2App builder UI preview takes a very long time to display large set of output.
    579154BFD8LZULogos XT needs to provide an explicit disconnect method on a socket
    579054BJC6H00Default object is copied when inplace structure is used.
    579004BMBPN6MThe front object is clipping in reference to the camera.
    578934BFAT6O5Error 53 Get File Type.vi When Used in an Executable
    578704B56C400Coercion dot behavior change with compare primitive.
    578634B91BLMDFeedback node initialize terminal moves when using arrow keys for positioning in a Timed Loop
    578594BBDNE00Print Report prints only 1 copy regardless user input
    578484BA9J5P2No error is returned when trying to programmatically build a non Source Dist build spec in base, full LabVIEW
    578384BC9FU00DB Variant to Data returns stale data
    578364BB7PL2JMathScript 'hold' not recognized by freqz
    578354BB7MS00Typedef array or numeric and numeric do not match for drag and drop
    578044BBEHGC3DAbort in debug build only, when dragging VI from dependencies to my computer
    578024B5FNJ89Compare VI and VI Hierarchies do not recognize differences in initialized controls within a cluster
    577804B1916BWDLL Wizard: update doesn't remember VI names
    577574B0DSJWQFound non-reentrant VIs in waveform "FFT Power Spectrum for 1 Chan.vi" hierarchy
    577354AICTBP2Certain text makes the Three Button Dialog look bad.
    577264AJ9FBP2Integer word length coercion is not corrrect in numeric property page
    577064AL8TT2NFeedback Node appears as 4 objects on the block diagram
    577034AHACSQ6In Place Element Structure: border nodes overlap when created by right-clicking the top border
    576904AKCNPJ1When LVClass/Variant DDO contains missing LVClass data, control is not grayed out
    576874AI9S8P2Adding many files in the app builder source files page takes a long time.
    576864AK5T56IPath controls don't open to folder it expects
    576754ADBP7OUMathScript command input field does not show up correctly on startup sometimes
    576674ACDJHP2Adding a control or polyVI that is in a libray as Always Included, does not distribute the owning library
    576604AED61V6Saving a project VI with changed dependencies does not docmod project
    576564ABDS4E9LabVIEW 8.5 French - Problem in find project item dialog with low resolution
    576484AEFTMGACrash on callisto
    576384AE1UK91Converting LLB To Directory That Contains a VI with Japanese Name Causes Error 1
    576344AA93O00Import web service tool invalid path names
    576294AEDFE00Trying to save for previous on a VI currently in vi.lib does nothing and gives no error
    576234AC6DA2JMathScript polystab is slow
    576104A4AFPQ6Build path displayed in build status dialog does not match output directories in AB UI Load Previous test.
    576094A0APG00Use vi.lib/AdvancedString/Path To Command
    5754349N98KS0variable label doesn't update after renaming
    5752249F8C1J1Cluster to Array prim doesn't seem to handle LVClasses intelligently
    57516490AGUDENo Rename option on Project root item
    5744348NGJ7XXPasting array contents on front panel deletes all other elements
    5743148N74H1GNeed a "VI Hierarchy window" for MathScript
    5741748MFOI00Determine whether we still need to deploy TypeDesc attribute
    5740848JGN12K"Include SubVIs" checkbox doesn't include dynamic subVIs.
    57380484FF8FNVista UI - Create a new probe Dialog
    5734447SCI7GOType name change on bundler/unbundler does not cause auto-grow
    5730447MFBMN8Output configuration of nodes and the waveform datatype
    5728847E9AHZULogos XT should return an error with the k_DISCONNECTED status
    5718346BB6D00Unflatten XML slowdown
    5717246C8L5VXSoftware triggering with hysteresis doesn't work in signal express.
    57168467E11XCNew additions to Application:TargetOS property could adversly affect App Builder
    5716546DGB0I0Remote Panels and VLM Cause Undesired Behavior
    5713345U8NU9ZUser gets no indication that the Variable could not resolve the alias and has fallen back on the "last known" IP address
    5712345U7DRVRSingle Plot cursor on Digital Waveform Graph crashes LabVIEW
    57116460DNKIJMatrix Logarithm.vi gives inconsistent results on Windows vs RT
    5710845OADI0SDragging over 30 shared variables and dropping them on a front panel can't be accomplished successfully
    5710645O8LAP2Cancelling removal of missing class file from project results in dialog calling project corrupt.
    5710045GB9KV9Variable reference is destroyed too early when a variable in a subVI is called from multiple hierarchies
    5701644DLSS7QMajor grids disappear on waveform graph
    56999444F09MQUser sees search dialog instead of error after giving bad DLL to CLN
    5698743S3M57UWaveform Chart Control Probe No Longer Works For All Data Types
    569584388O1FIUsing a higher count of Shared Variables in a VI makes the VI respond very slow during development.
    5692742MDRSX6Shared Varibles disappear on the block diagram
    5687541Q7I1ABBehavior when opening read/write and read-only sesssions on same TDMS file depends on order
    5683940THMI99Waveform Graph Custom Probe Only Works For DBL Data
    567763ZJFNHHANeed better error reporting if PDF file is not installed
    567383YSA44BWCompare VIs doesn't report VI path link changes
    566813YC9T09ORemove breakpoints from heirarchy does not work for subVI's from library
    566473Y0H7C9AWiring from SNode diagram to SNode's containing diagram, setting tack point, and wiring back to snode behaves differently in 8.1 than in 7.1
    566413XUC9E00Memory Usage window incorrectly reports subarrays as fully allocated arrays
    566373XOEOS2KCustom Probes can cause recursion; need same behavior as regular custom probes
    565803WICRJSQSingle Process Shared Variable VI Saved At Project Level, Regardless of Owning Library Location.
    565743WBH00J1Compare primitives (other than = and !=) don't work with LVClasses
    565443W3ESOC3Need to not use absolute addressing of LVClass gencode
    564913V7F0FRSAppBuilder doesn't allow user to type into it
    562853P6GLMBWThe NI-488-errors.txt file not being installed on Mac & Windows.
    561663KDFUL00Cannot build a dll with LabVIEW App Builder if LabVIEW is installed to a path containing multibyte characters
    561343J7A8IJ1Variable terminal spanning the whole node causes wiring issues
    560773HGGQE3ONo list of properties when creating a property node for a splitter bar
    560263CTG0CEOCreate a variable from a right click option on a wire
    558072U9G8M00ConnectorTM not updated when caption is deleted.
    557992VHDQKJ1If probe is open with unsaved changes, using that probe discards changes without asking
    557762RDBPUXCReport Generation VIs aren't the same between Windows and Mac
    555504I5GC9KUIConfig::browseNode strips single-quotes from some tag names
    555294HUEHCD5Weight of curve fitting can't be changed in C code
    554764HL7CE00Please fix Queue Stack - LIFO.vi example programs for issues introduced in LabVIEW 8.6.
    554094GK9ESXXLabVIEW Crashes After Modifying Cursor Value in Corrupt Waveform Graph
    552814FC6TLHOFront Panel of nested subpanel control not accessable in LabVIEW 8.5
    552744F12PAWQLabVIEW crash - right-click on timed loop in text or tree palette format mode
    552704F0ETBPWMathScript UDFs have inconsistent case-sensitivity
    552424EB6HMP2LabVIEW crashes when deleting an item from a class after it was removed from source control.
    552284E89QTN8Crash setting Index Count property on Index Array node inside flat sequence
    552164DGGKPQUInvalid Variable Inputs with Formula Waveform VI in LabVIEW 8.5
    552094DADILSGIO Control interface does not call into GetIOControlRtClickMenuItems from a built LabVIEW executable
    550804AIBG43ZAnnoying dialogs output on Cancel from password prompt
    550754AO9EFTDIO Assistant support being installed to LabVIEW 7.1 even when LabVIEW 7.1 not installed
    550554A3EDUNBOpen Front Panel option should not be available on Black Box Code gen VI
    5496644C83BW0Mouse Down Event for Right Click doesnt work on disabled controls, if VI is used in a SubPanel
    5495443CFE91JMac OS X Creates Incorrect File Permissions After Install
    5494942A9TBN8Stack overflow doing "Create SubVI" (reproduces in LabVIEW 4.0.1)
    548873VEGNI77"Refnum-free" property nodes leak refnums
    548403NPFG683Fixed size arrays do not work with VI server variant get/set control value.
    547244HU8LQTDSylvester Eqs and Lyapunov Eqs cause memory leakage in LV8.5.1.
    547024HDA3J00Block node caption does not update correctly in Icon View
    546934HFD291GUpgrade codes for help installers conflict
    546624GUF1QGSForcing class private data to include Xcontrol Refnum crashes LabVIEW
    546614GDCRETDThe Spline Interpolation 1D VI should use the derivatives of initial boundary when the initial boundary is 2nd derivative.
    546414G6EG79ZDuplicate PersistentIDs for Variables in .lvproj file
    546374GB87JP2BlockNode Express VIs drop with empty diagrams
    546134FJFQOI5Linking issues in project explorer using an .lvlib library
    546034FJDRUGOMarked As Modifier option not undone after undo operation.
    545854F5AC8TDHermite Interpolation 1D VI gives uncoherent results with its help. Compatibility issue with the size of X.
    545784ETDPSTD2D Interpolation VI gives unreasonable results when the inputs sizes don't match.
    544834C1867N8Variant to Data outputing different data the first time its run vs. subsequent runs
    544734BPF7DWNDataSocket will not load on Mac if drivers are not installed
    544574BAAOMVISimplify C Interface package file
    544354AHFTU00convert to subvi doesn't work on new express vis
    5440549E1UPQKLV Stand Alone application crashes when inserting VI as a subpanel that is also called statically
    543884918MPRSSave for Previous - Lousy error message for S4P if VI belongs to a password protected library
    541323IDFD9BQShould LVM files be dependant on decimal separator?
    540154ILA1IVIModal Class Browser initializes to wrong class for strict VI references
    538754IBAFKXXLabVIEW 8.5.1 RT Palette Crash - Load When Needed
    537254HSCRIHLRedraw the function block merge VIs
    536264HEC2D00Failure to load .NET assemblies produces unhelpful error message that makes debugging difficult.
    536044HACQ408Update Help button links for dialog boxes from Express VI Development Toolkit
    535944HFHDNO2Function palette search on new target VI crashes LV
    535424H7CN59ACan create a non-locked down copy of an eval licensed VI via new from template mechanism
    535244GRFEIXEDynamically calling a VI that calls a .NET assembly throws error 7
    535094GK9P66QExpress utility VI does not handle Ring values correctly
    534884GUGS2DKCreate Data Link not active if Getting Started Window is open
    534814GL5DL15Fixed-size array information lost from indexed for loop when adding a primitive to signal path
    534774GKBRNOQCall VI node is not migrated from LabVIEW 7.X to 8.5.x stack
    534214G9A4D00TDMS Read causes memory leak when used with strings
    534054G6DSRDXMathScript UDF with no input parameter fails
    533864G51T2U1VI saved without diagram breaks when it contains .NET reference
    533124FTBMM00Strict static VI reference and execution state issue
    533044FEFIT5IReport Express VI functional test in Linux - Generated Report does not match with the original
    533014FJ7BP00LabVIEW crashes if loading a MathScript implementation VI fails for any reason
    532674FFB1100Intensity Graph data corruption
    531844F6CLLN8VI ends up with odd name when reverting changes of a VI with a missing subVI
    531304EM7J8WQLoading 8.2 Formula Express VI in 8.5 can give wrong result with integer-only inputs
    531044EHCI57ZSearch aborted box keeps popping up
    531034EH802WIError building Source Distribution when LabVIEW is installed in a different location
    530944EBG02DTBroken VI error when building executable that uses target-relative shared variables
    530724E3FECJ1When saving a copy of a VI and adding the duplicate to the original library, scope is not preserved
    530404E0DODF2Erroneous Broken Wire with In Place Element Structure and Uninitialized Shift Register
    530014DP8SGOFAdding a VI that Uses a .NET Assembly to a LabVIEW Project Breaks the VI in LabVIEW 8.5
    529694DGEDC2NWe should only generate helpDB dictionaries for components that we know are localized
    529034D4MGTGIInternal Error happens when showing the "Change Inheritance" page for AB_DLL.lvclass
    528774CRBUMORMathScript function gensig does not generate signal with same cycle
    528594CR9OHORMathScript impz add redundant zeroes for FIR filter
    527904C2BAJFFLabVIEW completely fails to load an assembly if a dependant assembly isn't found.
    527844BUEM5YTOpen Datasocket primitive crashes if subVI is invoked dynamically (using Call By Ref or LabVIEW class dynamic dispatching)
    527074BT8BKU7NI Example Finder- LVOOP Examples (.lvproj examples) descriptions are not localized
    526514BI9SC00Poly instances with different output terminals have strange drawing behavior
    526494BJ81LN8Error for target relative shared variable is incorrect
    526284BFG7RFNMVE isn't properly flushing posted DeferredActionEvents
    526214BGE7OM8User inputted timestamp ranges in the LabVIEW property nodes is not saving
    526084BFF38SFVI doesn't appear broken after .m file is deleted
    525154B42I5IRead DAQmx properties & TDM user defined Properties from TDMS test fails
    524154ASAQPU9Updating a global variable through the node will not update its view from the window
    524034APET600Errors with LabVIEW Class constant of a class that is missing
    523974APAO4LGSE 2.5: Help button is not linked with help in: Record Options->Start Condition -> Set Time and date
    523834AHD4SX6Error 1017: Can not build EXE in project with single-process shared variables
    522844AH953QOWe can't load .NET assemblies which reference missing unused assemblies
    522154A7BBIRMProblems with variable-related VIs on MAC
    520654A09C100User can abort Details Display Dialog (from Simple/General Error Handler) using ctrl + period
    5204249TAM8OUMathScript specgram not supported
    5186249GE2P00Built app (RTE) can't load a class with polyVIs included
    5184448TF5Q54Single element relative paths need to display better in load warning dialog
    5182848QKJV9AClosing a library only project sometimes gives save/defer decision when it should give save/don't save
    51789496H2J00Frontmost property of VI incorrect when floating window is open.
    5172248NAH8U1Numeric Control: Format String functionality shows odd behavior when attempting to increment (displays NaN)
    5168648MC17P2SCCGetRequiredFiles does not return files inside of a library.
    51492481EAMMQUpdate NTS et al. binaries/includes for the Linux build
    51313478FEEM9Vista UI issue in "Rearrange Pages" dialog
    51259478EAS5LMCL Adapt to Type -- Selection is Wrong
    51190477CC55Minsanity in knob control
    5096246LENBC3RC Linker Test failed
    507414688TNRMEx_userDefPropDialog.vi is broken on MAC
    50739467BNIMQTimed Loop crashes LabVIEW in Linux
    5063945UFF3KYLoading thousands of variable in the project takes a long time
    5039244BE1JKQAbout_App runtime menu appears differently in executable
    503274436ATN3To More Specific Class to an XControl does not work in built applications.
    5025643Q96C00LabVIEW generates empty INI files on Windows if no INI file currently exists
    5020343C928FCExample VI \Icon256.vi: overlapping text
    5019643DGP8FCExample VI Add Files to Project.vi: text overlapping.
    50191439F4DFCExample VI Open Tree Control.vi: text overlapping on FP.
    50189439EIGFCExample VI Date Server Queue.vi: overlapping text on FP.
    50182439BFJFCExample VI E-Mail notification: overlapping text on front panel.
    5017643D8GSVQNI_3D Picture Control.lvlib:Find Object.vi should be able to handle not finding the specified object
    4976940OD22FNStrange behavior on Ctrl+Double-click on Tree control, event structure
    4975340M9C8N8private data control is "hung" if opened from VI hierarchy window after flattening a class to a variant
    495833ZJF84YRPasting/typing a directory path into path control then immediately clicking browse takes you to different directory
    494293YRBD700Dynamic class VIs don't appear in VI hierarchy
    493553YLB3DDXInstance vis can be reported bad in mass compile log
    487353V9ANMFNVariable Rename test: renaming variable not detected unless VI loaded into memory
    487233VDFPPN8Error from Variable refers to "global variable"
    481433PQF4B00NI ACL Configuration Dialog has no help file
    478813O294AZUTagger logs redundant data points whenever an external Logos client connects to or disconnects from a Variable's source I/O Server data item
    476183KRAE05GDropping an image display control as a strict typedef gives a DAssert
    4701238RFJQXXLabVIEW does not refresh well when Express VI is reopened
    4697838AHG6XXLabVIEW does not exit properly after using HSDIO Express VIs in process
    462074IK86BGYSquare cannot accept integer input when Adapt to source is selected
    459284ILAJ889.NET Event Not Registered Consistently
    459254IKEMI68Waveform Chart Sweep Chart Displays Horizontal Line
    459074IHBF000Unable to acess Property Pages for ActiveX control from LabVIEW 8.5.1 context menu
    458224IBHBTQ2LabVIEW crashes when user invokes Add Targets and Devices
    456554IBFAOAGCrash Creating Control from Match Regular Expression with Standard Classic Palette
    455924IDBQP00Pressing on the Stop button does not stop the VI when running the VI in the TestStand LabVIEW User Interface
    454794ICDRLGELabVIEW 8.5 Crashes When You Open a VI from LabVIEW 8.0 that includes an XY graph
    454564IDAUQB7Global Variable Change Will not Break Top Level VI
    453964I3FLMF2Save for Previous on the Attached VIs Crashes LabVIEW
    453494I4B7LE1Library Access Scope failing to update when one library moved inside another.
    452474I77OEK4Front panel controls stick sometimes when clicked
    452194I3GS4K4Writing to Cursor.Plot property of Intensity Graph throws error
    452174I3CQT00Merge dialog comes up runable in LabVIEW Full - Windows.
    451934I3GN200MathScript Linker crash with mixed case for UDF Calls
    451474I62I9POError -90001 when using Color attribute in MathScript Window
    451294HTDPD54Multiple Executables In A Single Installer Do Not Deploy Correctly
    451284HTDKC54Adding Multiple Executables to Installer Breaks Installer
    450724HT7N0X2Changing dt in Waveform constant crashes LV
    450164HSD22P2Selecting Tools>>Source Control>>Show Differences on a poly VI does not show interactive window.
    449694HOBBKTYOpening a vi that adds two waveforms and was saved for previous version from 8.5 crashes LabVIEW
    449614HU96900Coercion dots not shows when static ref of a differnt VIs are wired to a Call by ref node.
    445964HHAH2OH3d entry allowed into spreadsheet string to array
    445194HG8AA1WPrompt for VI says "Find the VI Template Named ..."
    444984HDD7P2JMathScript issues with 'filter'
    444974HDD73M2Shrinking Panel Bounds with SubPanel
    444054HAEETUDLabVIEW compiler not optimizing for speed in 8.5 as it did in 8.2.1
    442244HA8OA00Event structure value change event NewVal terminal value differs from control value for variant types
    441244GJDKRVBLinux Dark Runtime Threading Differences From Regular Linux Runtime
    441074GREN284Deleting data with interactive data retrieval always deletes last element
    440574GK9S4XXSaving New Class Without Data Cluster Crashes LabVIEW, No Dialog
    440294H1EPO00Opening many top level VIs causes crash
    439474GLRO6QFeedback nodes don't move correctly.
    439464GLHH6QTo align two feedback nodes lead to many DWarn
    439344GSMUJP2Read BMP File hangs LabVIEW if reading the wrong file type
    439304GKCDSUSRegister For Events Retains Unwanted Elements When its Terminals are Disconnected.
    439094GPE4HTDRefNewton Raphson Inner Part numeric derivative.vi returns different results with Newton Raphson Inner Part.vi.
    436584GBDC7OOInline subVI invoke node crashes
    436404GAA2M2NAcquire Data.vi and Analyze & Present Data.vi in examples\general\uievents.llb need cosmetic changes
    436204G9DOKKYLV Project incorrectly allows adding a DAQmx Project item to a Library
    435464G6EDQUKDynamically setting properties on XControls doesn't work
    434984GAC57ORLabVIEW ODE Solver VI returns unexpected result on multi-core system
    434624GCFHHAEcRIO 9002 Ethernet overload causes Controller Crash
    432214FPB4CTMAdding VI to Front Panel that contains a Splitter Bar causes crash
    431714FSFD5C4Cluster data outside of visible portion of front panel do not print
    431164FQ6JR1GDuplicate Case Crashes with Delete/Copy Panel Terminals from Diagram Disabled
    429934FGD3T00Opening a class from disk which is already loaded says it's open from another path
    429104FJGJR00The property dialog of a diagram constant pops the front panel
    428994FEDIT0DBasic Hyperlink Project Item Test on Linux
    427934FDHT5XEThe example RT Analysis Workspace.lvproj does not open up in Linux
    427794FBBGT00NI-TDMS cdfs should contain different versions as the dlls change from release-to-release
    427764F897L14LabVIEW 8.5 Crashes when Duplicating Event Structure
    427524F7FCQ9XTip Strips Missing in Switch Executive 2.1.1
    426584F4FLLWSIgnore Waveform Timestamp does not execute or remain checked
    426104F4F1LRMGo To LabVIEW button should not be in File Dialog in Runtime Engine
    425994F4ESQRMAbout LabVIEW menu item should be changed to About "Application" in Runtime Engine
    425794F5GDALJLabVIEW 8.2.1 and 8.5 crash when updating multiple FP objects programmatically in cluster
    425384F6C651WVI documentation printing doesn't include control descriptions of the control is a typedef
    424834EPG6F5UUpdate RT App Builder tests
    423134EOCBC5ILoad Deprecated Properties - No warning message displayed.
    423084EUAFFNKUpgrading Tab Controls to LabVIEW 8.5 breaks Z-Order and makes controls disappear / reappear
    422174EIDFGWBWrite to Text File function behaves inconsistently when dealing with path arrays that have been converted to string arrays
    422124EH9INF3Close "Configure Method" window of XControl method will hang LabVIEW
    421164EAFE6AHLarge custom control shared variable crashes LV
    421114EBD3L00Change CHM reference for the Help button in the View I/O Items dialog box topic
    420644EB9FCWXTest dragging of XControl Components in the project framework - LabVIEW crash
    419334E77JBXPI64 Data Type Array Auto Conversion Crashs LabVIEW 8.5 on PowerPC (Mac and VxWorks)
    419124E3I6HVBDigital Waveform Graph Does Not Support X Scale Formatting Options Except Floating Point
    418714E2FL4XEAn error dialog pops up when "PICT" file format is selected.
    418544E80I56YAB Installer Include hardware configuration with installer generated by app builder - Test instructions not clear
    418254E2E4DXECannot find - "Plot Images- Save Load .vi" at the specified location.
    417734DQE18RMLabVIEW Crash Capture mechanism doesn't work in Mac OS X 10.5
    417414E03F700Datasocket method not threadsafe - results in LabVIEW crash
    416714E1GD7J1The context help for GetLVClassInfo.vi is wrong
    416194DIF6L5IRing and Enum Controls- Property Page Test - Changes in Label not reflecting
    416094DPCT5SMPoser Node VI Server "Terminals[]" property gives me some bad terminals for wiring
    416074DOEJLBACrash when comparing 3DPC_SurfacePlot reference
    415784DOE4B9ZMVE should prevent user from editing certain properties under certain circumstances
    415524DJEAC5IArray Node Auto-resizing and other feedback VI is broken
    414744DG3LG4ILicensing Testing for Constellation doc needs to be updated
    414684DHBEMN8compiler error using Search 1D Array with an array of variants
    414184DHF6RLX'Diff' ing two VIs with radio buttons with different mechanical action does not report any differences.
    413874DDEJC1RRemote Panel Licenses Lost When Repeatedly Refreshing RT Page
    413734DHC6200Calls To DB Tools Execute Query With Non-Forward-Only Cursor Fails in 8.5, Error 3005
    411964D3BLBXEThe file "loadprimetest.vi" does not execute successfully
    411354CUCHF00Expand Digital Buses checkbox incorrectly appears on graphs
    411274CU9UK5DSweep/Scope Chart does not update x-axis the first few sweeps
    409364CJDJEZGWrite to XML File.vi does not specify name space in the LVData tag
    409084CHF93TZCreating a programable property leads to xcontrol corruption
    407334CEFHUV6Attempting to stop loading an LVClass while searching hits dwarns and crashes
    406564C16URVIVisible Bounds property from "Diagram" class needs context help
    406454C0ETLVIAdaptToEnteredData property from "Numeric Constant" class needs context help
    406444C0EQSVIMakeSpace method from "AbstractDiagram" class needs context help
    406124BUC8A7NAppend Control Image to Report appends a wrong image
    404864BPC7200Please fix Queue Stack - LIFO.vi example program.
    404754BNF54BQExamples\project\viserver\Add Files to Project.vi should not allow some string from being translated
    404544BQF4D1IWhen you don't have MKL DLLs on your computer and you try to load a VI that calls them, LabVIEW crashes.
    404134BM94LJ1Font on VI Properties>>Window Appearance>>Customize dialog is wrong
    403934BJD32CSCan't create indicator of IMAQ image control reference
    403884BGC5SP2App builder VI Properties auto test fails.
    403494BKHM600Crash if FPGA target support open plugin uses "custom" I/O ctl for "resource name" input
    403474BJ793N8Error 42 writing to a shared variable of fixed point type.
    403244BIBKMXEVista UI - Search Instrument Driver 2nd window has hidden string.
    402954BJASUP2Can't build a framework multiple times during a LabVIEW session.
    400484B1CTVSNThere are two "RT Analysis Workspace.lvproj" examples in [Example Finder]
    400304B12TB6SMixed Signal Graph: Digits of Precision only applies to 2nd Y Axis
    399804AP75269Cannot deselect Run Executable after Installation from Installer Properties
    398934AHAHR1RFormula nodes does invalid operation in prop types
    398274ALEUK00FXP point parameters should not change when uncheck 'Adapt to source'
    397284AEE43DEShortcut menu item on tab control, Goto Other Page, spelled incorrectly
    3951148O91GEQAdding PNG images to LabVIEW Front Panel corrupts the VI
    39238421AIPFCExample "Print LLB to HTML custom.vi" has out-of-date comment.
    391803RTGNPBWAdding a tab in tab control typedef causes placement problems
    382173YFFC900LLB Manager hangs until we click outside of LV
    375943PL9QP00Link Help button in Select Application Instances dialog box to the Profiler help page.
    373954688MCRMBroken VIs in distribution due to missing Storage.llb and lvStorage.llb on Mac
    371854586SIKMEdit VI is very slow
    3699849SBL1FCVista UI - Import Shared Library: sizing issue.
    3696049ODBO71Replacing Waveform Graph with Mixed Signal Graph w/ cursors crashes.
    3662440MBIBN8Errors and crash attempting to drop an xnode that contains a LabVIEW Class in its state
    3566442H9C4EQUnable to Edit Items on a Text Ring with Quad, Unsigned Quad, or Fixed Prec. Representation
    355263W96QK7CLabVIEW 8.0 - Image Display control causes
    35180488FQSUKLabVIEW needs to support updating linker information for subVIs using properties of Xcontrols
    © 2004–2008 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-2-5 14:08
