查看: 4196|回复: 0
[面阵相机] 石鑫华视觉供应进口CMOS相机AVT Guppy F-503C
  • 签到天数: 128 天
    发表于 2014-7-17 10:43:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    AVTGuppy系列IEEE 1394A工业相机轻巧便宜,型号多样,非常适合于有空间、成本限制的应用项目。
    AVT Guppy工业相机
    描述
    Very small, lightweight industrial FireWire camera – inexpensive
    小巧,轻型工业火线相机-便宜
    The Guppy is a very small, lightweight, inexpensive industrial FireWire camera. Guppy cameras are equipped with a large variety of renowned CCD and CMOS sensors by Sony and Micron/Aptina - the versatile Guppy series provides the right camera for almost all kinds of applications.
    Guppy系列相机是非常小巧、轻型、廉价的工业火线相机。Guppy系列相机配置了大量有名的CCD、CMOS传感器 ,这些传感器都是由SONY和Micoron/Aptina提供的-通用的Guppy系列相机为几乎所有应用的提供了正确的相机。
    IEEE 1394a (400 Mb/s)
    火线1394A接口
    CCD and CMOS sensors (1/3, 1/2, 1/2.5), 10 models (VGA to 5 Megapixel)
    CCD、CMOS图像传感器(含1/3,1/2,1/2.5),10型号(30万像素到500万像素)
    Guppy F-038B/C and F044B/C also available as NIR version (enhanced near infrared light sensitivity)
    Guppy F-038B/C和F044B/C也可以提供近红外的版本(增强的近红外感光特性)
    Options
    可选项
    -Various IR cut/pass filters各种红外截止、通过 滤波器
    -CS/M12 Mount adapters (M12 only for sensors < 1/2)镜头接口可选用CS/M12(M12型仅适用传感器小于1/2’的)
    -White medical housing白色医疗外壳
    功能
    Programmable LUT可编程查找表
    Auto gain自动增益
    Auto exposure ( except for Guppy F-036B/C, F-503B/C)自动曝光(除F-036B/C, F-503B/C外)
    Image mirror (only Guppy F-036B/C, F-503B/C)图像镜像(仅F-036B/C, F-503B/C)
    Binning (b/w) (only Guppy F-036B/C, F-503B/C)像素组合(黑白)(仅F-036B/C, F-503B/C)
    HDR (High Dynamic Range Mode, only Guppy F-036)高动态范围(仅F-036)
    Only Guppy F-503B/C: Sub-sampling, defect pixel correction, multi-shot, separate AOI for auto features仅F-503B/C拥有子采集,坏点校正,多次采集,单独的AOI用于自动特征。
    应用
    With its very compact housing, a Guppy industrial camera fits into the smallest places. For OEM solutions, board level versions are available. Thanks to the diversity of the Guppy models, this industrial FireWire camera fits a large variety of applications.
    非常紧凑的外壳,Guppy系列工业相机适用于最小的工作空间。对于OEM解决方案,板级的版本是可用的。得益于Guppy系列型号的多样性,这类工业火线相机适用多种应用项目。
    Cost-effective and easy move from analog to digital cameras划算的,并且非常容易从模拟相机到数字相机的转换
    Applications with space constraints应用项目有空间限制
    OEM solutions (board level version)代工解决方案(提供板级版本)
    Machine vision and inspection机器视觉和检测
    Robotics机器人
    Quality control质量控制
    ITS/Traffic monitoring智能效果/交通监控
    ... and many more更多
    规格
    Guppy
    F-033
    F-036
    F-038
    F-038NIR
    F-044
    F-044NIR
    F-046
    F-080
    F-146
    F-503
    Interface
    接口
    IEEE 1394a - 400 Mb/s, 1 port
    Resolution
    656×494
    752×480
    768×492
    768×492
    752×580
    752×580
    780×582
    1032 ×778
    1392 ×1040
    2592×1944
    Sensor
    Sony ICX424
    Micron/Aptina MT9V0225
    Sony ICX418
    Sony ICX428
    Sony ICX419
    Sony ICX429
    Sony ICX415
    Sony ICX204
    Sony ICX267
    Aptina MT9P031
    Sensor type
    传感器类型
    CCD Progressive
    CMOS Progressive
    CCD Interlaced
    CCD Interlaced
    CCD Interlaced
    CCD Interlaced
    CCD Interlaced
    CCD Progressive
    CCD Progressive
    CMOS Progressive
    Sensor size
    传感器尺寸
    Type 1/3
    Type 1/3
    Type 1/2
    Type 1/2
    Type 1/2
    Type 1/2
    Type 1/2
    Type 1/3
    Type 1/2
    Type 1/2.5
    Cell size像素大小
    7.4 洀嬀/size]
    6 洀嬀/size]
    8.4×9.8 洀嬀/size]
    8.4×9.8  洀嬀/size]
    8.6×8.3  洀嬀/size]
    8.6×8.3  洀嬀/size]
    8.3洀嬀/size]
    4.65 洀嬀/size]
    4.65洀嬀/size]
    2.2洀嬀/size]
    Lens mount
    C
    Max frame rate at full resolution
    全分辨率时最大帧率
    58 fps
    64 fps
    30fps
    30 fps
    25 fps
    25 fps
    49fps
    30 fps
    17 fps
    6fps
    A/D模数
    10bit
    10bit
    12bit
    12bit
    12bit
    12bit
    12bit
    12bit
    12bit
    12bit
    Output输出
    Bit depth
    位深
    8bit
    8bit
    8bit
    8bit
    8bit
    8bit
    8bit
    12bit
    8/12bit
    8/12bit
    Mono modes
    黑白模式
    Mono8
    Color modes YUV
    彩色模式YUV
    n/a
    Color modes RGB
    彩色模式RGB
    n/a
    Raw modes
    裸数据模式
    Raw8
    General purpose inputs/outputs (GPIOs)基本通用输入输出
    Opto-coupled I/Os
    光电隔离输入输出
    1 inputs, 3 outputs
    RS-232
    串口
    1
    Operating conditions/Dimensions工作条件/尺寸
    Power requirements (DC)
    供电
    8 V - 36 V
    Power consumption (12 V)
    功率
    <2 W
    Mass重量
    50g
    Body Dimensions
    (L x W x H in mm)
    尺寸
    48.2 x 30 x 30 mm incl. connectors
    Regulations
    认证
    CE, FCC Class B, RoHS
    石鑫华视觉网的相机购买请看http://visionbbs.com
    GMT+8, 2026-4-7 17:20
