查看: 1191|回复: 0
[NI驱动程序] NI-VNA 18.0.0 Win32/64bitEng 矢量网络分析仪18.0.0下载
    3 小时前
     楼主| 发表于 2024-4-9 15:25:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-VNA
    NI-VNA为使用NI PXI矢量网络分析仪的客户提供支持。
    NI-VNA是控制所有NI PXI矢量网络分析仪所需的NI仪器驱动程序。您可以配置测量扫频、触发器和时域。您也可以自定义自动化测量并执行用户校准。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及底层实用程序。NI-VNA包含了交互式软面板和示例。
    NI-VNA 18.0.0
    发布日期:2018/5/31
    包含的版本:18.0.0完整版,版本号18.0.0
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    Windows 8.1 32-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 8.1 64-bit
    语言:英文English
    文件大小: 613728136 字节 (585.30 MB)
    修改日期: 2023-01-21 09:52
    MD5: d486c4200af803efca551046b119a792
    SHA1: 63e6d17d22feb108dc51705536661e4956174886
    SHA256: 10ccd53c2f983d14b57d628d24f4dce7932b2e5c76708ff69089d5c0758f281c
    CRC32: 6ffdc311
    注册登录视觉论坛账号,购买附件查看下载地址
    VNA18.0.0.txt (474 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VNA 18.0 Readme
    May 2018
    This file contains important information about NI-VNA, including new features, system requirements, supported hardware, and known issues.
    IVI Compliance Functionality
    Licenses and Notices
    This software installation provides support for customers using vector network analyzer hardware, as specified in the Supported Hardware section. To program your vector network analyzer, use the NI-VNA instrument driver or the NI-VNA Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using a vector network analyzer.
    NI-VNA 18.0 adds support for LabVIEW 2018 (32- and 64-bit)
    NI-VNA 17.5 includes the following new features:
    • Removes dependency on .NET 2.0
    NI-VNA 17.0 includes the following new features:
    • Adds support for LabVIEW 2017 (32- and 64-bit)
    • Removes support for LabVIEW 2013
    NI-VNA 16.0 includes the following new features:
    • Adds support for LabVIEW 2016 (32- and 64-bit)
    • Removes support for LabVIEW 2012
    • PXIe-5630 Vector Network Analyzer
    • PXIe-5632 Vector Network Analyzer
    Device-specific information about these modules is included in the NI Vector Network Analyzers Help.
    NI-VNA 18.0 has the following requirements:
    NI-VNA 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 SP11 (64-bit)
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note  In 2016, the NI-VNA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The NI-VNA will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the NI-VNA to an unsupported OS. Additionally, after installing the NI-VNA, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-VNA 18.0 supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-VNA. To add support for application software installed after installing NI-VNA, modify your NI-VNA installation or launch the NI-VNA installer again.
    Versions Supported by NI-VNA
    LabVIEW2015 SP1, 2016, 2017 SP1, or 2018
    LabWindows™/CVI™9.0.1 and later
    Microsoft Visual C++ (MSVC)6.0 or later
    Accessing the APILabVIEW
    NI-VNA VIs are available in LabVIEW from the Functions»Measurement I/O»NI-VNA palette.
    LabWindows/CVI
    NI-VNA functions are available in LabWindows/CVI from the Instrument menu. To load the NI-VNA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niVNA\niVNA.fp.
    C
    You can use the NI-VNA C dynamically linked library by adding a reference to:
    • (32-bit) Program Files\IVI Foundation\IVI\Bin\niVNA.dll
    • (64-bit) Program Files (x86)\IVI Foundation\IVI\Bin\niVNA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niVNA_64.dll for 64-bit development.
    To launch the NI-VNA SFP, navigate to Start»All Programs»National Instruments»NI-VNA»VNA Soft Front Panel.
    Select Help»Find Examples in LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-VNA. You can also select the Search tab to search all installed examples by keyword.
    All installed NI-VNA examples for LabVIEW and LabWindows/CVI are accessible from Start»All Programs»National Instruments»NI-VNA»Examples.
    Documentation for NI-VNA is located at Start»All Programs»National Instruments»NI-VNA»Documentation. The documentation set is composed of the following documents.
    Document
    Format
    Description
    NI Vector Network Analyzers HelpHTML/Windows HelpContains primary help content for vector network analyzers. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to fundamental vector network analyzer concepts
    • Hardware device information
    • A complete reference for all NI-VNA programming functions and VIs
    Getting started guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Calibration procedures for your devicePDFContains calibration instructions for your device.
    NI-VNA ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Introduction to niVNAHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    NI-VNA IVI Compliance DocumentTXTContains information about IVI compliance.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI-VNA 18.0 no longer installs IVI Compliance Package. NI-VNA 18.0 supports IVI configuration and runtime, but no longer supports the following features:
    LabVIEW and SVI IVI class driver APIs for developing IVI interchangable applicationsIVI Class Simulation DriversIVI-COM Adapters
    You can access the software and documentation known issues list online. Refer to the NI website at for an up-to-date list of known issues in NI-VNA 18.0.
    NI-VNA contains third-party software for which the following licenses and notices apply:
    • NI-VNA FOSS notices
    • Microsoft DotNet 4.0 License
    • Microsoft DirectX 9.0 License
    © 2010–2018 National Instruments. All rights reserved.
    374800F-01
    GMT+8, 2026-4-23 11:00
