查看: 1192|回复: 0
[NI驱动程序] NI-VNA 17.5.0 Win32/64bitEng 矢量网络分析仪17.5.0下载
    3 小时前
     楼主| 发表于 2024-4-9 15:22:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-VNA
    NI-VNA为使用NI PXI矢量网络分析仪的客户提供支持。
    NI-VNA是控制所有NI PXI矢量网络分析仪所需的NI仪器驱动程序。您可以配置测量扫频、触发器和时域。您也可以自定义自动化测量并执行用户校准。该驱动软件包括基于IVI准则的灵活API、完整的硬件支持文档以及底层实用程序。NI-VNA包含了交互式软面板和示例。
    NI-VNA 17.5.0
    发布日期:2018/1/22
    包含的版本:17.5.0完整版,版本号17.5.0
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    Windows 8.1 32-bit
    Windows 7 (SP1) 64-bit
    Windows 7 (SP1) 32-bit
    Windows 8.1 64-bit
    语言:英文English
    文件大小: 613580680 字节 (585.16 MB)
    修改日期: 2023-01-21 09:52
    MD5: da3e92dc0c204ddadabf16c14d1db3a2
    SHA1: ac91ae11282ff8726914ce0e8a9a1df30b038946
    SHA256: 5bd2ed7936fa2a7cb51659310031e8bc458d1a564ce360c33a2b2178f770b008
    CRC32: 4645aec3
    注册登录视觉论坛账号,购买附件查看下载地址
    VNA17.5.0.txt (474 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VNA 17.5 Readme
    January 2018
    Thank you for using NI-VNA. This file contains important information about NI-VNA and is organized into the following sections:
    NI-VNA 17.5 includes the following new features:
    • Removes dependency on .NET 2.0
    NI-VNA 17.0 includes the following new features:
    • Adds support for LabVIEW 2017 (32- and 64-bit)
    • Removes support for LabVIEW 2013
    NI-VNA 16.0 includes the following new features:
    • Adds support for LabVIEW 2016 (32- and 64-bit)
    • Removes support for LabVIEW 2012
    NI-VNA 15.0 includes the following new features:
    • Adds support for LabVIEW 2015 (32- and 64-bit)
    • Removes support for LabVIEW 2011
    NI-VNA 14.0 includes the following new features:
    • Adds support for LabVIEW 2014 (32- and 64-bit)
    • Adds support for output triggers
    • Adds support for loading sweep settings from a configuration file
    • PXIe-5630 Vector Network Analyzer
    • PXIe-5632 Vector Network Analyzer
    Device-specific information about these modules is included in the NI Vector Network Analyzers Help.
    NI-VNA 17.5 supports the following operating systems:
    • Windows Server 2012 R2 SP11 (64-bit)
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 requires Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note:  NI-VNA 17.5 does not support Windows Server non-R2 editions.
    Note  In 2016, the NI-VNA dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The NI-VNA will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the NI-VNA to an unsupported OS. Additionally, after installing the NI-VNA, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Minimum System Requirements
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows™/CVI™ or Microsoft Visual Studio®, before installing NI-VNA. To add support for ADEs installed after installing NI-VNA, modify your NI-VNA installation or launch the NI-VNA installer again.
    • NI LabVIEW 2014 SP1, 2015 SP1, 2016, or 2017
    • LabWindows/CVI 9.0.1 or later
    • Users\Public\Public Documents\National Instruments
    • Program Files\IVI Foundation\IVI\
    • (64-bit) $(IVIROOTDIR32) is configured as an environment variable on the target system.[/td][/tr]
      [tr][td][/td][td]If you upgraded an installation of IVI, your files may be located in the following location:
      • (32-bit) Program Files (x86)\IVI\
      [/td][/tr]
      [/table]
    NoteDocumentation for NI-VNA is located at Start»All Programs»National Instruments»NI-VNA»Documentation. The documentation set is composed of the following documents.
    [table]
    Document
    Format
    Description
    NI Vector Network Analyzers HelpHTML/Windows HelpContains primary help content for NI RF vector network analyzers. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to fundamental RF vector network analyzer concepts
    • Hardware device information
    • A complete reference for all NI-VNA programming functions and VIs
    Getting started guide for your devicePrinted and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Calibration procedures for your devicePDFContains calibration instructions for your device.
    NI-VNA ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Introduction to niVNAHTMLContains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues.
    NI-VNA IVI Compliance DocumentTXTContains information about IVI compliance.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    Accessing VIs and Functions
    NI–VNA palette VIs are available from the Functions»Measurement I/O»NI–VNA palette.
    NI–VNA functions are available in LabWindows/CVI from the Instrument menu. To load the NI–VNA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niVNA\niVNA.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–VNA examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–VNA or by directory structure at instr»niVNA.
    • Click the Search tab to search all installed examples by keyword. For example, search for "VNA" to locate all NI RF vector network analyzer examples.
    You can also access all the installed NI–VNA examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–VNA»Examples.
    Driver Version Naming Changes
    NI-VNA versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: . For example, NI-VNA 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-VNA 2.0.1. The first version released under the new numbering scheme is NI-VNA 14.0.
    Uninstalling NI-VNA
    As part of the NI-VNA 17.5 installation, the following software is installed. To completely remove the NI-VNA 17.5 installation from your system, you must also remove all of the following packages:
    • NI Measurement & Automation Explorer (MAX) 17.5
    • NI-VISA Run-Time Engine 17.5
    IVI Compliance Functionality
    NI-VNA 17.5 no longer installs IVI Compliance Package. NI-VNA 17.5 supports IVI configuration and runtime, but no longer supports the following features:
    LabVIEW and SVI IVI class driver APIs for developing IVI interchangable applications.IVI Class Simulation Drivers.IVI-COM Adapters.
    If you want to the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    You can access the software and documentation known issues list online. Refer to the NI-VNA 17.5 Known Issues at ni.com for an up-to-date list of known issues in NI-VNA 17.5.
    Licenses and Notices
    NI-VNA contains third-party software for which the following licenses and notices apply:
    © 2010–2018 National Instruments. All rights reserved.
    • EULAs are located in the \_Legal Information.txt for information on including legal information in installers built with NI products.
    374800E-01
    GMT+8, 2026-4-23 11:01
