TA的每日心情 | 奋斗 5 小时前 |
签到天数: 3866 天 连续签到: 59 天 [LV.Master]2000FPS
发表于 2022-2-28 12:25:52
NI LabVIEW 2021 SP1 Runtime Linux64ENG LV2021SP1运行版 64位Linux系统 64位英文版离线安装包下载
LabVIEW 2021 SP1 Linux RTE
发布日期:
22-2-16
包含的版本:
2021 SP1
openSUSE
Scientific Linux
RedHat
Ubuntu
Linux
语言:
英文
文件大小: 93532160 字节 (89.20 MB)
修改日期: 2022-01-18 18:30
MD5: c5fe2e16dfe6fb4ef0297574660d5e8a
SHA1: 0a07b3be5a618be8ff468ea6a13f78f3e5317eeb
SHA256: b53ea9b1983272b671611e88fdb898e3671715ac881104f6684163e67689f777
CRC32: cbb4f8c4
注册登录视觉论坛会员,购买附件查看
LV2021SP1 Linux RTE.txt
(536 Bytes, 下载次数: 2, 售价: 5 圆)
LabVIEW 2021 SP1 Readme for GNU/Linux
January 2022
LabVIEW Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
LabVIEW Manuals: New features, behavior changes, and other documentation
Supported Drivers
LabVIEW 2021 SP1 for Linux has the following requirements:
Linux
Processor Pentium 4 G1 (or equivalent) or later Pentium 4 G1 (or equivalent) or later
RAM 256 MB 1 GB
Screen Resolution 1024 x 768 pixels 1024 x 768 pixels
Operating System Linux kernel 2.6x or 3.x
GNU C Library (glibc) Version 2.11 or later for the Intel x86_64 architecture openSUSE Leap 15.2
openSUSE Leap 15.1
Red Hat Enterprise Linux 8
Red Hat Enterprise Linux 7
CentOS 8
CentOS 7
Ubuntu 18
Ubuntu 20
Disk Space 98 MB 1.1 GB for the complete installation
Color Palette N/A LabVIEW and the LabVIEW Help contain 16-bit color graphics. LabVIEW requires a minimum color palette setting of 16-bit color.
Temporary Files Directory N/A LabVIEW uses a directory for storing temporary files. NI recommends that you have several megabytes of disk space available for this temporary directory.
Adobe Reader N/A You must have Adobe Reader installed to search PDF versions of all LabVIEW manuals.
Note
LabVIEW 2021 SP1 for Linux is available only in 64-bit.
LabVIEW and LabVIEW Run-Time Engine require 64-bit processors that support SSE2 instructions.
To install LabVIEW modules and toolkits, refer to the readme of each product for installation instructions. The VI Analyzer Toolkits installs with the LabVIEW Professional Development System for Linux.
NoteVI Analyzer toolkit is not supported on Ubuntu in LabVIEW 2021 SP1.
Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Complete the following steps to install a patch on computers with LabVIEW 2021 SP1. Replace f# with the specific patch you are installing.
Close all NI software.
Download LV2021_f#LPatch.tgz into a folder. For example, download the file to ~/Desktop/Patch/LV2021_f#LPatch.tgz.
Unpack LV2021_f#LPatch.tgz. For example, cd ~/Desktop/Patch and tar -xzf LV2021_f#LPatch.tgz.
Run the installation script as root. For example, type su and enter the password. Then run ./INSTALL.
After the installation script reports that Patch installation completed, verify that the patch installed correctly. Select Help?About LabVIEW and look for 21.0.0f# on the right portion of the window.
Repeat these steps for all development systems where you want to install the patch.
LabVIEW 2021 SP1 for Linux supports the following modules and toolkits.
Control Design and Simulation Module1
MathScript Module2
VI Analyzer Toolkit3
Application Builder3
Supported Drivers
Refer to the NI website for information about drivers compatible with LabVIEW for Linux. To use hardware with LabVIEW 2021 SP1, install the latest version of the driver for the device. Refer to the readme of each driver for more information about system requirements and installation instructions.
Refer to the LabVIEW Help, accessible by selecting Help?LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
? 2004–2022 National Instruments Corporation. All rights reserved.
For patents covering the NI products/technology, refer to the appropriate location: Help?Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
374718T-01
