查看: 2360|回复: 0
[RTE运行引擎] NI LabVIEW 2021 SP1 Runtime Mac64ENG LV2021SP1运行版 64位苹果MAC系统 64位英文版离线安装包下载
    发表于 2022-2-28 12:30:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2021 SP1 Mac OS
    发布日期:
    22-2-16
    包含的版本:
    2021 SP1
    Mac OS
    语言:
    英文
    文件大小: 42507072 字节 (40.54 MB)
    修改日期: 2022-01-21 21:09
    MD5: 3dce614f1b13a854043b6a6293d450e7
    SHA1: c9ecf1d7c0bc81728c7ab442f22ab5f58e784f62
    SHA256: 5cdb5128ffbc4d3dd8bd71a757ce93ea890a0465c666198cdecb5d045c14a2b9
    CRC32: 10acc07b
    注册登录视觉论坛会员,购买附件查看
    LV2021SP1 MacOS RTE.txt (530 Bytes, 下载次数: 1, 售价: 2 圆)
    LabVIEW 2021 SP1 Readme for macOS
    January 2022
    Supported Drivers
    LabVIEW 2021 SP1 for macOS has the following requirements:
    macOS
    RAM256 MB2 GB
    Operating SystemmacOS 11 (x86_64 only)
    macOS 10.15
    macOS 10.15
    Note
    • LabVIEW 2021 SP1 for macOS is available only in 64-bit.
    Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    Complete the following steps to install a patch on computers with LabVIEW 2021 SP1. Replace f# with the specific patch you are installing.
    • Close all NI software.
    • Mount LabVIEW2021f#.dmg and run LabVIEW 2021 f# Patch.
    • Verify that the patch installs correctly. Select Help»About LabVIEW and look for 21.0.0f# on the right portion of the window.
    LabVIEW 2021 SP1 adds two Place VI Contents VIs to the Functions palette. OpenSSH Exec and PuTTY SSH Exec execute a system command on an SSH server specified by user@host with OpenSSH or PuTTY (plink) respectively.
    LabVIEW 2021 SP1 for macOS supports the following modules and toolkits.
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    Supported Drivers
    LabVIEW 2021 SP1 for macOS supports the following drivers. To use hardware with LabVIEW 2021 SP1, install the latest version of the driver for the device.
    • NI-488.2
    • NI-VISA
    Refer to the readme of each driver for more information about system requirements and installation instructions.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2021 SP1.
    374717T-01
    GMT+8, 2026-1-13 06:29
