查看: 2913|回复: 0
[NI软件套件] NI LabVIEW 2021 SP1 and Drivers x64Win10 64bitENG LV2021SP1和驱动64位英文版离线安装包下载
    发表于 2022-3-9 15:03:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:
    22-2-26
    包含的版本:
    2021 SP1
    语言:
    English英文
    LV2020SP1 64Eng and Drivers
    文件大小: 421955584 字节 (402.41 MB)
    修改日期: 2022-02-16 23:31
    MD5: f4d934677c2db05fccc5006cdfcef84d(官方正确)
    SHA1: fd8362b6d61442f5998d3b3fd53c1806c344b2ec
    SHA256: 46de69ef5370aa80b444a1751480f14c224eb3b846a46442fab204f1cceae95d
    CRC32: a3c5afcf
    请注册视觉论坛会员登录后购买附件下载查看
    LV2021SP1 and Drivers 64ENG.txt (594 Bytes, 下载次数: 7, 售价: 40 圆)
    LabVIEW 2021 SP1 Platform Readme
    February 2022
    With the LabVIEW Platform, one installation gives you access to nearly all products in the LabVIEW platform. If you purchased any LabVIEW modules or toolkits, install and activate them using the LabVIEW Platform installer to ensure compatibility with LabVIEW 2021 SP1. If you want to evaluate any of these add-ons before purchasing them, you can install these add-ons and try them for free for a set period of time.
    You can run the LabVIEW Platform installer on the following operating systems:
    NI installs the LabVIEW Platform using NI Package Manager. If you do not already have NI software installed, the LabVIEW Platform installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • When prompted, enter the serial number for each product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Complete the following steps to install products using the LabVIEW Platform media.
    • Insert the LabVIEW Platform media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2021 SP1.
    Installing Another Language Version
    LabVIEW 2021 SP1 allows different language versions in 32-bit and 64-bit to be installed on the same machine. For example, if you have a 64-bit English version of LabVIEW 2021 SP1 installed, you can install a 32-bit Japanese version. However, if you already have a 32-bit English version installed, you must uninstall that version before installing a 32-bit LabVIEW of another language.
    LabVIEW NXG 5.1 installs with all languages. Navigate to File >> Preferences to change the language version.
    LabVIEW Module and Toolkit Compatibility
    If you want to install LabVIEW modules and toolkits, ensure you install modules and toolkits that are compatible with LabVIEW 2021 SP1. If you attempt to install incompatible toolkit versions, you might corrupt your LabVIEW installation. If you install an incompatible version and corrupt your LabVIEW installation, visit ni.com/info and enter the Info Code repair to learn how to repair software in NI Package Manager.
    Products Included in the LabVIEW Platform
    The following products are included in the LabVIEW Platform. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Note  Some drivers included with previous versions of the LabVIEW Platform are not included with this release. Visit ni.com/downloads for the latest driver versions.
    Application Software
    Version
    Bitness
    G Web Development Software2022 Q164-bit
    LabVIEW2021 SP132-bit and 64-bit
    LabVIEW NXG5.1.064-bit
    NI Switch Executive 202121.5.032-bit and 64-bit
    Add-Ons
    Version
    Bitness
    JKI VI Package Manager2021 SP132-bit and 64-bit
    LabVIEW Advanced Signal Processing Toolkit202132-bit and 64-bit
    LabVIEW Control Design and Simulation Module202132-bit and 64-bit
    LabVIEW Datalogging and Supervisory Control Module202132-bit
    LabVIEW Datalogging and Supervisory Control Runtime202132-bit
    LabVIEW Desktop Execution Trace Toolkit202132-bit and 64-bit
    LabVIEW Digital Filter Design Toolkit202132-bit and 64-bit
    LabVIEW FPGA Compilation Tool for ISE 14.7202032-bit and 64-bit
    LabVIEW FPGA Compilation Tool for Vivado 2019.1202064-bit
    LabVIEW FPGA Compile Farm Toolkit202132-bit and 64-bit
    LabVIEW FPGA Module202132-bit and 64-bit
    LabVIEW MathScript Module202132-bit and 64-bit
    LabVIEW NXG FPGA Module5.1.064-bit
    LabVIEW NXG Real-Time Module5.1.064-bit
    LabVIEW NXG Web Module5.1.064-bit
    LabVIEW Real-Time Module202132-bit and 64-bit
    LabVIEW Sound and Vibration Toolkit202132-bit and 64-bit
    LabVIEW Unit Test Framework Toolkit202132-bit and 64-bit
    LabVIEW VI Analyzer Toolkit202132-bit and 64-bit
    Vision Development Module202132-bit and 64-bit
    Driver Software
    Version
    Bitness
    FlexRIO with Integrated I/O21.5.032-bit and 64-bit
    FlexRIO with Modular I/O21.5.032-bit and 64-bit
    IVI Compliance Package21.0.032-bit and 64-bit
    NI CompactRIO21.0.032-bit and 64-bit
    NI Industrial Controller Device Drivers21.0.032-bit and 64-bit
    NI R Series Multifunction RIO21.5.032-bit and 64-bit
    NI-488.221.5.032-bit and 64-bit
    NI-DAQmx21.3.032-bit and 64-bit
    NI-DCPower21.5.032-bit and 64-bit
    NI-DMM21.3.032-bit and 64-bit
    NI-FGEN21.3.032-bit and 64-bit
    NI-HSDIO21.5.032-bit and 64-bit
    NI-IMAQ21.0.032-bit and 64-bit
    NI-IMAQ I/O21.0.032-bit and 64-bit
    NI-IMAQdx21.0.032-bit and 64-bit
    NI-Industrial Communications for EtherNet/IP21.0.032-bit and 64-bit
    NI-SCOPE21.0.032-bit and 64-bit
    NI-SWITCH21.3.032-bit and 64-bit
    NI-Serial21.5.032-bit and 64-bit
    NI-Sync21.3.032-bit and 64-bit
    NI-VISA21.5.032-bit and 64-bit
    NI-XNET21.5.032-bit and 64-bit
    PXI Platform Services21.5.032-bit and 64-bit
    • LabVIEW 2021 SP1 installs the LabVIEW Database Connectivity Toolkit and the LabVIEW Report Generation Toolkit for Microsoft Office.
    • The DataFinder Toolkit no longer exists. You can now find the functionality of this toolkit on the DataFinder Connectivity palette in LabVIEW 2021 SP1.
    • In 2019, the Statechart Module moved to the LabVIEW Tools Network.
    LabVIEW 2021 SP1 Platform no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2003–2022 National Instruments Corporation. All rights reserved.
    377933F-01
    GMT+8, 2026-1-13 07:51
