查看: 3333|回复: 0
[NI软件产品] LabVIEW 2014SP1 FPGA Module Xilinx Compilation Tools Win32Eng LV2014SP1 FPGA编译工具(ISE 14.7)
    2 小时前
    发表于 2020-8-19 23:47:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2014SP1ISE14,4.37GB
    发布日期
    15-3-5
    受支持的操作系统
    Windows XP 32-bit
    Windows XP 64-bit
    Windows Vista 32-bit
    Windows Vista 64-bit
    Windows 7 32-bit
    Windows 7 64-bit
    语言
    English
    校验和
    MD5:8CB1920841931771F55BDEF5050E9401
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGA-ISE14.7-CT2014SP1.txt (280 Bytes, 下载次数: 4, 售价: 10 圆)
    LabVIEW 2014 SP1 FPGA Module Xilinx Compilation Tools for Windows DVD Readme
    December 2014
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows DVD, including system requirements and installation instructions.
    With the LabVIEW 2014 SP1 FPGA Module Xilinx Compilation Tools for Windows DVD, one installation gives you access to Xilinx Compilation Tools for Vivado 2013.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile your FPGA VIs on a Windows computer. You also must install these tools on the development computer if you plan to create simulation exports, configure the IP Integration Node, incorporate Xilinx IP, use third-party simulation, or use the Configure Component-Level IP wizard.
    The LabVIEW FPGA Module Xilinx Compilation Tools for Windows have the following system requirements:
    • 11 GB of disk space
      • Windows XP Professional (32-bit and 64-bit)
    Note: National Instruments recommends a 64-bit OS for the computer on which you install the Xilinx Compilation Tools.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014 SP1.
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Windows. Refer to the support document at ni.com for more information about the NI hardware supported by each Xilinx compilation tool.
    Use the Xilinx compilation tools for Vivado 2013.4 to compile FPGA VIs for the following NI-RIO devices:
    • NI USB-785xR
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-797xR
    • NI cRIO-9068, NI cRIO-903x
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx compilation tools for ISE 14.7 to compile FPGA VIs for the following NI-RIO devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. Visit ni.com/info and enter the Info Code 2014SP1FPGATools101 to download the Xilinx 10.1 compilation tools.
    You can find installation instructions for the Xilinx compilation tools for Windows in the LabVIEW FPGA Module Release and Upgrade Notes, which are available online at ni.com/manuals and on the LabVIEW 2014 SP1 Platform media.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    NI LabVIEW FPGA Module Xilinx Compilation Tools for Windows Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The NI LabVIEW FPGA Module Xilinx Compilation Tools for Windows will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of the FPGA Module Xilinx Compilation Tools for Windows that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    Info Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2012–2014 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW\FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    \LabVIEW\FPGA\Legal
    374738B-01
    GMT+8, 2026-4-23 10:50
