查看: 3587|回复: 0
[NI软件产品] LabVIEW 2014SP1 FPGA Module Xilinx Compilation Tools Linux32Eng LV2014SP1 FPGA编译工具(Vivado 2013.4)
    2 小时前
    发表于 2020-8-26 22:29:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2014sp1cw-linux-vivado2013_4,3.41GB
    发布日期
    15-3-5
    受支持的操作系统
    Red Hat Enterprise Linux 6.3 (32-bit)
    语言
    English
    校验和
    MD5: 1e8b07a9654cdc5d4d76d91a541743df
    SHA1: 7de051251da9e64378b08ba56a2990fc64137e83
    SHA256: 7e2f01078c0a5f6f3b5bc6389c967edb1c022d8bde40a5f1cd556bf8d25dc01b
    CRC32: 4e92eed3
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-Vivado2013.4-LV2014SP1.txt (292 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2014 SP1 FPGA Module Xilinx Compilation Tools for Linux DVD Readme
    December 2014
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux DVD, including system requirements and installation instructions.
    With the LabVIEW 2014 SP1 FPGA Module Xilinx Compilation Tools for Linux DVD, one installation gives you access to Xilinx Compilation Tools for Vivado 2013.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile your FPGA VIs on a Linux computer.
    The LabVIEW FPGA Module Xilinx Compilation Tools for Linux have the following requirements:
    • 11 GB of disk space
    • Red Hat Enterprise Linux 6.3
    Note: National Instruments recommends a 64-bit OS for the computer on which you install the Xilinx Compilation Tools.
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Refer to the support document at ni.com for more information about the NI hardware supported by each Xilinx compilation tool.
    Use the Xilinx compilation tools for Vivado 2013.4 to compile FPGA VIs for the following NI-RIO devices:
    • NI USB-785xR
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-797xR
    • NI cRIO-9068, NI cRIO-903x
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Xilinx Compilation Tools for ISE 14.7
    Use the Xilinx compilation tools for ISE 14.7 to compile FPGA VIs for the following NI-RIO devices:
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PCIe-784xR, NI PCIe-785xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI sbRIO-960x, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    • NI 9144, NI 9146, NI 9148, NI 915x
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Insert the LabVIEW FPGA Module Xilinx Compilation Tools for Linux installation media. Use mount /mnt/cdrom to mount the media. On some Linux systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter cd /mnt/cdrom/CWXILINX14 or cd /mnt/cdrom/CWVIVADO2013.
    • To run the installation script, enter sh ./INSTALL.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    © 2012–2014 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW\FPGA\Legal
    The Python_2.5_notice.pdf file contains a third-party copyright notice for third-party components used by certain FPGA Module features. The following directory is the default installation location for the file, but the location might vary depending on the configuration of the local computer:
    \LabVIEW\FPGA\Legal
    374740B-01
    GMT+8, 2026-4-23 10:49
