查看: 3639|回复: 0
[NI软件产品] LabVIEW 2020 FPGA Module Xilinx Compilation Tools Linux32Eng LV220 FPGA编译工具(ISE 14.7)
    2 小时前
    发表于 2020-8-26 22:25:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-LVFPGA2020-LinuxISE,3.74GB
    发布日期
    20-5-15
    受支持的操作系统
    Red Hat Enterprise Linux 6.5
    语言
    English
    校验和
    MD5: 9d3a92e8d696a2c6c0f6038998c57097
    SHA1: 9906a5690d8a13a20c9f9530f8d42ace34429e4b
    SHA256: 942a1fbef12f3b489150f45052a5c543dcf4822191f7947354a636559008810f
    CRC32: c14606c5
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-ISE14.7-LV2020.txt (283 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2020 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2019.1 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2019.1 has the following system requirements:
      • Red Hat Enterprise Linux 7.4/7.5/7.6 (64-bit)
      • CentOS 7.4/7.5/7.6 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit)
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Use the Xilinx Compilation Tool for Vivado 2019.1 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/6593/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659x/782xR/784x/785x/786x/786xR/7902R/791x/793xR/797xR/798x/799x
    • roboRIO
    • sbRIO-9603/9608/9609/9628/9629/9638/9651/96x7
    • USB-784xR/785xR
    • USRP-RIO devices
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • IC-312x
    • NI-915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2019_1 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740L-01
    GMT+8, 2026-4-23 10:50
