查看: 1744|回复: 0
[RTE运行引擎] NI RFmx TD-SCDMA 21.8.0 Runtime x64Win10 64bitENG RFmx蜂窝测试TD-SCDMA21.8.0运行版-64位
    昨天 07:53
     楼主| 发表于 2022-6-17 17:56:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:
    2022/4/19
    包含的版本:
    21.8.0完整版
    语言:
    英文
    应用程序位数:
    64位
    文件大小: 606836736 字节 (578.72 MB)
    修改日期: 2022-04-19 20:45
    MD5: 229ad061f52ea549082b65cec88878be(官方正确)
    SHA1: 2b3ea46f4fb930d202b9c6d168e55e5604648322
    SHA256: ca2ef29b24d88883bdc2a543b297eefefa399e45b0715fc10e7b86e5ed4d51ad
    CRC32: 4c86fabb
    注册登录视觉论坛用户,购买附件查看下载地址
    RFmx TDSCDMA21.8.0RTE64.txt (587 Bytes, 下载次数: 0, 售价: 5 圆)
    RFmx TD-SCDMA 21.8 Readme
    April 2022
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx TD-SCDMA is application software that provides simple access to the most advanced optimization techniques such as multimeasurement parallelism and multi-DUT measurements. The result is fast, high-quality measurements with minimal software development efforts. Using this software, you can perform physical layer analysis on TD-SCDMA cellular signals including MODACC, ACPR, CHP, and SEM. RFmx TD-SCDMA is completely interoperable with all RFmx APIs.
    RFmx TD-SCDMA 21.3 includes the following new feature:
    RFmx TD-SCDMA 20.0 includes the following new features:
    RFmx TD-SCDMA 19.1 includes the following new feature:
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 21.8 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 21.8 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 21.8 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 21.8, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by RFmx TD-SCDMA
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    ItemInstalled Location
    Import Library files
    Select Start » National Instruments » RFmx TD-SCDMA » RFmx Soft Front Panel to launch the RFmx Soft Front Panel (64-bit).
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » NI-RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    RFmx TD-SCDMA HelpHTML/Windows HelpContains primary help content for RFmx TD-SCDMA. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to RFmx TD-SCDMA
    • A complete reference for all RFmx TD-SCDMA programming functions and VIs
    RFmx TD-SCDMA 21.8 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6:
    The following is the behavior change in RFmx TD-SCDMA 19.1 from RFmx TD-SCDMA 19.0:
    • Obsoleted RFmxTDSCDMA Analyze (IQ) and RFmxTDSCDMA Analyze (Spectrum) APIs. Use RFmxTDSCDMA Analyze (IQ, 1 Wfm) and RFmxTDSCDMA Analyze (Spectrum, 1 Wfm) APIs instead.
    The following are the behavior changes in RFmx TD-SCDMA 19.0 from RFmx TD-SCDMA 3.0:
    • Dropped support for RFmx TD-SCDMA Measurement Interactive Panel
    © 2014–2022 National Instruments Corporation. All rights reserved.
    375525U-01
    GMT+8, 2026-4-24 05:17
