查看: 181|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2026 Q1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA26.0.0
    6 小时前
  • 签到天数: 3857 天
    连续签到: 50 天
     楼主| 发表于 2026-3-20 10:07:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx TD-SCDMA
    发布日期:2026/1/28
    包含的版本:2026 Q1完整版/运行版,版本号26.0.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2682933248 字节 (2.50 GB)
    修改日期: 2026-02-07 16:37
    MD5: e3b12e16e85c898c902ddedf12aae117
    SHA1: 7fca5ff1f8a68965ed4215d2e1b6993e56829bdf
    SHA256: 5f3c4f85b62bf1eac35ab3af1d0a62309caf7779db2ec3eabf3631c6a42c65f3
    SHA512: 2f83f3f47da691ba941d3c2f04fd2f1e40c69ba28662adc0c72821617fdfd46bf0d7b4c78b08ae61a50d974ef4af628a070c14dfff9d7c7688c7fdab4ef9f2bc
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA 2026 Q1.txt (688 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1030436864 字节 (982.70 MB)
    MD5: 69b0ed368ffa808f02e46d768d15194b
    SHA1: 63279346ca2916883b832c898065857184429597
    SHA256: fe8c33ba91608fc2a2c04cc30e1a1c80489c7bade8a6e70ce936880948a7c325
    SHA512: d21a20c212db5da349a9b69f84f2d7abc6cf5a935b89442b3210aca5e05465a1cbaecd29e01a9b407ab42cea9c92b2df337c4c51e5e812b319aae4b090d91516
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA 2026 Q1RTE.txt (713 Bytes, 下载次数: 0, 售价: 5 圆)
    2026Q1未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    This file contains important information about the RFmx TD-SCDMA, including system requirements, and installation instructions.
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    Installed Software
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA has the following requirements:
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    Required Software
    If you are using the RFmx TD-SCDMA .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx TD-SCDMA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx TD-SCDMA installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Installed Software
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    The following is the behavior change in RFmx TD-SCDMA 20.7 from RFmx TD-SCDMA 20.6:
    GMT+8, 2026-4-15 14:27
