查看: 2598|回复: 0
[NI软件套件] NI Test Workflow 2022 Q1 Pro x64Win10 64bitEng NI测试工作流程21.5标准版-64位英文
    5 小时前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-3-25 16:40:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    专业版包含:
    应用程序软件
    LabVIEW专业版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem专业版
    TestStand
    附加软件
    LabVIEW VI Analyzer工具包
    发布日期:
    2022/2/16
    包含的版本:
    2022Q1专业版
    应用程序位数:
    64位
    语言:
    英文
    文件大小: 10878179328 字节 (10.13 GB)
    修改日期: 2022-02-16 23:42
    MD5: c1109a522e00065cf9119f74aadb3fcf
    SHA1: 6f32c5f6ae311caa3e81e80f14d2674254f3ef5e
    SHA256: 32017630dd7018f77fbca0bd03401c137bf1023023e06ff3ef0af2245395d377
    CRC32: 7390b91c
    注册登录视觉论坛,购买附件查看下载地址
    NI TestWorkflow2022Q1 专业版64位ENG.txt (619 Bytes, 下载次数: 0, 售价: 30 圆)
    2022Q1版无自述文件,参考2021Q4的自述文件
    Test Workflow Pro 2021 Q4 Readme
    November 2021
    This file contains installation instructions and compatibility information for Test Workflow Pro.
    Installation InstructionsInstalling and Activating the Test Workflow Pro
    NI installs Test Workflow Pro using NI Package Manager. If you do not already have NI software installed, Test Workflow Pro installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow Pro. For more information on Test Workflow Pro activation, refer to NI Software Activation.
    Complete the following steps to install products using the Test Workflow Pro media.
    • Insert the Test Workflow Pro installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the Test Workflow Pro media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the Test Workflow Pro media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Products Included on the Test Workflow Pro Media
    The following products are included on the Test Workflow Pro media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Note  Visit ni.com/downloads for the latest driver versions.
    Application Software
    Version
    Bitness
    LabVIEW Professional202132-bit and 64-bit
    G Web Development Software 202121.0.032-bit and 64-bit
    InstrumentStudio 202121.0.064-bit
    FlexLogger2021 R464-bit
    DIAdem Professional202164-bit
    TestStand202132-bit and 64-bit
    Add-Ons
    Version
    Bitness
    LabVIEW Advanced Signal Processing Toolkit202132-bit and 64-bit
    LabVIEW Datalogging and Supervisory Control Module202132-bit
    LabVIEW Datalogging and Supervisory Control Runtime202132-bit
    LabVIEW Desktop Execution Trace Toolkit202132-bit and 64-bit
    LabVIEW Digital Filter Design Toolkit202132-bit and 64-bit
    LabVIEW Unit Test Framework Toolkit202132-bit and 64-bit
    LabVIEW VI Analyzer Toolkit202132-bit and 64-bit
    Note  The LabVIEW Professional Development System installs the LabVIEW Database Connectivity Toolkit, the LabVIEW Report Generation Toolkit, the LabVIEW Application Builder, the LabVIEW Desktop Execution Trace Toolkit, the LabVIEW Unit Test Framework Toolkit, and the LabVIEW VI Analyzer Toolkit.
    To compare the products included in NI Software Suites, including Test Workflow Pro, refer to Compare NI Software Suites.
    Test Workflow Pro does not support Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2021 National Instruments Corporation. All rights reserved.
    378766A-01
    GMT+8, 2026-4-24 12:56
