查看: 2478|回复: 0
[NI软件套件] NI Test Workflow 2021 Q4 Standard x64Win10 64bitEng NI测试工作流程21.3标准版-64位英文
    5 小时前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-3-25 16:11:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Test Workflow测试工作流程
    标准版包含:
    应用程序软件
    LabVIEW完整版
    G Web开发软件
    InstrumentStudio
    FlexLogger
    DIAdem高级版
    发布日期:
    2021/12/7
    包含的版本:
    2021Q4标准版
    应用程序位数:
    64位
    语言:
    英文
    文件大小: 8831309824 字节 (8.22 GB)
    修改日期: 2021-12-08 06:38
    MD5: d126839b7b03d2f4f8e9a156dda0dee5
    SHA1: a86b29832990016f0e8fdfeec4a25508f80aad80
    SHA256: c38493658cb1fe25ad4a09fa4a8b773058a7b6e311a9aac917fbaa2430991563
    CRC32: 3d21216f
    注册登录视觉论坛,购买附件查看下载地址
    NI TestWorkflow2021Q4 标准版64位ENG.txt (630 Bytes, 下载次数: 0, 售价: 20 圆)
    Test Workflow Standard 2021 Q4 Readme
    November 2021
    This file contains installation instructions and compatibility information for Test Workflow Standard.
    • Test Workflow Standard Release Notes: Known issues and other notes about this release
    Products Included on the Test Workflow Standard Media
    Installation InstructionsInstalling and Activating Test Workflow Standard
    NI installs Test Workflow Standard using NI Package Manager. If you do not already have NI software installed, Test Workflow Standard installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate Test Workflow Standard. For more information on Test Workflow Standard activation, refer to NI Software Activation.
    Complete the following steps to install products using the Test Workflow Standard media.
    • Insert the Test Workflow Standard installation media.
    Save the media in order to modify or repair your installation or to distribute NI software with your custom-built installers.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the Test Workflow Standard media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the Test Workflow Standard media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    The following products are included on the Test Workflow Standard media. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Note  Visit ni.com/downloads for the latest driver versions.
    Application Software
    Version
    Bitness
    LabVIEW Full202132-bit and 64-bit
    G Web Development Software 202121.0.032-bit and 64-bit
    InstrumentStudio 202121.0.064-bit
    FlexLogger2021 R464-bit
    DIAdem Advanced202164-bit
    To compare the products included in NI Software Suites, including Test Workflow Standard, refer to Compare NI Software Suites.
    Test Workflow Standard does not support Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2021 National Instruments Corporation. All rights reserved.
    • EULAs are located in the \_Legal Information.txt for information on including legal information in installers built with NI products.
    378765A-01
    GMT+8, 2026-4-24 12:56
