查看: 3263|回复: 0
[NI软件套件] NI Static Test Software Suite 1.2 x64Win10 64bitEng NI静态测试软件套件1.2
    5 小时前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-3-21 15:27:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    Static Test Software Suite静态测试软件套件
    静态测试软件套件包括帮助处理在静态或疲劳结构测试中收集数据的软件,此软件用于航空航天应用程序。
    静态测试软件套件包括用于航空航天数据采集和测试开发环境的FlexLogger、SystemLink服务器、静态数据查看器(Static Data Viewer)等应用软件。该套件可与连接至应变计的CompactDAQ系统一起使用,用于测试航空器机身、太空运载工具等结构。FlexLogger帮助测试操作员配置测试,记录从几分钟到几周或更长时间的应变数据,而结构工程师可以通过静态数据查看器Web应用程序远程访问测试数据,以便分析结构的行为。
    1.2
    发布日期
    2021/12/1
    包含的版本
    1.2完整版
    受支持的操作系统
    应用程序位数
    64位
    语言
    英文
    校验和
    文件大小: 6443450368 字节 (6.00 GB)
    修改日期: 2021-11-29 22:49
    MD5: 6f757621262a35e1d1e9a710a305b7f7
    SHA1: 3e6df514731abf528c06c19a9b812b976230457b
    SHA256: cf385a140292b25574da3e2d4f97c89c769655adf5327ddc2811656535afe9cd
    CRC32: d25fd4b9
    注册登录视觉论坛,购买附件查看下载地址
    NI STSS1.2.txt (637 Bytes, 下载次数: 0, 售价: 15 圆)
    Static Test Software Suite 1.2 Readme
    December 2021
    This file contains installation instructions and compatibility information for the Static Test Software Suite used in the Static Structural Test Reference Architecture.
    For known issues, bugs fixed since the last release, and other notes about a Static Test Software Suite release, visit Static Test Software Suite Release Notes.
    You can access the Static Structural Test Reference Architecture documentation by search at ni.com.
    The Static Test Software Suite includes FlexLogger, the Static Data Viewer web application, and SystemLink Server for use in aerospace data acquisition and test development environments.
    Included Components
    Static Test Software Suite 1.2 includes the following major components:
    • FlexLogger 2021 R4
      • NI-DAQmx 21.0
      • NI-DAQmx cDAQ Firmware 21.0
      • FlexLogger CLI 21.3 (FlexLogger Spreadsheet Importer)
    • Static Data Viewer 1.2
    • SystemLink 2021 R3 (Server only)
    Note   The Static Test Software Suite does not include licenses for FlexLogger and SystemLink. You must purchase separate licenses for each product.
    Note   The Static Test Software Suite does not include a license for Microsoft Office. You must purchase a separate license for Microsoft Excel.
    Static Test Software Suite 1.2 requires the following:
    • Intel Xeon E-2286G CPU 4.0 GHz, 6-Core
    • 64 GB RAM
    • At least 30 GB of disk space
    • Gigabit Ethernet adapter (x2) (one dedicated for instrumentation network)
    • Windows 10 64-bit
    • DHCP server support or an external DHCP-enabled router
    Download the Static Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Note   During FlexLogger installation, ensure that NI-DAQmx cDAQ Firmware is selected for download in the Additional items you may wish to install page. It is selected by default. The downloaded cDAQ firmware is required to update the firmware on the cDAQ chassis in the reference architecture.
    © 2021 National Instruments Corporation. All rights reserved.
    378599B-01
    GMT+8, 2026-4-24 12:55
