查看: 2198|回复: 0
[NI软件套件] NI FRC LabVIEW 2020 Win32Eng FIRST机器人竞赛软件套件FRC2020(基于LabVIEW2019)
    5 小时前
  • 签到天数: 3866 天
    连续签到: 59 天
    发表于 2022-3-14 18:10:03 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    FRC LabVIEW软件
    FRC LabVIEW软件提供的组件专为FIRST机器人竞赛(FRC)参与者使用LabVIEW编程机器人而开发。
    FRC LabVIEW软件是一个软件套件,为FRC提供了使用LabVIEW所需的软件组件。该套件包括LabVIEW专业版以及LabVIEW Real-Time模块和LabVIEW视觉开发模块等软件附件。FRC LabVIEW软件还包括相关的驱动程序。
    发布日期
    2019/11/4
    包含的版本
    2020专业版
    受支持的操作系统
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    应用程序位数
    32位
    语言
    English
    校验和
    文件大小: 8281763840 字节 (7.71 GB)
    修改日期: 2019-11-04 14:15
    MD5: 2bed0a8236a5dd452c96a019450a9ecf(官方正确)
    SHA1: ece33650f9227cedd9be57748bc7ff97223c5a44
    SHA256: 7e33d9a3d88b34d11af40b3a18656d1d640679ad6c342151fe247d6f15cb9a9e
    CRC32: ee2decc2
    FRC LabVIEW2020.txt (607 Bytes, 下载次数: 0, 售价: 30 圆)
    LabVIEW Software for FRC 2020 Readme
    September 2019
    The LabVIEW Software for FRC 2020 includes the LabVIEW 2019 Professional Development System and other software components that you can use to program your robot.
    To obtain the FRC API, examples, and utilities like the Driver Station and roboRIO Imaging Tool, install the FRC Game Tools 2020 update suite after the FRC kickoff. Visit the FRC Resource Hub for more information about the software updates after kickoff.
    Installation Options
    LabVIEW Software for FRC 2020 has two installation options. Teams Using LabVIEW for robot programming should select installation option 1. Teams using text-based languages should select installation option 2.
    1. Installation Instructions for Teams Using LabVIEW for Development
    This option allows you to program your robot in LabVIEW, perform vision analysis, and capture from USB cameras.
    • Launch the installer. This will initiate a pre-install of NI Package Manager. After the NI package manager installation completes, you will be presented with a list of software to install.
    • On the "Select Products" dialog, accept the default selections. This includes:
      • LabVIEW (32-bit) English - 2019
      • LabVIEW Real-Time Module English - 2019
      • Vision Development Module - 2019
      • LabVIEW Robotics Module for FRC - 2019
      • NI CompactRIO - 19.0.0
      • NI-IMAQdx driver - 19.0.0
    • On the "Additional items you may wish to install" dialog, accept the default selections. NOTE: If you do not accept the default selections, it is likely that some components required for programming your robot will not be installed.
    • Accept the licensing agreements and proceed through the installation wizard.
    This option has the following system requirements:
    • Operating System: Windows 10/8.1/7 SP1
    • Disk Footprint: 15.2 GB
    2. Installation Instructions for Teams Using Text-Based Languages for Development
    This option allows you to perform vision analysis and capture from USB cameras from text-based languages.
    • On the "Select Products" dialog, select the following:
    • Disk Footprint: 8.2 GB
    Additional NI Software
    You may also download the following NI software from ni.com and license it using your serial number.
    • Multisim Education Edition
    • Ultiboard Education Edition
    • LabVIEW Statechart Module
    © 2009–2019 National Instruments. All rights reserved.
    378191A-01
    GMT+8, 2026-4-24 12:57
