查看: 3847|回复: 0
[NI软件产品] NI-WLAN Test Toolkit 20.0 Win32/64Eng NI无线局域网测试工具包20.0
    发表于 2021-3-3 23:57:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    WLAN测试工具包
    WLAN测试工具包为WLAN 802.11a/b/g/j/p/n/af/ah/ac/ax测试应用提供了信号生成和分析功能。
    WLAN测试工具包是一款应用软件,旨在扩展NI RF仪器用于WLAN 802.11信号生成和分析的功能。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/af/ah/ac/ax信号进行分析。WLAN测试工具包具有灵活的配置,可进行减损处理,提供每用户测量结果报告以及MIMO和分集配置,因而可支持多站点信号。借助WLAN测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    Win32/64Eng
    20.0
    文件大小: 2137878528 字节 (1.99 GB)
    修改日期: 2020-05-15 14:16
    MD5: 2afa5b2b76a97ba959bd2b3d95154fdd(官方正确)
    SHA1: 13d4735dedea2fd301d6853a3816f06613803ce5
    SHA256: ab335cf165a237c76224286d7c987a8aef3c5e011ac3de572ceaae4a23769b1a
    CRC32: 01453a56
    WLAN20.0.txt (632 Bytes, 下载次数: 3, 售价: 10 圆)
    NI WLAN Toolkit 20.0 Readme
    May 2020
    This file contains important information about the NI WLAN Toolkit, including system requirements, and installation instructions.
    NI WLAN Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The NI WLAN Toolkit gives you direct and fine control over the generation and analysis of IEEE 802.11a/b/g/n/ac and ax signals, as well as 802.11j/p/ah/af waveforms, with industry-leading speed and accuracy. It empowers you to characterize, validate, and test a variety of WLAN connectivity products, such as RF front end components, wireless modules, and user devices.
    New Features New Features in WLAN Analysis New Features in WLAN Generation
    Vector Signal Analyzers
    • PXIe-5663
    • PXIe-5663E
    • PXIe-5665
    • PXIe-5668
    Vector Signal Transceivers
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5840
    • PXIe-5841
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    Vector Signal Generator
    • PXIe-5673
    • PXIe-5673E
    NI WLAN Toolkit has the following requirements:
    • Pentium IV Processor or equivalent
    • At least 2 GB of disk space
    • 4 GB RAM
    Required Software
    • NI-RFSA 15.0 or later
    • NI-RFSG 15.0 or later
    • PXI Platform Services 14.0
    NI WLAN Toolkit 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, NI WLAN Toolkit dropped support for all 32-bit Windows operating systems. NI WLAN Toolkit will not install or run on an unsupported OS. Refer to NI WLAN Toolkit Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    Note   In 2016, NI WLAN Toolkit dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. You cannot deploy or distribute applications that use NI WLAN Toolkit 20.0 to an unsupported OS. Additionally, after installing NI WLAN Toolkit 20.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI WLAN Toolkit 20.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI WLAN Toolkit
    LabVIEW2017 SP1, 2018 SP1, 2019 SP1, or 2020
    LabWindowsa„¢/CVIa„¢2013 SP2 and later
    TestStand4.2.0 for TestStand sequences
    NI installs NI WLAN Toolkit using NI Package Manager. If you do not already have NI software installed, NI WLAN Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate NI WLAN Toolkit. For more information on NI WLAN Toolkit activation, refer to National Instruments Software Activation .
    Accessing the APILabVIEW
    NI WLAN Toolkit VIs are available in LabVIEW from the Functions » RF Communications » WLAN palette.
    LabWindows/CVI
    NI WLAN Toolkit functions are available in LabWindows/CVI from the Library menu.
    Interactive Example
    To launch the WLAN Interactive Example, navigate to the following locations:
    WLAN Analysis Interactive Example
    • Start » All Programs » National Instruments » WLAN Analysis » WLAN Analysis Interactive Example
    WLAN Generation Interactive Example
    • Start » All Programs » National Instruments» WLAN Generation» WLAN Generation Interactive Example .
    The documentation set is composed of the following documents.
    DocumentFormatDescriptionPath
    NI WLAN Analysis Toolkit HelpHTML/Windows HelpInformation about WLAN Analysis. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to WLAN Analysis
    • A complete reference for all WLAN Analysis programming functions and VIs
    Start»All Programs»National Instruments»WLAN Analysis»WLAN Analysis Toolkit Documentation
    NI WLAN Generation Toolkit HelpHTML/Windows HelpInformation about WLAN Generation. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to WLAN Generation
    • A complete reference for all WLAN Generation programming functions and VIs
    Start»All Programs»National Instruments»WLAN Generation»WLAN Generation Toolkit Documentation
    NI WLAN Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»WLAN»NI WLAN Toolkit Readme
    To access all the installed NI WLAN Toolkit examples for LabVIEW and LabWindows/CVI, navigate to the following locations:
    • Start » All Programs » National Instruments » WLAN Analysis Toolkit » WLAN Analysis Toolkit Examples
    • Start » All Programs » National Instruments » WLAN Generation Toolkit » WLAN Generation Toolkit Examples
    Behavior Changes Behavior Changes in WLAN Analysis Behavior Changes in WLAN Generation
    The following are the known issues in NI WLAN Toolkit.
    IDKnown IssueReported Version
    741171RFSA Fetch Error is observed when there is a transition from multi-record single-instrument to single-record multi-instrument acquisition on PXIe-5840/5830/5831,
    if NI-RFSA handles are not closed between transitions.
    18.2
    Bug Fixes Bug Fixes in WLAN Analysis Bug Fixes in WLAN Generation
    NI WLAN Toolkit will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2009–2020 National Instruments. All rights reserved.
    378072C-01
    GMT+8, 2026-4-23 09:17
