查看: 3594|回复: 0
[NI软件产品] NI-WLAN Test Toolkit 19.1 Win32/64Eng NI无线局域网测试工具包19.1
    发表于 2021-3-3 23:56:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    WLAN测试工具包
    WLAN测试工具包为WLAN 802.11a/b/g/j/p/n/af/ah/ac/ax测试应用提供了信号生成和分析功能。
    WLAN测试工具包是一款应用软件,旨在扩展NI RF仪器用于WLAN 802.11信号生成和分析的功能。该软件可以通过误差矢量幅度(EVM)、频谱发射屏蔽(SEM)、发射功率(TXP)等符合标准的物理层测量,对802.11a/b/g/j/p/n/af/ah/ac/ax信号进行分析。WLAN测试工具包具有灵活的配置,可进行减损处理,提供每用户测量结果报告以及MIMO和分集配置,因而可支持多站点信号。借助WLAN测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
    Win32/64Eng
    19.1
    文件大小: 2140209152 字节 (1.99 GB)
    修改日期: 2019-07-23 14:12
    MD5: 57af0f8f1c775c4738fc9c9f213c4da9(官方正确)
    SHA1: c3ed02cd7f34012b8676f9b74ffee12bf2ed0d4c
    SHA256: 43208788b62164d885d26d216037abb7fbf1204f70b2384c80663b06206e94e7
    CRC32: eb770f51
    WLAN19.1.txt (609 Bytes, 下载次数: 0, 售价: 10 圆)
    WLAN Toolkit 19.1 Readme
    July 2019
    This file contains important information about the WLAN Toolkit, including installation instructions, new features, bug fixes, and known issues.
    LabWindows/CVI
    Soft Front Panel
    WLAN Toolkit Drops Support for Windows 7 and Windows Server 2008 R2 in 2021
    The WLAN Toolkit gives you direct and fine control over the generation and analysis of IEEE 802.11a/b/g/n/ac and ax signals, as well as 802.11j/p/ah/af waveforms, with industry-leading speed and accuracy. It empowers you to characterize, validate, and test a variety of WLAN connectivity products, such as RF front end components, wireless modules, and user devices.
    New Features New Features in WLAN Analysis New Features in WLAN Generation
    System RequirementsWLAN Toolkit has the following requirements:
    • Pentium IV Processor or equivalent
    • At least 2 GB of disk space
    • 4 GB RAM
    Required Software
    • NI-RFSA 15.0 or later
    • NI-RFSG 15.0 or later
    • PXI Platform Services 14.0
    WLAN Toolkit 19.1 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    Note In 2019, WLAN Toolkit dropped support for all 32-bit Windows operating systems. Refer to WLAN Toolkit Drops Support for Windows 7 and Windows Server 2008 R2 in 2021 for information about future OS support.
    WLAN Toolkit 19.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by WLAN Toolkit
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    LabWindows™/CVI™2013 SP2 and later
    TestStand4.2.0 for TestStand sequences
    NI automates WLAN Toolkit installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    WLAN Toolkit is available for download from NI Software Product Downloads.
    The following table shows the hardware models supported in WLAN Toolkit:
    Hardware ProductHardware Model
    Vector Signal AnalyzerPXIe-5663/5663E
    PXIe-5665
    PXIe-5668R
    Vector Signal TransceiverPXIe-5830/5831
    PXIe-5820
    PXIe-5840
    PXIe-5644R
    PXIe-5645R
    PXIe-5646R
    Vector Signal GeneratorPXIe-5673/5673E
    Behavior Changes Behavior Changes in WLAN Analysis Behavior Changes in WLAN Generation
    IDKnown Issue
    741171RFSA Fetch Error is observed when there is a transition from multi-record single-instrument to single-record multi-instrument acquisition on PXIe-5840/5830/5831, if NI-RFSA handles are not closed between transitions.
    Bug Fixes Bug Fixes in WLAN Analysis Bug Fixes in WLAN Generation
    Accessing the APILabVIEW
    WLAN Toolkit VIs are available in LabVIEW from the Functions»RF Communications»WLAN palette.
    LabWindows/CVI
    WLAN Toolkit functions are available in LabWindows/CVI from the Library menu.
    Soft Front Panel
    To launch the WLAN Soft Front Panel, navigate to the following locations:
    WLAN Analysis Soft Front Panel
    • (Windows 7) Start»All Programs»National Instruments»WLAN Analysis»WLAN Analysis Soft Front Panel.
    • (Windows 10/8.1) Start»National Instruments»WLAN Analysis Soft Front Panel.
    WLAN Generation Soft Front Panel
    • (Windows 7) Start»All Programs»National Instruments»WLAN Generation»WLAN Generation Soft Front Panel.
    • (Windows 10/8.1) Start»National Instruments»WLAN Generation Soft Front Panel.
    To access all the installed WLAN Toolkit examples for LabVIEW and LabWindows/CVI, navigate to the following locations:
    • (Windows 7) Start»All Programs»National Instruments»WLAN Analysis Toolkit»WLAN Analysis Toolkit Examples.
    • (Windows 10/8.1) Start»National Instruments»WLAN Analysis Toolkit Examples.
    • (Windows 7) Start»All Programs»National Instruments»WLAN Generation Toolkit»WLAN Generation Toolkit Examples.
    • (Windows 10/8.1) Start»National Instruments»WLAN Generation Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    The documentation set is composed of the following documents.
    DocumentFormatDescriptionPath
    WLAN Analysis Toolkit HelpHTML/Windows HelpInformation about WLAN Analysis. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to WLAN Analysis
    • A complete reference for all WLAN Analysis programming functions and VIs
    (Windows 7) Start»All Programs»National Instruments»WLAN Analysis»WLAN Analysis Toolkit Documentation
    (Windows 10/8.1) Start»National Instruments»WLAN Analysis»WLAN Analysis Toolkit Documentation
    WLAN Generation Toolkit HelpHTML/Windows HelpInformation about WLAN Generation. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to WLAN Generation
    • A complete reference for all WLAN Generation programming functions and VIs
    (Windows 7) Start»All Programs»National Instruments»WLAN Generation»WLAN Generation Toolkit Documentation
    (Windows 10/8.1) Start»National Instruments»WLAN Generation»WLAN Generation Toolkit Documentation
    WLAN Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.(Windows 7) Start»All Programs»National Instruments»WLAN»WLAN Toolkit Readme
    (Windows 10/8.1) Start»National Instruments»WLAN Toolkit Readme
    How to Use NI Software with Microsoft Windows 8.1
    WLAN Toolkit will drop support for Windows 7 and Windows Server 2008 R2 starting from 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2009–2019 National Instruments. All rights reserved.
    378072B-01
    GMT+8, 2026-4-23 09:13
