查看: 3472|回复: 0
[NI软件产品] NI RFmx 19.0 Full Win32/64Eng NI Wireless Test Standard Software完整版ni-rfmx-suite_19.0.0
    发表于 2021-2-26 22:41:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx
    WinEng
    19.0X86/64
    文件大小: 1812422656 字节 (1.69 GB)
    修改日期: 2019-08-07 19:01
    MD5: 9ad813cde8d6f90f9686cd7a069c1ead(官方正确)
    SHA1: f4da66b8a845106a59b33b5ddf62d8f505db2045
    SHA256: aa12f9243031ba2e1b424da481c66e7f11e1b5c520ece103b7d54589efdb6b3b
    CRC32: d80cf78c
    RFmx19.0.txt (630 Bytes, 下载次数: 0, 售价: 10 圆)
    RFmx Readme
    June 2019
    This file contains important information about the RFmx, including system requirements, installation instructions, and a list of included products.
    Products Included in RFmx
    RFmx Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The following products are included in the RFmx media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    • RFmx Waveform Creator
    • RFmx SpecAn
    • RFmx Demod
    • RFmx Noise Figure
    • RFmx Phase Noise
    • RFmx WLAN
    • RFmx Bluetooth
    • RFmx NR
    • RFmx LTE
    • RFmx WCDMA
    • RFmx TD-SCDMA
    • RFmx EV-DO
    • RFmx CDMA2k
    • RFmx GSM
    Drivers
    • NI-RFSG Playback Library
    System RequirementsRFmx has the following requirements:
    • 4 GB RAM*
    RFmx 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    Note  In 2019, RFmx dropped support for all 32-bit Windows operating systems. RFmx will not install or run on an unsupported OS. Refer to RFmx Drops Support for Windows 7 and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx 19.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by RFmx SpecAn
    LabWindows™/CVI™2013 SP2 or later
    RFmx SpecAn is available for download from NI Software Product Downloads.
    RFmx will drop support for Windows 7 (64-Bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2019 National Instruments. All rights reserved.
    377996A-01
    GMT+8, 2026-4-23 09:13
