查看: 3285|回复: 0
[NI软件产品] LabVIEW Communications Real-Time Target Image 3.1 Linux Real-Time OS English LabVIEW通信实时目标映像3.1
    发表于 2021-2-24 23:54:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Communications Real-Time Target Images提供Linux Real-Time OS映像,可与LabVIEW Real-Time模块硬件搭配使用。
    LabVIEW Communications Real-Time Target Image是一款应用软件,用于配置特定PXI控制器或USRP(通用软件无线电外设)设备,使其可支持LabVIEW Communications。借助该软件,即可将硬件转换为NI Linux Real-Time OS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    LabVIEW Real-Time (NI Linux Real-Time) OS,English
    3.1
    文件大小: 191889408 字节 (183.00 MB)
    修改日期: 2019-05-17 13:09
    MD5: c21102d79ae97d0e9d0fe0afb7ddb5d9
    SHA1: 765ae6133360b4f884e968171d88181bfcd9538a
    SHA256: ae8e8aab19c61c1f18b31fa128396e157f193501b635054959bdd72626c556be
    CRC32: b7de39a9
    LVComms_LinuxRT3.1.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW Communications System Design Suite 3.1 Readme
    March 2019
    This file contains important information about the LabVIEW Communications System Design Suite, including system requirements, known issues, and a partial list of bugs fixed for LabVIEW Communications System Design Suite 3.1.
    Real-Time Hardware Compatibility
    Patch Details
    LabVIEW Communications System Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021
    LabVIEW Communications has the following minimum system requirements:
    • 64-bit version of Windows 10 (version 1809)/8.1 Update 11/7 SP12/Server 2012 R2 Update1/Server 2008 R2 SP12
    • 45 GB disk space
    • 8 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to LabVIEW Communications System Design Suite 3.1 Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021 for information about future OS support.
    The RT controller you purchase with LabVIEW Communications 3.1 comes with a compatible version of NI Linux Real-Time.
    To use an RT controller that you did not receive with LabVIEW Communications 3.1, update the real-time controller to a compatible version of NI Linux Real-Time. Refer to the NI website for a guide to updating your real-time controller for use with LabVIEW Communications 3.1.
    You can access an up-to-date list of known issues for a particular release of the LabVIEW Communications System Design Suite on the NI website.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    You can Access the software bug fixes list online. Refer to the NI website for an up-to-date list of bug fixes in the LabVIEW Communications System Design Suite.
    Patch Details
    You can access a list of issues fixed for a particular release of LabVIEW Communications on the NI website.
    LabVIEW Communications System Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW Communications System Design Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2014-2019 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    376333E-01
    GMT+8, 2026-4-23 09:14
