查看: 129|回复: 0
[NI软件套件] Embedded Control and Monitoring Software Suite 2026 Q1 Win11 32bitZh-cn 嵌入式控制和监控软件套件2026Q1中文版ECMSS26.0.0
    昨天 08:12
  • 签到天数: 3859 天
    连续签到: 52 天
     楼主| 发表于 2026-4-10 10:36:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    发布日期:2026/1/28
    包含的版本:2026 Q1专业版,版本号26.0.0
    Windows Server 2025
    语言:中文Chinese/英文English
    应用程序位数:32位
    文件大小: 29805412352 字节 (27.76 GB)
    修改日期: 2026-02-06 18:20
    MD5: 377ece45ddb0ed2ab5e04fbcc6f1478f
    SHA1: 25263c5d025fbfed89ff151aab0d11531cc9cb66
    SHA256: a348130f4cf028ddb275fbe01f94ce860b2c9446fc77ce0b80f2d35f09366916
    SHA512: 32676239181e6c8f4ec2ce9fba2455e1824fd4e7a5ccea30ddd95972b8c5584b61005a5adfda5439f27c3dbeea16c8c30353f4e62f5ecaf9834bf5347e2c986e
    Embedded Control and Monitoring Software Suite 2026 Q1 X86Zh-cn.txt (856 Bytes, 下载次数: 0, 售价: 40 圆)
    套件包含:
    编程环境
    ProductVersionBitness
    LabVIEW2026 Q132-bit and 64-bit
    附加软件
    LabVIEW Real-Time Module2026 Q132-bit and 64-bit
    LabVIEW FPGA Module2026 Q132-bit and 64-bit
    LabVIEW Datalogging and  Supervisory Control Module2026 Q132-bit
    LabVIEW Datalogging and  Supervisory Control Runtime2026 Q132-bit
    LabVIEW FPGA Compile Farm  Toolkit2026 Q132-bit and 64-bit
    JKI VI Package Manager2026 Q132-bit and 64-bit
    Vision Development Module2025 Q432-bit and 64-bit
    LabVIEW FPGA Compilation Tool  for Vivado 2021.12026 Q132-bit and 64-bit
    驱动程序
    NI CompactRIO2026 Q132-bit and 64-bit
    NI-DAQmx2026 Q132-bit and 64-bit
    NI-Serial2025 Q432-bit and 64-bit
    NI-VISA2026 Q132-bit and 64-bit
    NI-XNET2026 Q132-bit and 64-bit
    FlexRIO with Modular I/O2026 Q132-bit and 64-bit
    FlexRIO with Integrated I/O2026 Q132-bit and 64-bit
    FPGA Interface C API20.0.032-bit and 64-bit
    NI-Sync2026 Q132-bit and 64-bit
    NI R系列多功能RIO2026 Q132-bit and 64-bit
    NI Vision Acquisition Software (包含IMAQ,  IMAQdx, IMAQ I/O)2025 Q432-bit and 64-bit
    2026Q1未更新自述文件,参考2023Q1版
    Embedded Control and Monitoring Software Suite 2023 Q1自述文件
    2023年1月
    本文件包含Embedded Control and Monitoring Software Suite 2023 Q1的安装说明和兼容性信息。
    您可以在ni.com上找到更多关于此次发行的信息。
    • Embedded Control and Monitoring Software Suite发行说明:已知问题,自上一发行版以来已修复的错误以及关于此次发行的说明信息。
    系统要求
    操作系统支持
    Embedded Control and Monitoring Software Suite中包含的产品
    安装说明
    产品安全及关键更新
    支持的硬件
    查找范例
    自动安装NI产品
    在Microsoft Windows 11中使用NI软件
    不支持的Windows操作系统
    NI不再支持Phar Lap ETS实时操作系统
    系统要求
    系统要求见各产品的自述文件。
    操作系统支持
    Embedded Control and Monitoring Software Suite 2023 Q1支持以下操作系统:
    Embedded Control and Monitoring Software Suite安装程序中包含以下产品。该表可能未包含可通过您的套件序列号激活的产品的完整列表。关于系统要求、产品安装、激活、已知问题和问题修正的更多信息,请参考具体产品的自述文件。
    应用程序软件
    产品
    版本
    位数
    LabVIEW2023 Q132位和64位
    注:本产品不再支持LabVIEW NXG。关于LabVIEW NXG生命周期日期和驱动程序版本支持的更多信息,请访问ni.com上的LabVIEW NXG。
    附加软件
    产品
    版本
    位数
    FPGA Interface C API202032位和64位
    JKI VI Package Manager2023 Q132位和64位
    LabVIEW FPGA Compilation Tool for Vivado 2021.12022 Q364位
    LabVIEW FPGA Compile Farm工具包2023 Q132位和64位
    LabVIEW FPGA模块2023 Q132位和64位
    LabVIEW Real-Time模块2023 Q132位和64位
    Vision Development模块2023 Q132位和64位
    注:LabVIEW专业版开发系统将安装LabVIEW Advanced Signal Processing工具包、LabVIEW Desktop Execution Trace工具包、LabVIEW Digital Filter Design工具包、LabVIEW Unit Test Framework工具包、LabVIEW VI Analyzer工具包、LabVIEW Database Connectivity工具包和LabVIEW Report Generation工具包。labview\readme目录下可找到这些工具包的自述文件。
    驱动程序
    产品
    版本
    位数
    FlexRIO with Integrated I/O2023 Q132位和64位
    FlexRIO with Modular I/O2023 Q132位和64位
    NI CompactRIO2023 Q132位和64位
    NI-DAQmx2023 Q132位和64位
    NI-Industrial Communications for EtherNet/IP2022 Q332位和64位
    NI-Serial21.532位和64位
    NI-Sync2023 Q132位和64位
    NI-VISA2022 Q332位和64位
    NI-XNET2023 Q132位和64位
    R系列2023 Q132位和64位
    注:本版本中不包含之前版本Embedded Control and Monitoring Software Suite中包含的部分驱动程序。如需最新驱动程序版本,请访问ni.com/downloads。
    Microsoft Visual Studio支持
    如使用Embedded Control and Monitoring Software Suite .NET Class Library,至少需要.NET Framework 4.0。在面向.Net Framework 4.0或.NET Framework 4.5的Visual Studio版本中,Embedded Control and Monitoring Suite 2023 Q1 .NET Class Library可与Visual C#或Visual Basic .NET配合使用。
    如要使用.NET API,除安装NI设备驱动程序外,还必须安装.NET类库或.NET包装器。关于.NET Framework和驱动程序支持的版本信息,及安装文件的下载地址,请访问NI软硬件的.NET资源。
    安装说明
    从ni.com/downloads下载Embedded Control and Monitoring Software Suite。NI软件包含用于管理安装的NI Package Manager。关于使用Package Manager安装、移除、更新NI软件的详细信息,请参考NI Package Manager手册。
    说明
    • 使用软件附带的序列号激活Embedded Control and Monitoring Software Suite。关于Embedded Control and Monitoring Software Suite激活的更多信息,请参考激活产品。
    产品安全及关键更新
    支持的硬件
    要查看设备信息:
    查找范例
    范例查找位置见各产品的自述文件。
    自动安装NI产品
    不支持的Windows操作系统
    Embedded Control and Monitoring Software Suite不再支持Windows Vista/XP/7/8.x、Windows Server 2003/2008/2012或其他32位Windows操作系统。本产品在2021年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。关于NI操作系统支持的详细信息,请访问https://www.ni.com/r/win32bitsupport
    NI软件不再支持Phar Lap ETS实时操作系统本产品在2022年5月1日以后发行的版本可能无法在这些操作系统上正常安装和运行。有关Phar Lap及其替代产品NI Linux Real-Time的支持路线图的高层信息,请访问ni.com/r/xf35k1。如需了解运行NI Linux Real-Time的PXI控制器支持的硬件信息,请访问ni.com/r/b7g5wi。
    GMT+8, 2026-4-18 05:16
