查看: 3541|回复: 0
[NI软件产品] LabVIEW Communications Real-Time Target Image 2.1 Linux Real-Time OS English LabVIEW通信实时目标映像2.1
    发表于 2021-2-24 23:51:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Communications Real-Time Target Images提供Linux Real-Time OS映像,可与LabVIEW Real-Time模块硬件搭配使用。
    LabVIEW Communications Real-Time Target Image是一款应用软件,用于配置特定PXI控制器或USRP(通用软件无线电外设)设备,使其可支持LabVIEW Communications。借助该软件,即可将硬件转换为NI Linux Real-Time OS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    LabVIEW Real-Time (NI Linux Real-Time) OS,English
    2.1
    文件大小: 317718528 字节 (303.00 MB)
    修改日期: 2018-08-21 03:25
    MD5: 2b2d677ad803c50a981a1811d0db69b5(官方正确)
    SHA1: 3540c1d3ea77ac35bd6545a09f1ffa5f62e7e565
    SHA256: 813ee1de11bf4e744a5f6e7016ec306a5dafb3cd3a1ac3468e4e2711b313c199
    CRC32: b99aec0b
    LVComms_LinuxRT2.1.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW Communications System Design Suite 2.1 Readme
    July 2018
    This file contains important information about the LabVIEW Communications System Design Suite, including system requirements, known issues, and a partial list of bugs fixed for LabVIEW Communications System Design Suite 2.1.
    Real-Time Hardware Compatibility
    LabVIEW Communications System Design Suite is a design environment closely integrated with NI software-defined radio hardware for prototyping communications systems.
    To use code that you created with LabVIEW 2009 or later with LabVIEW Communications System Design Suite 2.1, use the NI Code Conversion Utility for LabVIEW Communications 2.1 to convert VIs, projects, and libraries into files that are compatible with the LabVIEW Communications System Design Suite.
    If you are using LabVIEW Communications System Design Suite 2.0 or earlier, refer to the NI website for a guide to migrating code to the LabVIEW Communications System Design Suite 2.1.
    LabVIEW Communications has the following minimum system requirements:
    • 64-bit version of Windows 10/8.11/7 SP12
    • 15 GB disk space
    • 8 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    The RT controller you purchase with LabVIEW Communications 2.1 comes with a compatible version of NI Linux Real-Time.
    To use an RT controller that you did not receive with LabVIEW Communications 2.1, update the real-time controller to a compatible version of NI Linux Real-Time. Refer to the NI website for a guide to updating your real-time controller for use with LabVIEW Communications 2.1.
    You can access the software known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW Communications System Design Suite.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    You can Access the software bug fixes list online. Refer to the NI website for an up-to-date list of bug fixes in the LabVIEW Communications System Design Suite.
    © 2014-2018 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    376333C-01
    GMT+8, 2026-4-23 09:14
