查看: 6491|回复: 0
[NI软件产品] LabVIEW Communications Real-Time Target Image 2.0 Linux Real-Time OS English LabVIEW通信实时目标映像2.0
    发表于 2021-2-24 23:47:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Communications Real-Time Target Images提供Linux Real-Time OS映像,可与LabVIEW Real-Time模块硬件搭配使用。
    LabVIEW Communications Real-Time Target Image是一款应用软件,用于配置特定PXI控制器或USRP(通用软件无线电外设)设备,使其可支持LabVIEW Communications。借助该软件,即可将硬件转换为NI Linux Real-Time OS。注册商标Linux的使用获得了Linus Torvalds专属授权商LMI的再授权,Linus Torvalds拥有Linux注册商标在全球范围内的所有权。
    LabVIEW Real-Time (NI Linux Real-Time) OS,English
    2.0
    文件大小: 399507456 字节 (381.00 MB)
    修改日期: 2016-08-01 23:09
    MD5: 5141c09b2e6056165541dac418bcc668
    SHA1: 62dbf7f5396de1dd19f6d159f54330ceba98a43d
    SHA256: 8cedb4b154e115b0e9bd2043d93008915936ab279feeb5493d27ccabfb4b88c9
    CRC32: 9efdae0e
    LVComms_LinuxRT2.0.txt (660 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW Communications System Design Suite 2.0 Readme
    March 2016
    This file contains important information about the LabVIEW Communications System Design Suite, including system requirements, known issues, and a partial list of bugs fixed for LabVIEW Communications System Design Suite 2.0. This file also applies to the LabVIEW Communications System Design Software and the NI Code Conversion Utility for LabVIEW Communications 2.0.
    Real-Time Hardware Compatibility
    LabVIEW Communications System Design Suite is an integrated, hardware-aware design environment for prototyping communications systems.
    To use code that you created with LabVIEW or earlier versions of the LabVIEW Communications System Design Suite with the LabVIEW Communications System Design Suite 2.0, refer to the following resources:
    • LabVIEW 2009 or later—Use the NI Code Conversion Utility for LabVIEW Communications 2.0 to convert VIs, projects, and libraries into files that are compatible with the LabVIEW Communications System Design Suite and LabVIEW Communications System Design Software.
    • LabVIEW Communications System Design Suite 1.1 or earlier—Refer to the NI website for a guide to migrating code to the LabVIEW Communications System Design Suite 2.0.
    SuiteSoftware
    Operating SystemWindows 7 SP1 (64-bit)
    Windows 8.1 (64-bit)
    Windows 10 (64-bit)
    Disk Space15 GB3 GB
    RAM8 GB4 GB
    Note: You must use Internet Explorer 9 or later to open links from LabVIEW Communications System Design Suite.
    The NI PXIe-8135 RT or NI PXIe-8880 RT controller you purchase with LabVIEW Communications 2.0 comes with a compatible version of Linux Real-Time.
    To use an NI PXIe-8135 RT or NI PXIe-8880 RT controller that you did not receive with LabVIEW Communications 2.0, update the real-time controller to a compatible version of Linux Real-Time. Refer to the NI website for a guide to updating your real-time controller for use with LabVIEW Communications 2.0.
    You can access the software known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW Communications System Design Suite.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW Communications System Design Suite 2.0. This is not an exhaustive list of issues fixed in the current version of the LabVIEW Communications System Design Suite. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    507482The IIR Filter FPGA IP Example Does Not Run on Hardware
    507503FPGA Host Interface Example Returns Wrong Value in Indicator for USRP
    513672Chart Probe and Numeric Probe do not Work Correctly on Multirate Diagram with Disaggregate/Aggregate Nodes
    517226Crash with Multirate Diagram and Chart Probe After Disaggregate Node Set to 1 Output Chunk
    527093Switching Targets in the IIR Example Can Cause the Application to Crash
    549417Selective Diagram Clean Up Does Not Work
    557244LabVIEW Communications Multirate Diagram with Chart Probe Crashes with Ctrl+R
    563578The Reed Solomon Encoding and Decoding Nodes Return Error -1 Regardless of Input
    572656Compiling a Single Multirate Diagram as a SubMRD Causes a Compilation Error
    576661Multirate Diagram Does Not Estimate Throughput Correctly if Single Wire is Branched Into Both Inputs of Multiply Node
    LabVIEW Communications System Design Suite uses Microsoft .NET 4.5.1. The .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.5.1 or later separately before you install NI software.
    For more information about automating the installation of NI products, refer to the following articles on ni.com:
    • For more information on silent installations of suited NI products, such as LabVIEW Communications System Design Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
    © 2014-2016 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    376333A-01
    GMT+8, 2026-4-23 09:13
