查看: 5300|回复: 0
[NI软件产品] NI GPIB-Serial Converter Software 19.0 Win32/64 Eng/Jpn/Kor/Fre/Ger/Chn NI GPIB到串口转换软件19.0下载
    发表于 2020-12-17 22:47:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    GPIB-Serial Converter软件可帮助您配置GPIB仪器控制设备。
    GPIB-Serial Converter软件是一个实用程序软件,用于配置GPIB-RS232或GPIB-RS485/RS422转换盒。该实用程序使GPIB仪器控制设备能够将具有RS485、RS422或RS232串行端口的计算机转换为GPIB总线上的讲话者、监听器或控制器。GPIB-Serial Converter软件还为使用GPIB连接第三方仪器提供了最大的可靠性。
    19.0Win32/64中文, 德语, 日语, 法语, 英文, 韩语
    文件大小: 511444992 字节 (487.75 MB)
    修改日期: 2020-01-31 01:45
    MD5: e373b2916a8dba8f66f6de8f664aa340(官方正确)
    SHA1: 5ad69449e8dc65fa96c262697a835ff5eb5ef41e
    SHA256: d74e38030489aaa2f69021cfbe7a2d4e350b2b2c6078c92e29a4ef1c444cb7db
    CRC32: 8e092b7a
    GPIB-Serial19.0.txt (704 Bytes, 下载次数: 0, 售价: 10 圆)
    NI GPIB-Serial Converter Version 19.0 Readme
    January 2020
    This file contains important information about the NI GPIB-Serial Converter software.
    Features in Version 19.0
    Enhancements and Bug Fixes in Version 19.0
    Supported Interfaces
    NI GPIB-Converter Software Drops Support for Windows 7 (32- and 64-Bit) and All 32-Bit Windows Operating Systems in 2021
    The NI GPIB-Serial Converter software supports the National Instruments GPIB-RS232 and GPIB-RS485/RS422 hardware interfaces. These products are drop-in replacements for the older GPIB-232/485CT-A and GPIB-232CV-A products. There are no dip switches on the GPIB-RS232/485/422 hardware interfaces. The NI GPIB-Serial Converter software allows you to configure the settings for the hardware, as well as update the firmware, if a new firmware image becomes available.
    The NI GPIB-Serial Converter software supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  Refer to NI GPIB-Serial Converter Software Drops Support for Windows 7 (32- and 64-Bit) and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Features in Version 19.0Modes of Operation
    The GPIB-RS232/485/422 combines the modes of operation from the GPIB-232/485CT-A (G Mode and S Mode) and GPIB-232CV-A (C Mode and D Mode). Refer to the NI GPIB-Serial Converter Help for additional information regarding each mode.
    Firmware and Configuration Updates
    Use the NI GPIB-Serial Converter Wizard to select the desired mode of operation and configure the GPIB-RS232/485/422 settings. Download firmware images from the web and use the same utility to update the hardware interfaces with the new firmware.
    Serial Baud Rates
    Baud rates up to 115.2 kb/s are supported. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    Secondary GPIB Addressing
    Secondary GPIB addressing is available in any mode of operation. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    EOI Assertion in C Mode
    In C Mode, there is an option to assert EOI with and termination modes. The EOI (End or Identity) asserts on the GPIB bus on the terminating byte prior to readdressing the device as a Talker. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    Differences between GPIB-RS232/485/422 and GPIB-232/485CT/CV-A
    Refer to the NI GPIB-Serial Converter Help for a detailed list of differences between the GPIB-RS232/485/422 and the GPIB-232/485CT/CV-A hardware interfaces.
    Support for Windows 10/8.1/7 SP1 has been added in this release.
    Support for Windows 2000 and XP is discontinued in this release.
    The following hardware interfaces are supported:
    • GPIB-RS232
    • GPIB-RS485/RS422
    The NI GPIB-Serial Converter software will drop support for Windows 7 (32- and 64-bit) and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2006–2020 National Instruments. All rights reserved.
    378114A-01
    GMT+8, 2026-4-23 09:14
