查看: 5753|回复: 0
[NI软件产品] NI GPIB-Serial Converter Software 1.0 Win32Eng NI GPIB到串口转换软件1.0下载
    发表于 2020-12-17 22:45:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    GPIB-Serial Converter软件可帮助您配置GPIB仪器控制设备。
    GPIB-Serial Converter软件是一个实用程序软件,用于配置GPIB-RS232或GPIB-RS485/RS422转换盒。该实用程序使GPIB仪器控制设备能够将具有RS485、RS422或RS232串行端口的计算机转换为GPIB总线上的讲话者、监听器或控制器。GPIB-Serial Converter软件还为使用GPIB连接第三方仪器提供了最大的可靠性。
    1.0Win32Eng
    文件大小: 66933024 字节 (63.83 MB)
    修改日期: 2010-04-25 03:27
    MD5: 4e3398ca7623b29b84f397e2b076a412(官方正确)
    SHA1: 369b6fd5a5300e8ff62177298c214d980e1b6678
    SHA256: 33d2194578b7a9742cb7eb826a9cd09fd64b5e74d7b5f297afe5237d4e25938b
    CRC32: fb82ea8c
    GPIB-Serial1.0.txt (593 Bytes, 下载次数: 0, 售价: 10 圆)
    NI GPIB-Serial Converter, Version 1.0© 2006 National Instruments Corporation. All rights reserved.
    Thank you for using the NI GPIB-Serial Converter, Version 1.0.
    This file contains release notes, patent information, and last-minute information for the NI GPIB-Serial Converter software. Some information in this file may be too recent to be included in the official documentation set.
    This readme contains the following main sections:
    • Release Notes
    • Features in Version 1.0
    • Contacting National Instruments
    • Patent Information
    Release Notes
    The NI GPIB-Serial Converter software supports the National Instruments GPIB-RS232 and GPIB-RS485/RS422 hardware interfaces. These products are drop-in replacements for the older GPIB-232/485CT-A and GPIB-232CV-A products. There are no dip switches on the GPIB-RS232/485/422 hardware interfaces. The NI GPIB-Serial Converter software allows you to configure the settings for the hardware, as well as update the firmware, if a new firmware image becomes available.
    Supported Interfaces
    The following hardware interfaces are supported:
    • GPIB-RS232
    • GPIB-RS485/RS422
    The NI GPIB-Serial Converter software must be installed and run on the following operating systems:
    • Windows 2000 Service Pack 4
    • Windows XP Service Pack 2
    The configured hardware interfaces have been tested with, but are not restricted to, the following:
    • 32-bit x86 processors
    Features in Version 1.0Modes of Operation
    The GPIB-RS232/485/422 combines the modes of operation from the GPIB-232/485CT-A (G Mode and S Mode) and GPIB-232CV-A (C Mode and D Mode). Refer to the NI GPIB-Serial Converter Help for additional information regarding each mode.
    Firmware and Configuration Updates
    Use the NI GPIB-Serial Converter Wizard to select the desired mode of operation and configure the GPIB-RS232/485/422 settings. Download firmware images from the web and use the same utility to update the hardware interfaces with the new firmware.
    Serial Baud Rates
    Baud rates up to 115.2 kb/s are supported. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    Secondary GPIB Addressing
    Secondary GPIB addressing is available in any mode of operation. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    EOI Assertion in C Mode
    In C Mode, there is an option to assert EOI with and termination modes. The EOI (End or Identity) asserts on the GPIB bus on the terminating byte prior to readdressing the device as a Talker. Use the NI GPIB-Serial Converter Wizard to configure this setting.
    Differences between GPIB-RS232/485/422 and GPIB-232/485CT/CV-A
    Refer to the NI GPIB-Serial Converter Help for a detailed list of differences between the GPIB-RS232/485/422 and the GPIB-232/485CT/CV-A hardware interfaces.
    Thank you for your interest in the NI GPIB-Serial Converter. We appreciate communicating with the people who use our products. We are also very interested in hearing about the applications you develop using our products. Our Web site, ni.com, provides advanced support and services and contact information.
    Patent Information
    For patents covering National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2026-4-23 09:16
