查看: 5816|回复: 0
[NI软件产品] NI Bluetooth Toolkit 16.0 Win32/64Eng NI蓝牙测试工具包16.0下载
    发表于 2020-12-16 23:18:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Bluetooth测试工具包
    Bluetooth测试工具包为蓝牙基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)测试应用提供信号生成和分析功能。
    Bluetooth测试工具包是一款专用软件,旨在扩展NI RF的功能,使其具备经典蓝牙和低功率(LE)蓝牙信号生成和分析能力。该软件可以通过调制准确度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助Bluetooth测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并利用更高性能的API更快速完成自动化测试。此外,Bluetooth测试工具包可以通过内置的直接测试模式(DTM)命令来控制待测设备。Bluetooth 为Bluetooth SIG公司的注册商标。
    Win32/64Eng
    16.0
    文件大小: 830316424 字节 (791.85 MB)
    修改日期: 2016-12-14 15:55
    MD5: dacf7712da646d82b6dc2691e5e959d8(官方正确)
    SHA1: ac4fa82b0c0ad2ccc10163baf80e3b27ac8fc3ca
    SHA256: 74bbb4d8437f9dd9b59bc6ca03e23de8bcbdb7773cd0015b9cf248d1bd3cb0ab
    CRC32: e89917e6
    BT16.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    NI Bluetooth Analysis Toolkit 16.0 Readme
    December 2016
    Thank you for using NI Bluetooth Analysis Toolkit 16.0. This file contains important information about the NI Bluetooth Analysis Toolkit 16.0 and is organized into the following sections:
    Accessing VIs and Functions
    Product Version Naming Changes
    Uninstalling/Modifying NI Bluetooth Analysis Toolkit 16.0
    NI Bluetooth Analysis Toolkit 16.0 includes the following new features:
    • Support for Bluetooth LE Standard v5.0 (draft version)
    • Support for LE enhanced direct test Mode commands
    • Support for de-whitening in LE
    • Support for preamble-based burst synchronization for LE
    • Support for whole packet frequency deviation trace as part of carrier frequency offset measurement
    • Support for whole packet bit trace for LE as part of PER
    NI Bluetooth Analysis Toolkit 15.0 includes the following new features:
    • Support for Bluetooth LE Standard v4.2
    • Support for Bluetooth LE 2 Mbps Standard (draft version) in API
    • Support for Direct Test Mode commands for device control
    • Support for LabVIEW 2015 (32-bit and 64-bit)
    NI Bluetooth Analysis Toolkit 14.5 adds support for automatic detection of the packet type
    NI Bluetooth Analysis Toolkit 14.0 includes the following new features:
    • Support for Windows 64-bit processes
    • Addition of Runtime installers for LabVIEW and C
    • Support for automatic pattern detection for df1 and df2 measurements that use df2/df1 ratio
    • Addition of option to disable packet check and VBW filter in measurements
    • Support for user-defined payload length in DEVM measurement
    NI Bluetooth Analysis Toolkit 1.2 includes the following new features:
    • Addition of I/Q impairment estimation and compensation for DEVM measurements
    • Addition of spectrum measurements to composite LabVIEW and C examples
    • Addition of low energy PER measurement
    • Changes to sweep spectrum measurement method to improve performance
    • Changes to FFT spectrum measurement method with average detection, to improve performance
    • Deprecation of Per Spectral Acquisition Bandwidth property
    • Addition of centered spectrum measurements
    • Addition of preamble-based burst synchronization for Demodulation measurements on Basic Rate and EDR packets
    • Support for automatic detection of guard position for EDR InBand Spurious measurement using preamble-based burst synchronization
    • Addition of Bits above DF2Max Threshold and Symbols below 99% DEVM Threshold properties
    • Changes to computation of CFO Results in CFO measurements, in order to match CFO Results in DF2 Measurements
    • Optimization of memory
    NI Bluetooth Analysis Toolkit 1.1 includes the following new features:
    • Support for Bluetooth low energy
    • Support for BER measurement with the number of unique packets for which the PN generator must run continuously
    • Support for user-configurable detector type for spectral measurements
    • Support for modulation characteristic measurement for FSK packets with Dolph-Chebyshev filter
    • Support for 2/3 forward error correction
    • NI PXIe-5663E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5668R
    • NI PXIe-5840
    Note  Device-specific information about these modules is included in the NI Digital Waveform Generator/Analyzer Help.
    NI Bluetooth Analysis Toolkit 16.0 supports the following operating systems:
    • Windows Embedded Standard 7 SP12 (32-bit and 64-bit)
    Note   NI Bluetooth Analysis Toolkit 16.0 does not support Windows Server non-R2 editions.
    Minimum Requirements
    • NI-RFSA 2.9.1 or later
    • NI LabVIEW Modulation Toolkit 4.3.4 or later
    • NI Spectral Measurements Toolkit 2.6.4 or later
    Recommended System
    • RAM—4 GB*
    • A screen resolution of 1300 x 700
    • Hard drive space—2 GB
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows™/CVI™, before installing NI Bluetooth Analysis Toolkit 16.0. To add support for ADEs installed after installing NI Bluetooth Analysis Toolkit 16.0, modify your NI Bluetooth Analysis Toolkit 16.0 installation or launch the NI Bluetooth Analysis Toolkit 16.0 installer again.
    • NI LabVIEW 2013 SP1 f6 patch, 2014 SP1 f5 (32-bit) patch, 2014 SP1 f6 (64-bit) patch, 2015 SP1 f5 patch, or 2016
    • LabWindows/CVI 8.5.1 or later
      • (32-bit) Program Files\National Instruments
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
    ItemInstalled Location
    Analysis Interactive Example\Bluetooth Toolkit\niBTA_Interactive_example.exe
    DLL (32-bit OS/64-bit OS , 64-bit support)\system32\
    DLL (64-bit OS , 32-bit support)\systemWOW64\
    VIs\vi.lib\RF Toolkits\BT
    Examples\examples\RF Toolkits\BT
    LabWindows/CVI
    Header Files\Shared\CVI\Include
    Static Libraries\Shared\CVI\bin\msvc
    .lfp/.sub Files\Shared\CVI\bin
    Examples\CVI\samples\Bluetooth
    C
    Header Files\Shared\ExternalCompilerSupport\C\include
    Import Library\Shared\ExternalCompilerSupport\C\lib32\msvc
    Examples\Bluetooth Toolkit\examples\C\Analysis
    Select Start»All Programs»National Instruments»NI-Bluetooth Analysis Toolkit»Bluetooth Analysis Interactive Example to launch the Analysis Interactive Example.
    Documentation for NI Bluetooth Analysis Toolkit 16.0 is located at Start»All Programs»National Instruments»NI Bluetooth Analysis Toolkit»Bluetooth Analysis Toolkit Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI Bluetooth Analysis Toolkit HelpHTML/Windows HelpInformation about NI Bluetooth Analysis Toolkit products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Bluetooth Analysis Toolkit
    • A complete reference for all NI Bluetooth Analysis Toolkit programming functions
    NI Bluetooth Analysis Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI Bluetooth Analysis palette VIs are available from the Functions»RF Communications»Bluetooth»Analysis palette.
    NI Bluetooth Analysis functions are available in LabWindows/CVI from the Library menu.
    You can access all the installed NI Bluetooth Analysis Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI Bluetooth Analysis Toolkit»Bluetooth Analysis Toolkit Examples.
    Examples also are available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI Bluetooth Analysis Toolkit 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Bluetooth Analysis Toolkit support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Bluetooth Analysis Toolkit 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Bluetooth Analysis Toolkit 16.0 to an unsupported OS. Additionally, after installing NI Bluetooth Analysis Toolkit 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Bluetooth Analysis Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: <;ProductName>. For example, NI Bluetooth Analysis Toolkit 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI Bluetooth Analysis Toolkit 1.2. The first version released under the new numbering scheme is NI Bluetooth Analysis Toolkit 14.0.
    • Select NI Bluetooth Toolkit 16.0 from the dialog box that appears.
    • Select Control Panel.
    • Click the Uninstall button.
    You can access the software and documentation known issues list online. Refer to the NI Bluetooth Analysis Toolkit 16.0 Known Issues at ni.com for an up-to-date list of known issues in NI Bluetooth Analysis Toolkit 16.0.
    The following items are changes in Bluetooth Toolkit 16.0 from Bluetooth Toolkit 15.0.
    Bug IDFixed Issue
    558416Fixed an issue where the behavior of burst synchronization type Preamble was similar to None for LE.
    584720Fixed an issue where the CFO calculation in the LE-Enhanced packets did not match the Bluetooth LE 2 Mbps Test Cases (draft version)
    The following items are changes in Bluetooth Toolkit 15.0 from Bluetooth Toolkit 14.5.
    Bug IDFixed Issue
    542999Fixed an issue where the average DF2avg and max/min DF2max computation did not match the Bluetooth Radio Frequency TSS and TP Specification 1.2/2.0/2.0 + EDR/2.1/2.1+EDR/4.0 standards.
    The following items are changes in Bluetooth Toolkit 1.2 from Bluetooth Toolkit 1.1.
    Bug IDFixed Issue
    439355Fixed an issue where the GFSK Header portion was not excluded from the EDR InBand Spurious measurement.
    439820Fixed an issue where the default detector type was incorrect for ACP and EDR InBand Spurious emissions. The default detector type is now Average.
    Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8.1. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2011-2016 National Instruments. All rights reserved.
    375225C-01
    NI Bluetooth Generation Toolkit 16.0 Readme
    December 2016
    Thank you for using NI Bluetooth Generation Toolkit 16.0. This file contains important information about the NI Bluetooth Generation Toolkit 16.0 and is organized into the following sections:
    Uninstalling/Modifying NI Bluetooth Generation Toolkit 16.0
    NI Bluetooth Generation Toolkit 16.0 includes the following new features:
    • Support for disabling the LE PDU header
    • Support for LE enhanced direct test mode commands
    • Support for whitening in LE
    • Support for Dirty TX test with stable modulation index
    • Support for modulation index configuration
    • Support for oversampling factor configuration
    • Support for ramp time and settling time configuration
    NI Bluetooth Generation Toolkit 15.0 includes the following new features:
    • Support for direct test mode commands for device control
    NI Bluetooth Generation Toolkit 14.5 includes the following new features:
    • Support for custom impairment sets in Dirty Tx transmission
    • Support for user defined payload in LE
    NI Bluetooth Generation Toolkit 14.0 adds support for Windows 64-bit processes.
    NI Bluetooth Generation Toolkit 1.2 includes the following new features:
    • Enhancements to ramp up and ramp down of all packets, and to the guard interval of EDR packets
    • Changes to Continuous Carrier Mode to continue PN sequence generation in all the occupied slots in a packet
    NI Bluetooth Generation Toolkit 1.1 includes the following new features:
    • Support for specifying the number of unique packets for which the PN generator must run continuously
    • Enhancement in the implementation of the dirty transmitter to maintain the same impairment set for the required duration based on packet type. You cannot use the niBT Generate Data Packet with Dirty Tx Impairments.vi from NI Bluetooth Generation Toolkit 1.0 with NI Bluetooth Generation Toolkit 1.1, because the current release uses a single waveform name and does not support multiple indexed waveform names
    • Enhancement in the implementation of the dirty transmitter to support the number of unique packets
    • Support for configuring number of idle slots and generating the idle slots along with the data packet
    • NI PXIe-5673E
    • NI PXIe-5644R
    • NI PXIe-5645R
    • NI PXIe-5646R
    • NI PXIe-5840
    NI Bluetooth Generation Toolkit 16.0 supports the following operating systems:
    Note   NI Bluetooth Generation Toolkit 16.0 does not support Windows Server non-R2 editions.
    • Hard drive space—1 GB
    • NI-RFSG 1.9.7 or later
    Recommended System
    • RAM—4 GB*
    Note  You should install ADEs, such as NI LabVIEW or NI LabWindows™/CVI™, before installing NI Bluetooth Generation Toolkit 15.0. To add support for ADEs installed after installing NI Bluetooth Generation Toolkit 16.0, modify your NI Bluetooth Generation Toolkit 16.0 installation or launch the NI Bluetooth Generation Toolkit 16.0 installer again.
    Generation Interactive Example\Bluetooth Toolkit\niBTG_Interactive_Example.exe
    LabWindows/CVI
    C
    Examples\Bluetooth Toolkit\examples\C\Generation
    Select Start»All Programs»National Instruments»NI-BT Generation Toolkit»Bluetooth Generation Interactive Example to launch the Generation Interactive Example.
    Documentation for NI Bluetooth Generation Toolkit 16.0 is located at Start»All Programs»National Instruments»NI Bluetooth Generation Toolkit»Bluetooth Generation Toolkit Documentation. The documentation set is composed of the following documents.
    NI Bluetooth Generation Toolkit HelpHTML/Windows HelpInformation about NI Bluetooth Generation Toolkit. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI Bluetooth Generation Toolkit
    • A complete reference for all NI Bluetooth Generation Toolkit programming functions
    NI Bluetooth Generation Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI Bluetooth Generation palette VIs are available from the Functions»RF Communications»Bluetooth»Generation palette.
    NI Bluetooth Generation functions are available in LabWindows/CVI from the Instrument menu.
    You can access all the installed NI Bluetooth Generation Toolkit examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI Bluetooth Generation Toolkit»Bluetooth Generation Toolkit Examples.
    NI Bluetooth Generation Toolkit 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Bluetooth Generation Toolkit drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Bluetooth Generation Toolkit 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Bluetooth Generation Toolkit 16.0 to an unsupported OS. Additionally, after installing NI Bluetooth Generation Toolkit 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI Bluetooth Generation Toolkit versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the toolkit was released and the most recent software version the toolkit was designed to work with. Toolkit versions now start with a two-digit year indicator: <;ProductName>. For example, NI Bluetooth Generation Toolkit 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI Bluetooth Generation Toolkit 15.0. The first version released under the new numbering scheme is NI Bluetooth Generation Toolkit 14.0.
    You can access the software and documentation known issues list online. Refer to the NI Bluetooth Generation Toolkit 16.0 Known Issues at ni.com for an up-to-date list of known issues in NI Bluetooth Generation Toolkit 16.0.
    Bug IDFixed Issue
    557693Fixed an issue where the LE Preamble was not generated based on the LSB of LE access address.
    370079Fixed an issue where settling time and ramp time of the waveforms did not match the Bluetooth Radio Frequency TSS and TP Specification 1.2/2.0/2.0 + EDR/2.1/2.1+EDR/3.0/3.0+HS and Bluetooth Test Specification 4.0/4.2.0/4.2.2.
    549638Fixed an issue where the AWGN applied on the generated signal was wrong.
    584734Fixed an issue where the packet interval for LE-TP-EXT, LE-Enhanced packets did not match the Bluetooth Core Specification v4.0/4.2 and the Bluetooth LE 2 Mbps Standard (draft version).
    601300Fixed an issue where the seed for LE PN9 sequence was not reset between different runs.
    607860Fixed an issue where the dirty transmitter modulating signal was not synchronized with the packets.
    Bug IDFixed Issue
    436419Fixed an issue where the settings were incorrect when the carrier mode was set to Continuous.
    379019Fixed an issue where there was no option in LabVIEW examples to send a finite number of packets from the generator.
    375224C-01
    GMT+8, 2026-4-23 09:16
