查看: 5615|回复: 0
[NI软件产品] NI Bluetooth Toolkit 19.0 Win32/64Eng NI蓝牙测试工具包19.0下载
    发表于 2020-12-16 23:25:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Bluetooth测试工具包
    Bluetooth测试工具包为蓝牙基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)测试应用提供信号生成和分析功能。
    Bluetooth测试工具包是一款专用软件,旨在扩展NI RF的功能,使其具备经典蓝牙和低功率(LE)蓝牙信号生成和分析能力。该软件可以通过调制准确度、载波频率漂移、发射功率(TXP)等符合标准的物理层测量,分析蓝牙信号(最高可支持蓝牙5.2)基本速率(BR)、增强型数据速率(EDR)和低功耗(LE)信号。借助Bluetooth测试工具包,您可通过交互式软面板快速轻松地执行和调试测量,创建和回放开放的未锁定波形,并利用更高性能的API更快速完成自动化测试。此外,Bluetooth测试工具包可以通过内置的直接测试模式(DTM)命令来控制待测设备。Bluetooth 为Bluetooth SIG公司的注册商标。
    Win32/64Eng
    19.0
    文件大小: 1235009536 字节 (1.15 GB)
    修改日期: 2019-06-24 15:24
    MD5: 11410159ba2705e9ebbf86f140baa506(官方正确)
    SHA1: 0d8df8fb64851e8a811505a0510f3a7ed626a14a
    SHA256: 4d05bb31f61839acd7b13e96fb9668b00dd92c0f772db1e3add89a1a85e87f1f
    CRC32: 3c7f05f4
    BT19.txt (621 Bytes, 下载次数: 0, 售价: 10 圆)
    Bluetooth Toolkit 19.0 Readme
    May 2019
    This file contains important information about the Bluetooth Toolkit, including installation instructions, new features, bug fixes, and known issues.
    LabWindows/CVI
    Interactive Example
    Bluetooth Toolkit Drops Support for Windows 7 and Windows Server 2008 R2 in 2021
    Bluetooth Toolkit enables you to generate and analyze Bluetooth BDR, EDR, 4.0 LE, 4.2 LE, 5.0 LE (2 Mbps and long range) signals. The toolkit also supports generation of Bluetooth 5.1 signals. Helps in characterising the performance of Bluetooth design with powerful interactive examples.
    New Features New Features in Bluetooth Analysis New Features in Bluetooth Generation
    System RequirementsBluetooth Toolkit has the following requirements:
    • 1 GHz or faster 64-bit (x64) Processor or equivalent
    • At least 2 GB of disk space
    • At least 2 GB RAM
    Required Software
    • NI-RFSA 15.0 or later
    • NI-RFSG 15.0 or later
    Bluetooth Toolkit 19.0 supports the following 64-bit operating systems:
    • Windows 10/8.1/7 SP12
    Note In 2019, Bluetooth Toolkit dropped support for all 32-bit Windows operating systems. Refer to Bluetooth Toolkit Drops Support for Windows 7 and Windows Server 2008 R2 in 2021 for information about future OS support.
    Bluetooth Toolkit 19.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by Bluetooth Toolkit
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    LabWindows™/CVI™2013 SP2 and later
    NI automates Bluetooth Toolkit installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Bluetooth Toolkit is available for download from NI Software Product Downloads.
    The following table shows the hardware models supported in Bluetooth Toolkit:
    Hardware ProductHardware Model
    Vector Signal AnalyzerPXIe-5663/5663E
    PXIe-5665
    PXIe-5668R
    Vector Signal TransceiverPXIe-5820
    PXIe-5840
    PXIe-5644R
    PXIe-5645R
    PXIe-5646R
    Vector Signal GeneratorPXIe-5673/5673E
    Behavior Changes Behavior Changes in Bluetooth Analysis Behavior Changes in Bluetooth Generation
    IDKnown Issue
    737559PN seed input property not honored in continuous mode for multi packet generation.
    The same PN seed is used for generation of each packet, thereby resulting in same payload being generated when you set the number of unique packets to greater than 1 in a continuous mode of generation.
    Bug Fixes Bug Fixes in Bluetooth Analysis Bug Fixes in Bluetooth Generation
    Accessing the APILabVIEW
    Bluetooth Toolkit VIs are available in LabVIEW from the Functions»RF Communications»Bluetooth palette.
    LabWindows/CVI
    Bluetooth Toolkit functions are available in LabWindows/CVI from the Library menu.
    Interactive Example
    To launch the Bluetooth Interactive Example, navigate to the following locations:
    Bluetooth Analysis Interactive Example
    • (Windows 7) Start»All Programs»National Instruments»Bluetooth Analysis»Bluetooth Analysis Interactive Example.
    • (Windows 10/8.1) Start»National Instruments»Bluetooth Analysis Interactive Example.
    Bluetooth Generation Interactive Example
    • (Windows 7) Start»All Programs»National Instruments»Bluetooth Generation»Bluetooth Generation Interactive Example.
    • (Windows 10/8.1) Start»National Instruments»Bluetooth Generation Interactive Example.
    To access all the installed Bluetooth Toolkit examples for LabVIEW and LabWindows/CVI, navigate to the following locations:
    • (Windows 7) Start»All Programs»National Instruments»Bluetooth Analysis Toolkit»Bluetooth Analysis Toolkit Examples.
    • (Windows 10/8.1) Start»National Instruments»Bluetooth Analysis Toolkit Examples.
    • (Windows 7) Start»All Programs»National Instruments»Bluetooth Generation Toolkit»Bluetooth Generation Toolkit Examples.
    • (Windows 10/8.1) Start»National Instruments»Bluetooth Generation Toolkit Examples.
    The documentation set is composed of the following documents.
    DocumentFormatDescriptionPath
    Bluetooth Analysis Toolkit HelpHTML/Windows HelpInformation about Bluetooth Analysis. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Analysis
    • A complete reference for all Bluetooth Analysis programming functions and VIs
    (Windows 7) Start»All Programs»National Instruments»Bluetooth Analysis»Bluetooth Analysis Toolkit Documentation
    (Windows 10/8.1) Start»National Instruments»Bluetooth Analysis»Bluetooth Analysis Toolkit Documentation
    Bluetooth Generation Toolkit HelpHTML/Windows HelpInformation about Bluetooth Generation. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to Bluetooth Generation
    • A complete reference for all Bluetooth Generation programming functions and VIs
    (Windows 7) Start»All Programs»National Instruments»Bluetooth Generation»Bluetooth Generation Toolkit Documentation
    (Windows 10/8.1) Start»National Instruments»Bluetooth Generation»Bluetooth Generation Toolkit Documentation
    Bluetooth Toolkit ReadmeHTML (this document)Information about supported hardware and operating systems, new features, fixed issues, and legal notices.(Windows 7) Start»All Programs»National Instruments»Bluetooth»Bluetooth Toolkit Readme
    (Windows 10/8.1) Start»National Instruments»Bluetooth Toolkit Readme
    How to Use NI Software with Microsoft Windows 8.1
    Bluetooth Toolkit will drop support for Windows 7 and Windows Server 2008 R2 starting from 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2009–2019 National Instruments. All rights reserved.
    378073A-01
    GMT+8, 2026-4-23 09:13
