查看: 5545|回复: 0
[LV工具模块] NI Automotive Diagnostic Command Set Toolkit 20.6 Win32/64Eng 汽车诊断命令集工具包ADCS20.6
    8 小时前
  • 签到天数: 3849 天
    连续签到: 42 天
    发表于 2020-12-11 23:34:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    汽车诊断命令集工具包Automotive Diagnostic Command Set Toolkit
    汽车诊断命令集工具包为ECU生产测试设计和开发汽车诊断应用程序。
    汽车诊断命令集(ADCS)工具包是LabVIEW、LabWindows/CVI和Microsoft Visual Studio的软件附件。该附件适用于一系列汽车诊断应用,通常包括读取和写入参数、访问故障诊断代码(DTC)、闪存ECU固件以及启动ECU诊断测试模式。借助ADCS工具包,您可以开发单个应用程序,并根据需要随时进行部署,而无需额外部署或runtime许可证。该附件与许多NI汽车接口设备兼容,可简化各种便携式和车载诊断应用的开发,并提供对UDS、OBD、WWH-OBD等协议的支持。LabWindows标志经Microsoft公司授权使用。Windows是Microsoft公司在美国和其他国家的注册商标。
    ADCS20.6
    文件大小: 1035565056 字节 (987.59 MB)
    修改日期: 2020-12-09 08:07
    MD5: a6483a4a76b8c8a4cb63c03ff33cd43c(官方正确)
    SHA1: 59247cb533663d0fd95d02683d0dd02091d3c9d1
    SHA256: 2f73cee8b2e2cd7fef6fb1a277faac14263840f954e40f15898e82041bbef5f5
    CRC32: 10523a8e
    ADCS20.6.txt (636 Bytes, 下载次数: 10, 售价: 10 圆)
    Automotive Diagnostic Command Set Toolkit 20.6 Readme
    October 2020
    This file contains important information about the Automotive Diagnostic Command Set Toolkit software for Windows and LabVIEW Real-Time (RT), including installation instructions, new features, and known issues.
    ECU Simulator
    Using NI-XNET with the Automotive Diagnostic Command Set Toolkit
    Additional Programming Topics and Known Issues
    The Automotive Diagnostic Command Set Toolkit helps you design and implement automotive diagnostic applications for ECU production test.
    Automotive Diagnostic Command Set Toolkit 20.6 supports the following operating systems:
    • Windows Server 2008 R2 SP11 (64-bit, not supported on Server Core Role)
    Note  In 2016, NI dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. Automotive Diagnostic Command Set Toolkit will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Automotive Diagnostic Command Set Toolkit to an unsupported OS. Additionally, after installing this version of Automotive Diagnostic Command Set Toolkit, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ADCS Toolkit Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    Automotive Diagnostic Command Set Toolkit will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    This version of Automotive Diagnostic Command Set Toolkit software supports the following development environments, including service packs.
    Application SoftwareVersions Supported by Automotive Diagnostic Command Set Toolkit 20.0
    LabVIEW2017 SP1, 2018 SP1, 2019 SP1, 2020 SP1
    LabVIEW Real-Time Module2017, 2018 SP1, 2019, and 2020
    LabWindows™/CVI™2015 and later
    Microsoft Visual C/C++2008 and later
    Note  Automotive Diagnostic Command Set Toolkit software does not support LabWindows™/CVI™ Real-Time Module.
    NI installs Automotive Diagnostic Command Set Toolkit using NI Package Manager. If you do not already have NI software installed, Automotive Diagnostic Command Set Toolkit installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • If applicable, install an application development environment (ADE), such as LabVIEW, LabWindows/CVI, or Microsoft Visual Studio.
    • MSVC and LabWindows/CVI users should always install the MSVC Support feature.
    New FeaturesNew Features and Changes as Compared to Automotive Diagnostic Command Set 20.0
    The Automotive Diagnostic Command Set 20.6 release adds the following features:
    • Added support for XNET IP Stack.
    • Added support for LabVIEW 2020 SP1.
    • Added support for LabWindows/CVI 2020.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 19.5
    The Automotive Diagnostic Command Set 20.0 release adds the following features:
    • Added support for LabVIEW 2020.
    • Added support for LabWindows™/CVI™ 2020.
    • Added support for the PXIe-8522 4-Port, 1000BASE-T1 PXI Automotive Ethernet Interface Module
    • Added support for the PXIe-8523 4-Port, 100/1000BASE-T1 PXI Automotive Ethernet Interface Module
    New Features and Changes as Compared to Automotive Diagnostic Command Set 18.5
    The Automotive Diagnostic Command Set 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for LabVIEW Linux PXI RT.
    • Added support for LabWindows™/CVI™ 2019.
    • Added 0xFF flag for DoIP broadcast messages.
    • Added support for session-based properties.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 PXI Automotive Ethernet Interface Module.
    • Added support for installation through NI Package Manager.
    • Removed support for LabVIEW 2015.
    • Removed support for LabWindows™/CVI™ 2012 and 2013 (without SP1).
    • Removed support for NI-CAN 15.0.
    • Removed support for NI-XNET 15.0.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 18.0
    The Automotive Diagnostic Command Set 18.5 release adds the following features:
    • Added support for LabVIEW 2018 SP1.
    • Added support for Diagnostic over IP 2012 Protocol Version.
    • Added support for Tester Present Auto Timing.
    • Added support for ECU Determined CAN I/O Mode​. CAN I/O mode can be set to "ECU Determined" to use ECUs with CAN 2.0 or CAN FD.
    • Added Response Plausibility Check property​. Defines whether the first byte of the diagnostic response is checked to contain the + 0x40 offset (positive response) or whether the first byte is 0x7F (negative response)​.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 15.0
    The Automotive Diagnostic Command Set 18.0 release adds the following features:
    • Added support for LabVIEW 2016, LabVIEW 2017, and LabVIEW 2018.
    • Added support for ISO CAN FD.
    • Added support for Diagnostic over IP over non-primary NICs.
    • Added support for LIN sleep for UDS.
    • Removed support for LabVIEW 2012, LabVIEW 2013, and LabVIEW 2014.
    • Removed support for LabWindows™/CVI™ 2010 and earlier versions.
    New Features and Changes as Compared to Automotive Diagnostic Command Set 14.0
    The Automotive Diagnostic Command Set 15.0 release adds the following features:
    • Added support for LabVIEW 2015.
    • Removed support for LabVIEW 2011.
    • Added support for 64-bit LabVIEW and C/C++.
    • Added support for CompactRIO Real-Time Controllers supported by NI-XNET 15.0 (NI cRIO-9081, NI cRIO-9082, NI cRIO-903x).
    New Features and Changes as Compared to Automotive Diagnostic Command Set 1.2
    The Automotive Diagnostic Command Set 14.0 release adds the following features:
    • Added support for LabVIEW 2014.
    • Removed support for LabVIEW 2010.
    • Added support for WWH-OBD (World-Wide-Harmonized On-Board Diagnostics) based on ISO 27145.
    • Added the new Get Time Stamp function to measure timestamp information of the first/last send/received frame of the ISO TP for CAN and LIN.
    • Added support for NI cRIO-9068 Controller (based on NI Linux Real-Time OS).
    The Automotive Diagnostic Command Set Toolkit software supports the following software and hardware:
    • NI-CAN software version 16.0 or later
    • NI-CAN hardware supported by NI-CAN 16.0
    • NI-XNET software version 16.0 or later
    • NI-XNET CAN and LIN hardware supported by NI-XNET 16.0 or later
    • NI-XNET Automotive Ethernet hardware supported by NI-XNET 19.0 or later3
    • CompactRIO and R-Series hardware using NI 9852/9853 two-port CAN modules for NI CompactRIO (we recommend using NI 986x on NI CompactRIO instead of NI 985x)
    3 You can address NI-XNET Automotive Ethernet devices using their assigned IP addresses. To use a specific interface name (e.g., ENET1) together with a custom IP configuration, you can use an XNET IP Stack from ADCS. The IP Stack feature requires NI-XNET 20.1 or later.
    Note  Automotive Diagnostic Command Set Toolkit software supports only NI Automotive Ethernet, CAN, and LIN hardware products. For information about software for Automotive Ethernet, CAN, and LIN hardware products from other vendors, refer to the documentation you received with those products.
    ECU Simulator
    The Automotive Diagnostic Command Set Toolkit software provides an ECU simulation for CAN and LIN. All examples of the Automotive Diagnostic Command Set Toolkit are preconfigured to communicate with the ECU simulation.
    LabVIEW users can find the ECU simulator under \\examples\Automotive Diagnostic Command Set\ADCS Demo ECUs.llb.
    Microsoft Visual C/C++ and LabWindows/CVI users can find the ECU simulators at
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU CAN Ethernet, or
    • \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C\ADCS Demo ECU LIN.
    If you are using NI hardware that is supported by NI-XNET, it is recommended that you use NI-XNET 19.0 or later with this version of Automotive Diagnostic Command Set Toolkit.
    CAN FD support with the Automotive Diagnostic Command Set Toolkit
    CAN FD features are only supported with NI-XNET version 17.0.1 or later.
    Recommended Maximum Message Length for CAN FD
    NI recommends the following maximum message length for CAN FD based on the system RAM size.
    System RAM SizeMaximum Message Length
    ≤512 MB8 MB
    512 MB – 3.5 GB64 MB
    >3.5 GB256 MB
    The Automotive Diagnostic Command Set Toolkit software installs the necessary C/C++ support files in the following locations:
    • The typical path to the C examples folder is \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Examples\MS Visual C.
    • The header file for Visual C/C++ 2008 and 2015 is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\include folder.
    • The library file is in the Program Files\National Instruments\Shared\ExternalCompilerSupport\C\lib32\msvc folder.
    Using the VW Transport protocol with NI-XNET:
    • If you are using the VW Transport Protocol on NI-XNET hardware, we suggest using the Frame Stream Input and Output Mode. Example: CAN1@ni_genie_nixnet uses CAN interface 1 on NI-XNET with Frame Stream Mode.
    Automotive Diagnostic Command Set Toolkit 20.0 has fixed parameter lists and calling conventions of a subset of functions introduced with Automotive Diagnostic Command Set Toolkit 19.0. Requires recompiling all C/C++/CVI applications built with Automotive Diagnostic Command Set 19.0 and using one of the following functions:
    • ndDoIPSendVehicleIdentReqEIDAllVersions
    • ndDoIPSendVehicleIdentRequestAllVersions
    • ndDoIPSendVehicleIdentReqVINAllVersions
    • ndDoIPGetEntitiesAllVersions
    • ndDoIPConnectVersion
    You can access the software and documentation known issues list online. Visit ADCS Known Issues for an up-to-date list of known issues.
    You can access the Automotive Diagnostic Command Set Toolkit 20.6 bug fix list online at ADCS 20.6 Bug Fixes. This list describes a subset of issues fixed in this release. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the Automotive Diagnostic Command Set Toolkit Help, accessible from \Users\Public\Documents\National Instruments\Automotive Diagnostic Command Set\Documentation, for information about the Automotive Diagnostic Command Set Toolkit.
    The help includes an introduction to diagnostic protocols. It also explains how to get started with application development and includes a complete reference for all Automotive Diagnostic Command Set Toolkit functions.
    © 2009–2020 National Instruments. All rights reserved.
    375413G-01
    GMT+8, 2026-4-7 17:20
