查看: 32|回复: 0
[NI软件产品] NI VeriStand 2026 Q1 and Drivers Win11 64bitEng VerStand PC版完整版及运行版2026Q1 NIVS26.0.0含驱动版7.95GB
    7 小时前
  • 签到天数: 3843 天
    连续签到: 36 天
     楼主| 发表于 前天 16:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    发布日期:2026/1/28
    包含的版本:2026 Q1 PC版、完整版、运行版,版本号26.0.0
    Windows Server 2025
    语言:英文English
    文件大小: 8539566080 字节 (7.95 GB)
    修改日期: 2026-02-07 17:44
    MD5: ec4dd44b5d5b228c71810448699dbf5b
    SHA1: 18a1eea3691034a12a20f1481720b87fa2970498
    SHA256: 47bc69665fa11651d7e6a298dbdd475764d341902ffa4b86dadc9712d6d1cdc6
    SHA512: 2d5b67b551cd539551f05cddf78712d57ccf699f172e523e7257e4ee9fa8f91704821896fb70c7503cee4072e40afe3735b8a1a7ee9acad51e38827836946167
    VeriStand 2026 Q1 and Drivers.txt (650 Bytes, 下载次数: 0, 售价: 20 圆)
    VeriStand 2026 Q1 New Features
    VeriStand Engine Performance Improvement
    Removed redundant memory copies to improve Data Processing Loop execution time.
    GUI support for Runtime Configuration Feature
    Users can now configure runtime-configurable channels using the VeriStand Editor and use these channels which are added at runtime across VeriStand controls, charts, and other components of Veristand Editor.
    Enhancements
    Optimized Rx operations in Ballard ARINC 429 custom device.
    VeriStand Steps for TestStand 2026 Q1
    VeriStand Steps for TestStand 2026 Q1 release provides compatibility for TestStand 2025 and TestStand 2026.
    Related concepts:
    2026Q1版未更新自述文件,参考2023Q3版
    VeriStand 2023 Q3 Readme
    This file contains installation instructions and compatibility information for VeriStand 2023 Q3.
    • VeriStand Documentation: Detailed documentation about how to use your product
    VeriStand 2023 Q3 installs with the following:
    • NI-DAQmx 2023 Q3
    • NI-VISA 2023 Q3
    • NI-SLSC 2022 Q4
    • NI-XNET 2023 Q2
    • NI R Series Multifunction RIO 2023 Q3
    Simulation Models
    To create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions.
    .NET
    VeriStand 2023 Q3 supports the following operating systems:
    Windows Systems
    Real-Time Targets
    • Windows 11 64-bit version 22H2
    • Windows 10 64-bit version 22H21
    When formatting a disk with a PXI Linux RT system image for VeriStand 2023 Q3, select Linux RT System Image 2023 Q3 and enable support for the LabVIEW 2023 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target.
    Online Installer
    Installation Media
    The following sections describe issues to be aware of when you upgrade to VeriStand 2023 Q3.
    Note  NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2023 Q3. To access the documents, refer to the VeriStand Release Notes.
    Primary Control Loop (PCL) Timing Source
    As of VeriStand 2023 Q2, the System Explorer default for the PCL DAQ timing source is Signal From Task (Sample Complete). This default applies to new projects under the following conditions:
    • Setting the timing source to DAQ Timing.
    • Setting the timing source to Automatic Timing when a NI-DAQ device has at least one analog input hardware-timed single point channel.
    Note  This behavior will not change for existing, upgraded projects.
    Uncompiled Models
    Models compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions.
    Note  Models built with LabVIEW 2023 Q1 and later no longer support simulation subsystems developed using the LabVIEW Control Design and Simulation Module add-on.
    Migrating Files from VeriStand 2010 through 2018 SP1
    VeriStand 2023 Q3 can open projects from VeriStand 2010 through 2018 SP1 using the Open Legacy Project option in the Welcome tab.
    LabVIEW can no longer automate actions with legacy stimulus profiles. Consider migrating to modern stimulus profiles and real-time sequences.
    In addition, the following LabVIEW automation VIs are deprecated and no longer included with VeriStand:
    • NI VeriStand - Get Alarm Status.vi
    • NI VeriStand - Get Engine State.vi
    • NI VeriStand - Lock Workspace File.vi
    • NI VeriStand - Run Workspace File.vi
    • NI VeriStand - Stop Workspace File.vi
    • NI VeriStand - Unlock Workspace File.vi
    Resource
    Contents
    Access Instructions
    VeriStand HelpConceptual, how-to, and reference information for using VeriStand.In software: Help»Show VeriStand Help
    OR
    Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 Help
    VeriStand .NET API HelpReference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand.Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 .NET API Help.
    • VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2023\Projects\Example directory.
    • Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2023\Examples directory.
    • ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2023\Examples directory.
    • LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2023\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2023\examples\NI VeriStand Custom Devices directory.
    GMT+8, 2026-4-1 07:27
