查看: 5942|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 18.0 and Patch Win32/64Eng 以太网控制自动化技术工业通信软件18.0版及补丁下载
    2 小时前
    发表于 2020-11-13 23:25:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    18.0
    文件大小: 445892488 字节 (425.24 MB)
    修改日期: 2018-05-23 15:20
    MD5: 9b8fa208be9fed7799f1ce96d1f3531b
    SHA1: d95f534c92e32380a3b1839d4d6de6ad45873d5e
    SHA256: a9d44827ff2ece152b49daec9471ff7069d478a1f7d79cce1231ac1b07a3ab43
    CRC32: 3641b1cd
    18.0Patch
    安装补丁之前请先安装NI-Industrial Communications for EtherCAT 18.0。
    文件大小: 27601288 字节 (26.32 MB)
    修改日期: 2018-08-27 23:05
    MD5: 47115e53e8284eec0f36b7bffc4849f7
    SHA1: 79da1235cf43ee9b08278677bdeea87ba62e96dc
    SHA256: 55fbe1c5c1b6e221f9e3aedf8882707ebf5d7bcc4efbb53977253c35852c3e02
    CRC32: 2e9b2b1a
    NIIndComECAT18.0.txt (1.27 KB, 下载次数: 1, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT® 18.0 Readme
    March 2018
    This file contains important information about the NI-Industrial Communications for EtherCAT software, including installation instructions, new features, and known issues.
    Supported EtherCAT Masters
    The NI-Industrial Communications for EtherCAT software provides an EtherCAT master driver to support the real-time EtherCAT network operations. Use the software with the LabVIEW Real-Time Module to configure the EtherCAT network and map the EtherCAT device signals to the LabVIEW I/O variables.
    The NI-Industrial Communications for EtherCAT supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Note  In 2016 NI-Industrial Communications for EtherCAT dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Industrial Communications for EtherCAT 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherCAT 18.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherCAT 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Software Requirements
    To install the NI-Industrial Communications for EtherCAT software, install the following prerequisite software.
    • LabVIEW 2015 SP1 or later
    • LabVIEW 2015 SP1 Real-Time Module or later
    • NI CompactRIO Device Drivers May 2018
    • NI 9144 and NI 9145 are the only EtherCAT slaves that have FPGA support in LabVIEW. To use the NI 9144/9145 in FPGA Mode, install the LabVIEW 2014 FPGA Module or later on the host computer and then download a bitfile to the FPGA of the NI 9144/9145. You can compile or copy a bitfile to download to the FPGA.
    • NI 951x Series drive interface modules require the LabVIEW 2014 SoftMotion Module or later to work for EtherCAT.
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software:
    • Insert the NI-Industrial Communications for EtherCAT software media. The installer launches automatically. If the installer does not launch automatically, navigate to the media and launch the autorun.exe file.
    • Follow the installation wizard to install the NI-Industrial Communications for EtherCAT software.
    Note  Refer to NI-Industrial Communications for EtherCAT® Installation Guide to learn how to install the NI-Industrial Communications for EtherCAT software on the real-time controller. This manual is available in printed-format shipped with the media.
    New Features and ChangesVersion 18.0
    • Added support for LabVIEW 2018.
    • Added support for cRIO-905x.
    • Added support for new C Series modules—NI 9210/9224/9228.
    • Dropped support for the C Series module—NI 9233.
    Version 17.6
    • Added support for LabVIEW 2017 SP1.
    • Added support for cRIO-904x.
    Version 17.0
    • Added support for LabVIEW 2017.
    • Added support for the new C Series module—NI 9266.
    Version 16.1
    • Added support for the new EtherCAT slave—NI 9145.
    Version 16.0
    • Added support for LabVIEW 2016.
    • Added support for cRIO-9032/9035 (Sync)/9037/9039 (Sync).
    • Added support for new C Series modules—NI 9209/9216/9226/9344/9436.
    • Added support for IC-3171/3172/3173.
    • Added support for Remote I/O. Remote I/O is a modular I/O system for measurement, machine control, and industrial automation. NI provides Remote I/O API for communicating with Remote I/O devices in an EtherCAT environment.
    Version 15.0
    • Added support for LabVIEW 2015.
    • Added support for new C Series modules—NI 9220/9222/9223/9242/9244/9437.
    • Added support for sbRIO-9607/9627.
    Version 14.5
    • Added support for LabVIEW 2014 SP1.
    • Added support for new CompactRIO real-time controllers.
    Version 14.0
    • Added EtherCAT master support for new real-time controllers.
    • Added support for new C Series modules—NI 9212 and NI 9218.
    Version 2.7
    • Added support to import device profiles to real-time controllers.
    Version 2.6
    • Added support for cRIO-9068.
    • Added support for new C Series modules—NI 9381 and NI 9482.
    Version 2.5
    • Added support for more than eight modules on third-party modular slave devices.
    • Added support for 4-port slave devices when DC is not enabled.
    Version 2.4
    • Added support for sending and receiving raw PDO data.
    • Added support for monitoring slave device states.
    Version 2.3
    • Fixed a latency issue caused by using fiber-optic converters in an EtherCAT network.
    • Added support for third-party C Series modules in the NI 9144 FPGA mode.
    • Added support for using Remote Programmatic API with the LabVIEW Run-Time Engine.
    • Extended the maximum scan period to 1 second.
    Version 2.2
    • Added support for cable redundancy.
    • Added support for Modular Device Profiles.
    • Added support for cRIO-908x.
    Version 2.1
    • Improved the performance of user-defined variables.
    Version 2.0
    • Added support for Programmatic Configuration.
    • Added support for synchronization among multiple NI EtherCAT masters.
    • Added support for PXIe-8133 and RT desktop target.
    • Added support for NI 9214 C Series Module.
    Version 1.2
    • Added support for cRIO-9023, NI 9792, and EVS-146x Series.
    • Added support for new C Series modules.
    Version 1.1
    • Added LabVIEW FPGA Module support for the NI 9144.
    • Added support for Industrial Controllers and cRIO-9024.
    • Added support for new C Series modules, including the NI 951x Motion modules.
    Version 1.0.2
    • Fixed incorrect installer dependency.
    Version 1.0.1
    • Added support for cRIO-9022.
    Version 1.0
    • Initial support for the EtherCAT protocol.
    The following table lists the supported EtherCAT masters and the earlist supported version of the NI-Industrial Communications for EtherCAT.
    EtherCAT MasterEarliest Supported Version
    cRIO-90741.0
    PXI-81061.0
    PXIe-81301.0
    PXI-81041.0
    PXI-81831.0
    PXI-81451.0
    cRIO-90221.01
    PXI-81081.01
    cRIO-90241.1
    NI 31001.1
    NI 31101.1
    cRIO-90231.2
    cRIO-90251.2
    NI 97921.2
    EVS 1463RT1.2
    EVS 1464RT1.2
    All real-time embedded PXI controllers with the PXI-8231 or PXI-8232 Ethernet interface2.0
    PXIe-81332.0
    PCI-82322.0
    PCIe-82312.0
    PCIe-82332.0
    PCIe-82352.0
    cRIO-90812.2
    cRIO-90822.2
    RMC-8354RT2.5
    RMC-8355RT2.5
    PXI-81092.5
    PXI-81152.5
    PXIe-81152.5
    PXIe-81352.5
    cRIO-90682.6
    cRIO-903014.0
    cRIO-903114.0
    cRIO-903314.0
    cRIO-906714.0
    sbRIO-965114.0
    cDAQ-9132RT14.0
    cDAQ-9134RT14.0
    cDAQ-9139RT14.0
    PXI-884014.0
    PXIe-884014.0
    CVS-1457RT14.0
    PXI-811914.0
    PXIe-811914.0
    PXIe-888014.0
    cRIO-903514.5
    cRIO-903614.5
    cRIO-903814.5
    cRIO-903914.5
    cRIO-906414.5
    cRIO-906514.5
    cDAQ-9133RT14.5
    cDAQ-9135RT14.5
    sbRIO-960715.0
    sbRIO-962715.0
    cDAQ-9136RT15.0
    cDAQ-9137RT15.0
    CVS-1458RT15.0
    cRIO-903216.0
    cRIO-903716.0
    cRIO-9035 (Sync)16.0
    cRIO-9039 (Sync)16.0
    IC-317116.0
    IC-317216.0
    IC-317316.0
    cRIO-904x17.6
    cRIO-905x18.0
    Note  NI does not recommend using cDAQ real-time controllers with the NI 9144/9145 EtherCAT slave device in FPGA mode, because cDAQ real-time controllers cannot read user-defined variables from the NI 9144/9145 EtherCAT slave device. When using a cDAQ real-time controller as the master device, you can only read EtherCAT device signals from the LabVIEW I/O Variable Functions. You cannot read directly from the LabVIEW I/O variables.
    Note  If you use NI Measurement & Automation Explorer (MAX) to install the NI-Industrial Communications for EtherCAT software on real-time controllers, some controllers, such as the Embedded Vision System, require you to install the controller driver software. Otherwise, MAX cannot discover the controllers.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-Industrial Communications for EtherCAT software.
    Refer to the NI-Industrial Communications for EtherCAT® Help, available by selecting Help»NI-Industrial Communications for EtherCAT from LabVIEW, for information about the NI-Industrial Communications for EtherCAT software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherCAT folder to access the examples.
    You can also find the examples for NI-Industrial Communications for EtherCAT® in the labview\examples\indcomecat folder.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2008–2018 National Instruments. All rights reserved.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    374786J-01
    GMT+8, 2026-4-23 10:36
