查看: 515|回复: 0
[NI驱动程序] NI CompactRIO and Drivers 2025 Q3 Win11 32/64bitEng/Jpn/Chn NI-CompactRIO和驱动程序25.5.0-32/64位英文/日语/中文版
     楼主| 发表于 2025-8-14 10:21:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    语言:中文/英文/日文
    文件大小: 3936446464 字节 (3.67 GB)
    修改日期: 2025-07-24 11:23
    MD5: 508206b5e1f512efc8cb5835000abd3c
    SHA1: ffcba61b87a8a5f4158b8dd9596a49885203ef5b
    SHA256: 046718ac22e6374d6ffd0bc77a08268675541f50f193e2476c656647bbafb1be
    CRC32: 8edf52f8
    请注册和登录论坛,购买附件查看下载地址
    CompactRIO and Drivers2025Q3.txt (619 Bytes, 下载次数: 0, 售价: 20 圆)
    2025Q3版未更新自述文件,参考2023Q3版
    NI CompactRIO 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI CompactRIO 2023 Q3.
    • NI CompactRIO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI CompactRIO Documentation: New features, behavior changes, and other documentation
    Installing NI CompactRIO 2023 Q3 requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    NI CompactRIO 2023 Q3 supports the following operating systems:
    NI CompactRIO 2023 Q3 supports the following application software versions, including service packs.
    Versions Supported by NI CompactRIO 2023 Q3
    LabVIEW2020 or later
    Note: NI CompactRIO 2023 Q3 supports 64-bit version of LabVIEW RT 2022 Q3 or later and LabVIEW FPGA 2022 Q3 or later.
    Download the NI CompactRIO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO and Drivers to access the software documentation for your NI CompactRIO device.
    NI CompactRIO and Drivers no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-1-13 08:10
