查看: 3599|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 16.0 Win32/64Eng 以太网控制自动化技术工业通信软件16.0版下载
    2 小时前
    发表于 2020-11-13 23:15:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    16.0
    文件大小: 383801224 字节 (366.02 MB)
    修改日期: 2016-07-20 22:25
    MD5: e1be2ac2289b97ac480264ef9e178ab7
    SHA1: ed92c9df81914d18425ea01765a13d72af7f3c4c
    SHA256: 3a250126385d419e14b016064b18a504ef44194a8f84d8949afc3700146b385f
    CRC32: 8ffe0e09
    NIIndComECAT16.0.txt (656 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT® 16.0 Readme
    June 2016
    This file contains important information about the NI-Industrial Communications for EtherCAT software, including installation instructions, new features, and known issues.
    Supported EtherCAT Masters
    Driver Version Naming Changes
    The NI-Industrial Communications for EtherCAT software provides an EtherCAT master driver to support the real-time EtherCAT network operations. Use the software with the LabVIEW Real-Time Module to configure the EtherCAT network and map the EtherCAT device signals to the LabVIEW I/O variables.
    The NI-Industrial Communications for EtherCAT supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Software Requirements
    To install the NI-Industrial Communications for EtherCAT software, install the following prerequisite software.
    • LabVIEW 2013 or later
    • LabVIEW 2013 Real-Time Module or later
    • NI CompactRIO Device Drivers August 2016
    • NI 9144 is the only EtherCAT slave that has FPGA support in LabVIEW. To use the NI 9144 in FPGA Mode, install the LabVIEW 2012 FPGA Module or later on the host computer and then download a bitfile to the FPGA of the NI 9144. You can compile or copy a bitfile to download to the FPGA.
    • NI 951x Series drive interface modules require the LabVIEW 2012 SoftMotion Module or later to work for EtherCAT.
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software:
    • Insert the NI-Industrial Communications for EtherCAT software media. The installer launches automatically. If the installer does not launch automatically, navigate to the media and launch the autorun.exe file.
    • Follow the installation wizard to install the NI-Industrial Communications for EtherCAT software.
    Note  Refer to NI-Industrial Communications for EtherCAT® Installation Guide to learn how to install the NI-Industrial Communications for EtherCAT software on the real-time controller. This manual is available in printed-format shipped with the media.
    NI-Industrial Communications for EtherCAT 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-Industrial Communications for EtherCAT drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-Industrial Communications for EtherCAT 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Industrial Communications for EtherCAT 16.0 to an unsupported OS. Additionally, after installing NI-Industrial Communications for EtherCAT 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    New FeaturesVersion 16.0
    • Added support for LabVIEW 2016.
    • Added support for NI cRIO-9032/9035 (Sync)/9037/9039 (Sync).
    • Added support for new C Series modules—NI 9209/9216/9226/9344/9436.
    • Added support for IC-3171/3172/3173.
    • Added support for Remote I/O. Remote I/O is a modular I/O system for measurement, machine control, and industrial automation. NI provides Remote I/O API for communicating with Remote I/O devices in an EtherCAT environment.
    Version 15.0
    • Added support for LabVIEW 2015.
    • Added support for new C Series modules—NI 9220/9222/9223/9242/9244/9437.
    • Added support for NI sbRIO-9607/9627.
    Version 14.5
    • Added support for LabVIEW 2014 SP1.
    • Added support for new CompactRIO real-time controllers.
    Version 14.0
    • Added EtherCAT master support for new real-time controllers.
    • Added support for new C Series modules—NI 9212 and NI 9218.
    Version 2.7
    • Added support to import device profiles to real-time controllers.
    Version 2.6
    • Added support for NI cRIO-9068.
    • Added support for new C Series modules—NI 9381 and NI 9482.
    Version 2.5
    • Added support for more than eight modules on third-party modular slave devices.
    • Added support for 4-port slave devices when DC is not enabled.
    Version 2.4
    • Added support for sending and receiving raw PDO data.
    • Added support for monitoring slave device states.
    Version 2.3
    • Fixed a latency issue caused by using fiber-optic converters in an EtherCAT network.
    • Added support for third-party C Series modules in the NI 9144 FPGA mode.
    • Added support for using Remote Programmatic API with the LabVIEW Run-Time Engine.
    • Extended the maximum scan period to 1 second.
    Version 2.2
    • Added support for cable redundancy.
    • Added support for Modular Device Profiles.
    • Added support for NI cRIO-908x.
    Version 2.1
    • Improved the performance of user-defined variables.
    Version 2.0
    • Added support for Programmatic Configuration.
    • Added support for synchronization among multiple NI EtherCAT masters.
    • Added support for NI PXIe-8133 and RT desktop target.
    • Added support for NI 9214 C Series Module.
    Version 1.2
    • Added support for NI cRIO-9023, NI 9792, and EVS-146x Series.
    • Added support for new C Series modules.
    Version 1.1
    • Added LabVIEW FPGA Module support for the NI 9144.
    • Added support for Industrial Controllers and NI cRIO-9024.
    • Added support for new C Series modules, including the NI 951x Motion modules.
    Version 1.0.2
    • Fixed incorrect installer dependency.
    Version 1.0.1
    • Added support for NI cRIO-9022.
    Version 1.0
    • Initial support for the EtherCAT protocol.
    Supported EtherCAT MastersNI CompactRIO Real-Time Controllers
    • cRIO-9022
    • cRIO-9023
    • cRIO-9024
    • cRIO-9025
    • cRIO-9030
    • cRIO-9031
    • cRIO-9033
    • cRIO-9035
    • cRIO-9036
    • cRIO-9038
    • cRIO-9039
    • cRIO-9064
    • cRIO-9065
    • cRIO-9067
    • cRIO-9068
    • cRIO-9074
    • cRIO-9081
    • cRIO-9082
    • NI 9792
    Note  The NI CompactRIO real-time controllers have the following additional software requirements:
    • The cRIO-9035, cRIO-9036, cRIO-9038, cRIO-9039, cRIO-9064, and cRIO-9065 controllers require LabVIEW 2014 SP1 or later and NI-Industrial Communications for EtherCAT 14.5 or later.
    • The cRIO-9030, cRIO-9031, cRIO-9033, and cRIO-9067 controllers require LabVIEW 2014 or later and NI-Industrial Communications for EtherCAT 14.0 or later.
    • The cRIO-9068 controller requires LabVIEW 2013 and NI-Industrial Communications for EtherCAT 2.6 or later.
    • The cRIO-9081 and cRIO-9082 controllers require LabVIEW 2011 and NI-Industrial Communications for EtherCAT 2.2 or later.
    NI Single-Board RIO Controllers
    • sbRIO-9651
    • sbRIO-9607
    • sbRIO-9627
    Note  The NI Single-Board RIO controllers have the following additional software requirements:
    • The sbRIO-9651 System on Module requires LabVIEW 2014 or later and NI-Industrial Communications for EtherCAT 14.0 or later.
    • sbRIO-9607 and sbRIO-9627 require LabVIEW 2015 or later and NI-Industrial Communications for EtherCAT 15.0 or later.
    NI CompactDAQ Real-Time Controllers
    • cDAQ-9132
    • cDAQ-9133
    • cDAQ-9134
    • cDAQ-9135
    • cDAQ-9136
    • cDAQ-9137
    • cDAQ-9139
    Note  The NI CompactDAQ real-time controllers have the following additional software requirements:
    • cDAQ-9132, cDAQ-9134, and cDAQ-9139 require LabVIEW 2014 or later and NI-Industrial Communications for EtherCAT 14.0 or later.
    • cDAQ-9133 and cDAQ-9135 require LabVIEW 2014 SP1 or later and NI-Industrial Communications for EtherCAT 14.5 or later.
    • cDAQ-9136 and cDAQ-9137 require LabVIEW 2015 or later and NI-Industrial Communications for EtherCAT 15.0 or later.
    Note  NI does not recommend using cDAQ real-time controllers with the NI 9144 EtherCAT slave device in FPGA mode, because cDAQ real-time controllers cannot read user-defined variables from the NI 9144 EtherCAT slave device. When using a cDAQ real-time controller as the master device, you can only read EtherCAT device signals from the LabVIEW I/O Variable Functions. You cannot read directly from the LabVIEW I/O variables.
    Embedded Real-Time Controllers with the NI PXI-8231, NI PXI-8232, or NI PXI-8234 Ethernet Interface
    • All real-time embedded NI PXI controllers
    Embedded Real-Time Controllers with Two Built-in Ethernet Adapters
    • NI PXI-8109
    • NI PXI-8115
    • NI PXI-8119
    • NI PXI-8840
    • NI PXIe-8119
    • NI PXIe-8115
    • NI PXIe-8133
    • NI PXIe-8135
    • NI PXIe-8840
    • NI PXIe-8880
    • NI 3100
    • NI 3110
    Note  NI PXI-8840 and NI PXIe-8840 require NI-Industrial Communications for EtherCAT 14.0 or later.
    Real-Time Desktop Target with Any of the Following Ethernet Interfaces
    • NI PCI-8232
    • NI PCIe-8231
    • NI PCIe-8233
    • NI PCIe-8235
    Embedded Vision System
    • NI EVS-1463
    • NI EVS-1464
    Compact Vision System
    • NI CVS-1457RT
    • NI CVS-1458RT
    Note  NI CVS-1457RT requires NI-Industrial Communications for EtherCAT 14.0 or later. NI CVS-1458RT requires NI-Industrial Communications for EtherCAT 15.0 or later.
    Rack Mount 1U Controllers
    • NI RMC-8354
    • NI RMC-8355
    • IC-3171
    • IC-3172
    • IC-3173
    Note  If you use NI Measurement & Automation Explorer (MAX) to install the NI-Industrial Communications for EtherCAT software on real-time controllers, some controllers, such as the Embedded Vision System, require you to install the controller driver software. Otherwise, MAX cannot discover the controllers.
    NI-Industrial Communications for EtherCAT versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-Industrial Communications for EtherCAT 16.0 is the version released with LabVIEW 2016. The last version released under the old numbering scheme is NI-Industrial Communications for EtherCAT 2.7. The first version released under the new numbering scheme is NI-Industrial Communications for EtherCAT 14.0.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-Industrial Communications for EtherCAT software.
    Refer to the NI-Industrial Communications for EtherCAT® Help, available by selecting Help»NI-Industrial Communications for EtherCAT from LabVIEW, for information about the NI-Industrial Communications for EtherCAT software.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherCAT folder to access the examples.
    You can also find the examples for NI-Industrial Communications for EtherCAT® in the labview\examples\indcomecat folder.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI Measurement & Automation Explorer (MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2008–2016 National Instruments. All rights reserved.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    374786D-01
    GMT+8, 2026-4-23 10:36
