查看: 3660|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 14.0 Win32/64Eng 以太网控制自动化技术工业通信软件14.0版下载
    2 小时前
    发表于 2020-11-13 23:05:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    14.0
    文件大小: 323271456 字节 (308.30 MB)
    修改日期: 2014-08-06 14:55
    MD5: e084b8ba9d562503aaecfe5a92dd7e03
    SHA1: c7a554c5803cfa261e1f2d92a50131dcb2a73199
    SHA256: 63bacfc7cb45da1c159054e7a910b2b7d7357b1d04b78f671ed96b00e6ef656f
    CRC32: 0c567cbd
    NIIndComECAT14.0.txt (650 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT® 14.0 Readme
    June 2014
    Version 14.0
    This file contains last-minute information about the NI-Industrial Communications for EtherCAT software, including installation instructions, new features, a partial list of bugs fixed for NI-Industrial Communications for EtherCAT 14.0, and known issues.
    Driver Version Naming Changes
    The NI-Industrial Communications for EtherCAT software provides an EtherCAT master driver to support the real-time EtherCAT network operations. Use the software with the LabVIEW Real-Time Module to configure the EtherCAT network and map the EtherCAT device signals to the LabVIEW I/O variables.
    NI-Industrial Communications for EtherCAT 14.0 supports the following operating systems.
    • Windows 8.1 (32-bit and 64-bit)
    • Windows XP SP3 (32-bit)
    Note  NI-Industrial Communications for EtherCAT supports only R2 editions of Windows Server.
    Software Requirements
    To install the NI-Industrial Communications for EtherCAT software, install the following prerequisite software.
    • LabVIEW 2011 or later
    • LabVIEW 2011 Real-Time Module or later
    • NI-RIO 14.0
    • NI 9144 is the only EtherCAT slave that has FPGA support in LabVIEW. To use the NI 9144 in FPGA Mode, install the LabVIEW 2011 FPGA Module or later on the host computer and then download a bitfile to the FPGA of the NI 9144. You can compile or copy a bitfile to download to the FPGA.
    • NI 951x Series drive interface modules require the LabVIEW 2011 NI SoftMotion Module or later to work for EtherCAT.
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software on the host computer.
    • Insert the NI-Industrial Communications for EtherCAT software media into a drive. The installer launches if the drive plays media automatically. If the installer does not launch automatically, navigate to the media using Windows Explorer and launch the autorun.exe file from your NI-Industrial Communications for EtherCAT software media.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for EtherCAT software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking the Cancel button.
    • When the installation is complete, click the Finish button.
    Note  After installing the NI-Industrial Communications for EtherCAT software on the host computer, if you want to use the software on a real-time controller, refer to NI-Industrial Communications for EtherCAT® Installation Guide to learn how to install the NI-Industrial Communications for EtherCAT software on the real-time controller. This manual is available in PDF-format in the NI-Industrial Communications for EtherCAT media or in printed-format shipped with the media.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    New FeaturesVersion 14.0
    • Added EtherCAT master support for new real-time controllers. Refer to the Supported Hardware section for a list of real-time controllers that the NI-Industrial Communications for EtherCAT 14.0 software supports.
    • Added support for new C series modules—NI 9212 and NI 9218.
    Version 2.7
    • Added support to import device profiles to the real-time controllers.
    Version 2.6
    • Added support for cRIO-9068.
    • Added support for new C Series modules—NI 9381 and NI 9482.
    Version 2.5
    • Added support for more than eight modules on third-party modular slave devices.
    • Added support for 4-port slave devices when DC is not enabled.
    Version 2.4
    • Added support for sending and receiving raw PDO data.
    • Added support for monitoring slave device states.
    Version 2.3
    • Fixed a latency issue caused by using fiberoptic converters in an EtherCAT network.
    • Added support for third-party C series modules in the NI 9144 FPGA mode.
    • Added support for using Remote Programmatic API with the LabVIEW Run-Time Engine.
    • Extended the maximum scan period to 1 second.
    Version 2.2
    • Added support for cable redundancy.
    • Added support for Modular Device Profiles.
    • Added support for cRIO-908x.
    Version 2.1
    • Improved the performance of user-defined variables.
    Version 2.0
    • Added support for Programmatic Configuration.
    • Added support for synchronization among multiple NI EtherCAT masters.
    • Added support for PXIe-8133 and Real-Time Desktop target.
    • Added support for NI 9214 C Series Module.
    Version 1.2
    • Added support for cRIO-9023, NI 9792, and EVS-146x Series.
    • Added support for new C series modules.
    Version 1.1
    • Added LabVIEW FPGA Module support for the NI 9144.
    • Added support for Industrial Controller and cRIO-9024.
    • Added support for new C series modules, including the NI 951x Motion modules.
    Version 1.0.2
    • Fixed incorrect installer dependency.
    Version 1.0.1
    • Added support for cRIO-9022.
    Version 1.0
    • Initial support for NI-Industrial Communications for EtherCAT.
    Refer to Supported Hardware for NI-Industrial Communications for EtherCAT for the latest information about the hardware that the NI-Industrial Communications for EtherCAT software supports.
    NI-Industrial Communications for EtherCAT versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-Industrial Communications for EtherCAT 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-Industrial Communications for EtherCAT 2.7. The first version released under the new numbering scheme is NI-Industrial Communications for EtherCAT 14.0.
    Refer to the NI-Industrial Communications for EtherCAT® Help, available by selecting Help»NI-Industrial Communications for EtherCAT from LabVIEW, for information about using the NI-Industrial Communications for EtherCAT software.
    LabVIEW examples for the NI-Industrial Communications for EtherCAT software are in the labview\examples\indcomecat folder. You can modify an example VI to fit an application or copy an example and paste the example to a VI you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the NI-Industrial Communications for EtherCAT software.
    The following items are the ID and title of a subset of issues fixed in the NI-Industrial Communications for EtherCAT software. This is not an exhaustive list of issues fixed in the current version of the NI-Industrial Communications for EtherCAT software. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    477512Correct the calibration parameters for NI 9235/9236
    Using NI Launcher
    Finding All Programs
    NI-Industrial Communications for EtherCAT Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for EtherCAT will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for EtherCAT that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2008–2014 National Instruments. All rights reserved.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    GMT+8, 2026-4-23 10:36
