查看: 3443|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 2.1 Win32/64Eng 以太网控制自动化技术工业通信软件2.1版下载
    2 小时前
    发表于 2020-11-13 22:48:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    2.1
    文件大小: 69925472 字节 (66.69 MB)
    修改日期: 2011-02-23 03:40
    MD5: eb78d6aa5d512c38cf3bd05838ae1c20
    SHA1: 1adb5c9a6fcba196cdbca84786398a1f5ac2cc8b
    SHA256: 108eef6ec63fd73e7798d21df73a743c21994af83968975d7c337936e7979752
    CRC32: f659b948
    NIIndComECAT2.1.txt (634 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT® ReadmeVersion 2.1February 2011
    © 2008–2011 National Instruments Corporation. All rights reserved.
    Thank you for using NI-Industrial Communications for EtherCAT, Version 2.1.
    This file contains last-minute information about the NI-Industrial Communications for EtherCAT software. Some information in this file may be too recent to be included in the official documentation set.
    Version HistoryVersion 2.1
    – Improved the performance of User-defined Variables.
    Version 2.0
    – Added support for Programmatic Configuration.
    – Added support for synchronization among multiple NI EtherCAT masters.
    – Added support for PXIe-8133 and Real-Time Desktop target.
    – Added support for NI 9214 C-Series module. For the list of supported C-Series modules, refer to NI 9144 User Guide
    Version 1.2
    – Added support for cRIO-9023, NI 9792 and EVS-146x Series.
    – Added support for new C-Series modules. For the list of supported C-Series modules, refer to NI 9144 User Guide
    Version 1.1
    – Added LabVIEW FPGA Module support for the NI 9144
    – Added support for Industrial Controller and cRIO-9024
    – Added support for new C-Series modules (including the NI 951x Motion modules). For the list of supported C-Series modules, refer to NI 9144 User Guide
    Version 1.0.2
    – Fixed incorrect installer dependency on LabVIEW 8.6.1. Support for cRIO-9022 still requires LabVIEW 8.6.1.
    Version 1.0.1
    – Added support for cRIO-9022.
    Version 1.0
    – Initial support for NI-Industrial Communications for EtherCAT.
    The NI-Industrial Communications for EtherCAT Installation Guide included with the NI-Industrial Communications for EtherCAT CD includes instructions for installing National Instruments EtherCAT software.
    The NI-Industrial Communications for EtherCAT Installation Guide is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    The NI-Industrial Communications for EtherCAT Help is the primary document for NI-Industrial Communications for EtherCAT. This help includes an introduction to EtherCAT and information about application development.
    Open the help from Start»All Programs»National Instruments»NI-Industrial Communications for EtherCAT.
    Back to Top
    You must install and run this version of the NI-Industrial Communications for EtherCAT software on the following operating systems:
    • Windows XP SP2
    • Windows Vista
    • Windows Server 2003 R2
    • Windows Server 2008 R2
    • Windows 7
      For more information about using National Instruments hardware and software products with Windows Vista, visit ni.com/vista.
    This version of the NI-Industrial Communications for EtherCAT software supports the following National Instruments hardware products on LabVIEW RT:
    • NI CompactRIO real-time controller
      – NI cRIO-9022
      – NI cRIO-9023
      – NI cRIO-9024
      – NI cRIO-9074
      – NI 9792
    • Embedded real-time controllers with the NI PXI-8231, PXI-8232 or PXI-8234 Ethernet interface
      – All real-time embedded PXI controllers
    • Embedded real-time controllers with two built-in Ethernet adapters
      – PXIe-8133
      – NI 3100 Industrial Controller
      – NI 3110 Industrial Controller
    • Real-Time Desktop target with any of the following Ethernet interfaces
      – NI PCIe-8231
      – NI PCI-8232
      – NI PCIe-8235
    • Embedded Vision System
      – EVS-1463
      – EVS-1463 RT
      – EVS-1464
      – EVS-1464 RT
    Software Requirements
    The NI-Industrial Communications for EtherCAT software requires the following software:
    • LabVIEW 8.6 or later
    • LabVIEW Real-Time Module 8.6 or later
    • NI-RIO 3.6
    Notes:
    • LabVIEW 2009 or newer version is required for using the NI 9144 in FPGA Mode. You must also have the LabVIEW FPGA Module installed on the host computer, or access to a compiled bitfile you can download to the FPGA of NI 9144.
    • The LabVIEW NI SoftMotion Module must be installed for the NI 951x Series drive interface modules to work on EtherCAT.
    Back to Top
    Installing NI-Industrial Communications for EtherCAT software
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software.
    • Insert the NI-Industrial Communications for EtherCAT software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-Industrial Communications for EtherCAT software CD.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for EtherCAT software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Back to Top
    Contacting National Instruments
    Thank you for your interest in NI-Industrial Communications for EtherCAT. We appreciate communicating with the people who use our products. We are also very interested in hearing about the applications you develop using our products. Our Web site, ni.com, provides advanced support and services and contact information.
    Back to Top
    Patent Information
    For patents covering National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    EtherCAT® is a registered trademark of Beckhoff Automation GmbH.
    Credits
    This product includes components that use the Expat XML Parser. In regards to the Expat XML Parser, the following notice applies:
    Copyright © 1998, 1999, 2000 Thai Open Source Software Center Ltd and Clark Cooper. Copyright © 2001, 2002, 2003, 2004, 2005, 2006 Expat maintainers.
    Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is furnished to do so, subject to the following conditions: The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    GMT+8, 2026-4-23 10:37
