查看: 3275|回复: 0
[NI软件产品] NI-Industrial Communications for EtherCAT 1.0 Win32/64Eng 以太网控制自动化技术工业通信软件1.0版下载
    2 小时前
    发表于 2020-11-13 22:35:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for EtherCAT提供了EtherCAT主站支持,以支持NI控制器硬件上的确定性I/O。
    NI-Industrial Communications for EtherCAT为用户使用CompactRIO控制器、PXI控制器或工业控制器提供支持。使用此软件,您可以通过使用基于EtherCAT总线的CompactRIO机箱或使用远程I/O硬件来扩展I/O。NI建议结合经过充分测试和验证的NI EtherCAT产品使用此驱动软件。
    1.0
    文件大小: 33846816 字节 (32.28 MB)
    修改日期: 2010-05-06 23:25
    MD5: bd6fbea28c49485d02b3f41518d3ffd9
    SHA1: 74f5b5ddfdd86d2cdd58f0c555902983590a3fa8
    SHA256: 3ee100875ee0c7d97ca2ce62261ec97742ec6228060d659ff4b1c5d9ae286970
    CRC32: 4115863f
    NIIndComECAT1.0.0.txt (636 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherCAT® ReadmeVersion 1.0October 2008
    © 2008 National Instruments Corporation. All rights reserved.
    Thank you for using NI-Industrial Communications for EtherCAT, Version 1.0.
    This file contains last-minute information about the NI-Industrial Communications for EtherCAT software. Some information in this file may be too recent to be included in the official documentation set.
    The NI-Industrial Communications for EtherCAT Software Installation Guide included with the NI-Industrial Communications for EtherCAT CD includes instructions for installing National Instruments EtherCAT software.
    The NI-Industrial Communications for EtherCAT Installation Guide is in Adobe Acrobat Portable Document Format (PDF). You can download the Acrobat Reader for free at: www.adobe.com.
    The NI-Industrial Communications for EtherCAT Help is the primary document for NI-Industrial Communications for EtherCAT. This help includes an introduction to EtherCAT and information about application development.
    Open the help from Start»All Programs»National Instruments»NI-Industrial Communications for EtherCAT.
    Back to Top
    You must install and run this version of the NI-Industrial Communications for EtherCAT software on the following operating systems:
    • Windows XP (32-bit)
    • Windows Vista (32-bit only)
      For more information about using National Instruments hardware and software products with Windows Vista, visit ni.com/vista.
    This version of the NI-Industrial Communications for EtherCAT software supports the following National Instruments hardware products on LabVIEW RT:
    • Integrated real-time controller with FPGA
    – NI cRIO-9074
    • Embedded real-time controllers
    – NI PXI-8106 RT
    – NI PXIe-8130 RT
    – NI PXI-8104 RT
    – NI PXI-8183 RT
    – NI PXI-8145 RT
    Software Requirements
    The NI-Industrial Communications for EtherCAT software requires the following software:
    • LabVIEW 8.6
    • LabVIEW Real-Time Module 8.6
    • NI-RIO 3.0.1
    Back to Top
    Installing NI-Industrial Communications for EtherCAT 1.0 software
    Before installing the NI-Industrial Communications for EtherCAT software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherCAT software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherCAT software.
    • Insert the NI-Industrial Communications for EtherCAT software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-Industrial Communications for EtherCAT software CD.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for EtherCAT software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing NI-Industrial Communications for EtherCAT Silently
    You can control programmatically which features in the NI-Industrial Communications for EtherCAT distribution to enable or disable for installation. You therefore can install a subset of the NI-Industrial Communications for EtherCAT distribution silently. Refer to the silent_install.txt file in the bin directory on the NI-Industrial Communications for EtherCAT CD for more information about installing NI-Industrial Communications for EtherCAT silently and selecting which features to install automatically.
    Back to Top
    EtherCAT typically uses the first slave device on the EtherCAT network as its timing source (master clock). If you change the network topology by replacing the first slave device with a new one, be sure to power cycle the new device prior to connecting it as the first device on the EtherCAT network. This clears any timing offset information stored on the new slave device. Failure to do so may result in clock synchronization errors, because the new slave device now is used as the timing source (master clock) with erroneous offset information.
    Back to Top
    Contacting National Instruments
    Thank you for your interest in NI-Industrial Communications for EtherCAT. We appreciate communicating with the people who use our products. We are also very interested in hearing about the applications you develop using our products. Our Web site, ni.com, provides advanced support and services and contact information.
    Back to Top
    Patent Information
    For patents covering National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    EtherCAT® is a registered trademark of Beckhoff Automation GmbH.
    GMT+8, 2026-4-23 10:38
