查看: 3385|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 15.0 Win32/64Eng NI以太网/IP 工业通信软件15.0下载
    2 小时前
    发表于 2020-11-12 23:53:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    15.0
    文件大小: 174111008 字节 (166.05 MB)
    修改日期: 2015-08-01 04:21
    MD5: efa521adb1d64d8312cef6ed9255904a
    SHA1: 5e03cafda79bdf5401243cb9db2b9df7c7cc4368
    SHA256: 38c1038f6419df40a4b2f04cbc1010babb80d964ad5c6ffc04cc6e62455d33eb
    CRC32: ef3625de
    IndComEIP15.0.txt (634 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP 15.0 Readme
    June 2015
    This file contains important information about NI-Industrial Communications for EtherNet/IP, including supported application software and hardware, installation instructions, and new features.
    Hardware Support
    EtherNet/IP 15.0
    EtherNet/IP 14.0
    EtherNet/IP 1.3
    EtherNet/IP 1.2.1
    EtherNet/IP 1.2
    EtherNet/IP 1.1
    Driver Version Naming Changes
    NI-Industrial Communications for EtherNet/IP contains an extensive library of VIs and properties in LabVIEW to program your customized EtherNet/IP applications for your devices.
    In addition to the system requirements for the LabVIEW Development System, NI-Industrial Communications for EtherNet/IP has the following requirements:
    • LabVIEW Base Development System
    • LabVIEW Real-Time Module (required only if you run NI-Industrial Communications for EtherNet/IP on RT targets)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for the version of LabVIEW that you run NI-Industrial Communications for EtherNet/IP on.
    The following table lists the application software versions, including service packs, supported by NI-Industrial Communications for EtherNet/IP. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-Industrial Communications for EtherNet/IP
    LabVIEW2012, 2013, 2014, 2015
    LabVIEW Real-Time Module2012, 2013, 2014, 2015
    Hardware Support
    NI-Industrial Communications for EtherNet/IP supports the following NI hardware products:
    • CompactRIO
    • Compact Vision System
    • Embedded Vision System
    • Industrial Controllers
    • NI PXI
    • NI PXIe
    • Single-Board RIO
    • Smart Cameras
    • Stand-Alone CompactDAQ
    Before installing NI-Industrial Communications for EtherNet/IP, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherNet/IP setup program must have Administrator privileges because the program modifies the configuration registry of your system.
    Double-click the setup.exe file in the root directory of the NI-Industrial Communications for EtherNet/IP installer and follow the instructions on the screen to install NI-Industrial Communications for EtherNet/IP on the host.
    Use NI Measurement & Automation Explorer (MAX) to install NI-Industrial Communications for EtherNet/IP on RT targets.
    New FeaturesEtherNet/IP 15.0
    • Added support for NI 9147
    • Added support for NI cRIO-9035/9036/9039/9063/9064/9065
    • Added support for NI sbRIO-9607/9627/9637
    • Added support for LabVIEW 2015
    EtherNet/IP 14.0
    • Added support for stand-alone CompactDAQ modules
    • Added support for LabVIEW 2014
    EtherNet/IP 1.3
    • Added support for NI cRIO-9068
    • Added support for LabVIEW 2013
    EtherNet/IP 1.2.1
    • Added support for NI License Manager
    • Added support for LabVIEW 2012
    • Resolved a problem that EtherNet/IP can not be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 2011 (64-bit)
    • Resolved a stability issue seen only in the LabVIEW 2009 Real-Time Module
    • Resolved a problem that ethernetIPInterface.dll is not exported when building an EtherNet/IP Windows application
    EtherNet/IP 1.1
    • First official release to support the EtherNet/IP protocol
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
    • Added more LabVIEW error codes to better diagnose problems
    NI-Industrial Communications for EtherNet/IP versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-Industrial Communications for EtherNet/IP 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-Industrial Communications for EtherNet/IP 1.3. The first version released under the new numbering scheme is NI-Industrial Communications for EtherNet/IP 14.0.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible from Help»NI-Industrial Communications for EtherNet/IP in LabVIEW, for information about NI-Industrial Communications for EtherNet/IP.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Hardware Input and Output»NI-Industrial Communications»EtherNet/IP folder to access the examples. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for NI-Industrial Communications for EtherNet/IP in the labview\examples\ethernetip directory.
    Using NI Launcher
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI-Industrial Communications for EtherNet/IP Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for EtherNet/IP will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for EtherNet/IP that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 2010–2015 National Instruments. All rights reserved.
    374775B-01
    GMT+8, 2026-4-23 10:38
