查看: 3353|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 1.3 Win32/64Eng NI以太网/IP 工业通信软件1.3下载
    2 小时前
    发表于 2020-11-12 23:47:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    1.3
    文件大小: 165382432 字节 (157.72 MB)
    修改日期: 2013-08-06 02:47
    MD5: ef619c701770119e63db42c9b00287ee
    SHA1: 9d9e80590fec21e0b46e0274eb0ab950978e8e1b
    SHA256: 9d21396529207b01293aa5ad9a188bf0f837a10a0f813bd10dd3180852253e9b
    CRC32: 033e8ec0
    IndComEIP1.3.0.txt (620 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP 1.3 Readme
    June 2013
    This file contains information to introduce you to the NI-Industrial Communications for EtherNet/IP. The file contains the following information that you need to understand.
    New Features and Changes
    EtherNet/IP 1.3
    EtherNet/IP 1.2.1
    EtherNet/IP 1.2
    EtherNet/IP 1.1
    NI Software Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    The NI-Industrial Communications for EtherNet/IP software contains an extensive library of VIs and properties you can call from LabVIEW to program your customized EtherNet/IP applications for your devices.
    New Features and ChangesEtherNet/IP 1.3
    • Added support for NI cRIO-9068
    • Added support for LabVIEW 2013 32-bit and 64-bit
    EtherNet/IP 1.2.1
    • Added support for NI License Manager
    • Added support for LabVIEW 2012 32-bit and 64-bit
    • (Bug ID 336355) Resolved a problem that EtherNet/IP can not be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 64-bit
    • Added support for LabVIEW 2011
    • (Bug ID 307085) Resolved a stability issue seen only in LabVIEW RT 2009
    • (Bug ID 305672) Resolved a problem that ethernetIPInterface.dll is not exported when building an EIP Windows application
    EtherNet/IP 1.1
    • First official release to support EtherNet/IP
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
    • Added more LabVIEW error codes to better diagnose problems
    System RequirementsSupported Hardware
    The NI-Industrial Communications for EtherNet/IP software supports the following NI hardware products:
    • Desktop PCs
    • NI PXI controllers
    • NI CompactRIO
    • NI Single-Board RIO
    • NI Industrial Controllers
    • NI Smart Cameras
    • NI Compact Vision System
    • NI Embedded Vision System
    Software Requirements
    In addition to the system requirements for the LabVIEW Development System, the NI-Industrial Communications for EtherNet/IP software has the following requirements:
    • LabVIEW 2010, LabVIEW 2011, LabVIEW 2012, or LabVIEW 2013
    • If you want to run the NI-Industrial Communications for EtherNet/IP software on the NI real-time hardware platforms, you should also install the LabVIEW Real-Time Module of the same version as the LabVIEW you installed.
    Before installing the NI-Industrial Communications for EtherNet/IP software, log on as Administrator or as a user with Administrator privileges. The NI-Industrial Communications for EtherNet/IP software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-Industrial Communications for EtherNet/IP software:
    • Insert the NI-Industrial Communications for EtherNet/IP software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-Industrial Communications for EtherNet/IP software CD.
    • The installation wizard guides you through the necessary steps to install the NI-Industrial Communications for EtherNet/IP software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-Industrial Communications for EtherNet/IP software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select Custom software installation.
    • Select NI-IndCom for EtherNet/IP from the feature list and click Next.
    • Follow the remaining installation instructions until installation is complete.
    NI-Industrial Communications for EtherNet/IP Updates and Notifications
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible by selecting Help»NI-Industrial Communications for EtherNet/IP from the pull-down menu in LabVIEW, for information about using the NI-Industrial Communications for EtherNet/IP software.
    LabVIEW examples for the NI-Industrial Communications for EtherNet/IP software are in the labview\examples\ethernetip folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    Finding All Programs
    NI-Industrial Communications for EtherNet/IP Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-Industrial Communications for EtherNet/IP will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-Industrial Communications for EtherNet/IP that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2010–2013 National Instruments. All rights reserved.
    GMT+8, 2026-4-23 10:36
