查看: 3282|回复: 0
[NI软件产品] NI-Industrial Communications for Ethernet/IP 1.2.1 Win32/64Eng NI以太网/IP
    2 小时前
    发表于 2020-11-12 23:43:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Industrial Communications for Ethernet/IP 1.2.1 Win32/64Eng NI以太网/IP 工业通信软件1.2.1下载
    NI-Industrial Communications for Ethernet/IP使LabVIEW系统能够作为以太网/IP网络上的以太网/IP Class 1适配器设备进行通信。
    NI-Industrial Communications for Ethernet/IP是一款应用软件,为您使用CompactRIO控制器、CompactRIO单板控制器、PXI控制器、紧凑型视觉系统、智能相机、工业控制器或独立CompactDAQ系统提供了所需的支持。它包含丰富的LabVIEW VI和属性库,助您快速为兼容的以太网/IP硬件设备创建自定义的以太网/IP应用程序。该软件具有显式消息传递和I/O数据通信机制。这些机制提供与各种可编程逻辑控制器(PLC)和以太网/IP I/O设备的通信和数据共享。
    1.2.1
    文件大小: 165539976 字节 (157.87 MB)
    修改日期: 2012-09-10 22:18
    MD5: 70962e52699714b27f741305dfc088ee
    SHA1: 52bb168aadfc399dab9d447015dc601e03b37a60
    SHA256: 2bd2e6b54ed63c9f602e8aac8781a1e84dbe0fc714d9d5839183d3a050b3e5f4
    CRC32: d8bd152f
    IndComEIP1.2.1.txt (628 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-Industrial Communications for EtherNet/IP Readme
    Version 1.2.1
    July 2012
    This file contains information about the NI-IndCom for EtherNet/IP software for Windows 7/Vista/XP and LabVIEW™ Real-Time (RT). Information in this file is organized in the following sections:
    New Features and Changes
    EtherNet/IP 1.2.1
    EtherNet/IP 1.2
    EtherNet/IP 1.1
    The NI-IndCom for EtherNet/IP software contains an extensive library of VIs and properties you can call from LabVIEW to program your customized EtherNet/IP applications for your devices.
    New Features and ChangesEtherNet/IP 1.2.1
    • Added support for NI License Manager
    • Added support for LabVIEW 2012 32-bit and 64-bit
    • (Bug ID 336355) Resolved a problem that EtherNet/IP can not be included in the installer created using Application Builder
    EtherNet/IP 1.2
    • Added support for LabVIEW 64-bit
    • Added support for LabVIEW 2011
    • (Bug ID 307085) Resolved a stability issue seen only in LabVIEW RT 2009
    • (Bug ID 305672) Resolved a problem that ethernetIPInterface.dll is not exported when building an EIP Windows application
    EtherNet/IP 1.1
    • First official release to support EtherNet/IP
    • Added example VIs to show how to use the VI APIs for creating EtherNet/IP applications
    • Added more LabVIEW error codes to better diagnose problems
    You can install and run this version of the NI-IndCom for EtherNet/IP software on the following operating systems:
    • Windows XP (32-bit)
    The NI-IndCom for EtherNet/IP installer does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Caution  If you upgrade your system from a prior version of Microsoft Windows to Microsoft Windows Vista, you must uninstall all National Instruments software prior to performing the upgrade. After the upgrade is complete, you can reinstall your National Instruments software.
    The NI-IndCom for EtherNet/IP software supports the following NI hardware products in the LabVIEW Real-Time Module:
    • Desktop PCs
    • NI PXI controllers
    • NI CompactRIO
    • NI industrial controller
    • NI smart cameras
    • NI Compact Vision System
    • NI Embedded Vision System
    Software Requirements
    NI-IndCom for EtherNet/IP software requires at least one of the following software applications:
    • LabVIEW 2009 (32/64-bit), 2010 (32/64-bit), 2011 (32/64-bit), and 2012 (32/64-bit)
    If you want to run EtherNet/IP software on the NI real-time hardware platforms, you also should install the LabVIEW Real-Time module:
    • LabVIEW Real-Time (ETS) 2009, 2010, 2011 and 2012
    Before installing the NI-IndCom for EtherNet/IP software, log on as Administrator or as a user with Administrator privileges. The NI-IndCom for EtherNet/IP software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Complete the following steps to install the NI-IndCom for EtherNet/IP software:
    • Insert the NI-IndCom for EtherNet/IP software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-IndCom for EtherNet/IP software CD.
    • The installation wizard guides you through the necessary steps to install the NI-IndCom for EtherNet/IP software. You can go back and change values where appropriate by clicking the Back button. You can exit the setup where appropriate by clicking Cancel.
    Installing the Software on a Real-Time Target
    Complete the following steps to install the NI-IndCom for EtherNet/IP software on a real-time target in Measurement & Automation Explorer (MAX):
    • Expand Remote Systems in the configuration tree and expand your real-time target.
    • Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
    • If the real-time target is a CompactRIO controller, select Custom software installation.
    • Select NI-IndCom for EtherNet/IP in the feature list and click Next.
    • Follow the remaining installation instructions until installation is complete.
    Refer to the NI-Industrial Communications for EtherNet/IP Help, accessible by selecting Help»NI-Industrial Communications for EtherNet/IP from the pull-down menu in LabVIEW, for information about using the NI-Industrial Communications for EtherNet/IP software.
    LabVIEW examples for the NI-Industrial Communications for EtherNet/IP software are in the labview\examples\ethernetip folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create.
    Important Information
    © 2010-2012 National Instruments. All rights reserved.
    LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information section at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2026-4-23 10:36
