查看: 2970|回复: 0
[NI驱动程序] NI-SLSC 18.0 Driver Win32/64Eng NI开关负载信号调理设备驱动18.0版下载
    发表于 2020-11-8 23:43:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    18.0
    文件大小: 481814700 字节 (459.49 MB)
    修改日期: 2019-06-25 03:09
    MD5: 6f4b4a313f6bcc150377451efd39820b(官方正确)
    SHA1: 8f9fa8d284cf68ad531ddd2f07bf54e82be542fd
    SHA256: abf95eaf809b5b1d0b46a1c259f4bea75841bbf6d091510ff0fe279b7d9e81fe
    CRC32: 9c79cff6
    SLSC18.0.txt (252 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SLSC 18.0 Readme
    May 2018
    This file contains important information about the NI-SLSC driver software, including new features and known issues.
    NI-SLSC 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-SLSC dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SLSC 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SLSC 18.0 to an unsupported OS. Additionally, after installing NI-SLSC 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SLSC 18.0 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-SLSC
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module12015, 2016, 2017, 2018
    1 NI-SLSC supports Phar Lap ETS and NI Linux Real-Time targets, but does not support VxWorks targets.
    • Added support for the SLSC web API. The SLSC web API is platform-independent and performs operations on SLSC chassis and modules by sending HTTP requests to the web server on SLSC chassis.
    • Added the reservation timeout input to the Reserve Devices VI. You can specify a period of time for the Reserve Devices VI to wait when you want to reserve devices that have been reserved by other sessions.
    • Combined property commitment and command execution into a single round-trip network transaction. If any properties have pending changes for the devices or physical channels, LabVIEW automatically commits the properties before executing command.
    • Added support for new flash devices for Module Memory. Refer to the SLSC Design Guidelines in SLSC MDK 1.2 for more information.
    • Added support for LabVIEW 2018.
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.2 or earlier
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-SLSC 18.0.
    Refer to the NI-SLSC Help, accessible by navigating to the C:\Users\Public\Documents\National Instruments\NI-SLSC\Documentation directory and opening NI-SLSC Help.chm, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    © 2016–2018 National Instruments. All rights reserved.
    376773D-01
    GMT+8, 2026-4-23 09:14
